Tops of resistor have seperated
  • megaraider
    • Jul 2015
    • 307
    • Portugal
    Re: Tops of resistor have seperated
    P.S.: I'm still curious to know in what device it's being used?
    • Amraks
      • Nov 2011
      • 725
      crossovers for concert speakers. there is 8 - 10 of these crossovers in their system they hire when bands tour the state I am in.
      • megaraider
        • Jul 2015
        • 307
        • Portugal
        Thanks for indulging my curiosity
        • TinkerTron
          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
          by TinkerTron
          Hey everyone,
          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
          Instead, here's what's been bugging me so far:
          The schematic...
          03-06-2025, 02:03 PM
        • artvandalai
          What resistor ohm will work better to repair this waterpik?
          by artvandalai
          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
          01-05-2025, 04:10 PM
        • flat-earther
          Hoover FM216LI cordless vacuum refuses to charge
          by flat-earther
          I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
          I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
          5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
          So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
          06-06-2025, 03:14 AM
        • chth96
          Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
          by chth96
          I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
          Since then, This AC/DC adaptor have been out of order.
          But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
          After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
          And Is there any possibility that it will suddenly explode as well as to be out...
          12-03-2023, 04:40 AM
        • badcap111
          Xiaomi mi 9T missing resistor
          by badcap111
          Hi, while trying to replace a broken screen connector on the motherboard, I knocked off a resistor next to the connector, and the resistor vanished. I have tried to find out the value of the resistor by looking at the schematics, but I cannot find the value. The ID of the resistor, or what you should call it, is R6400.
          I don't know if the resistor is necessary for the phone to function, and the connector is still not soldered on to motherboard. I have contacted Xiaomi and asked them if they know the value, but they want a proof of purchase, which I don't have.
          Is...
          08-07-2023, 10:42 AM
