Rework station ir6500 out2 off
  • RavoLx
    • Jan 2019
    • 13
    • Morocco
    hi everyone i'm new here
    as you read i have a problem with my machine as the out 2 does not illuminated anymore since i changed the configuration, how fixed this problem?
    I do not know what is the function of OUT1 and OUT2 :shock:
    Thank you in advance.
  • petehall347
    • Jan 2015
    • 4426
    Re: Rework station ir6500 out2 off
    is there a way to do a reset ?
    • petehall347
      • Jan 2015
      • 4426
      manual here https://cdn.badcaps-static.com/pdfs/...764db3de0d.pdf
        • 30985
        i have posted manuals for those controllers here before.
        • RavoLx
          • Jan 2019
          • 13
          • Morocco
          i don't know
          • RavoLx
            • Jan 2019
            • 13
            • Morocco
            could you plz send it to me? or share it
              • 30985
              use the search function.
              • RavoLx
                • Jan 2019
                • 13
                • Morocco
                the rework station works fine, but I still do not know what is the role out2
                • petemanuk
                  Help with IR6500 rework station
                  by petemanuk
                  I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
                  1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
                  2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
                  10-14-2022, 12:31 AM
                • shahnld
                  wds-580 rework station issue
                  by shahnld
                  Good day.
                  i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
                  Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
                  kind regards...
                  03-28-2024, 01:14 PM
                • minimania
                  Need Schematic for jbc am6800 rework station
                  by minimania
                  hi all im looking for a Schematic for jbc am6800 rework station
                  mine has stopped working fully
                  it started with turning off when switched on then after a few off and ons it worked sort of for awhile
                  now it wont turn on at all...
                  01-28-2025, 03:44 PM
                • shahnld
                  Seamark ZM-R6200 Rework station
                  by shahnld
                  Good day Experts.
                  I have recently aquired a rework station SEAMARK ZM-R6800,. Is there anyone using this or some other similar station and give me some info about profile temp curve etc for removing leadfree soldered gpu chip..? just 1 profile will be enough to get started.
                  Kind regards
                  01-24-2024, 10:55 AM
                • Peter_1402
                  Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                  by Peter_1402
                  Hi Everyone,
                  I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                  1. Soldering iron works great
                  2. There is a burnt mark on the hot air gun handle.
                  I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                  Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                  Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                  Reed switch tested ok with a magnet.
                  From the above test, I can conclude...
                  07-12-2025, 11:50 AM
