Looking for a new rework solder station
  • the Noof
    • Aug 2016
    • 6
    I am looking into buying new solder rework stations. Currently we use the Pace MBT350. I am not happy with this station. I have used the Weller WR3000M station for about a week while doing some training. I thought it was pretty nice. But I have seen some mixed reviews on it. What about Hakko, JCB, Metcal… Any suggestions, or advice?
    Thanks,
    Brad
    • 31087
    Re: Looking for a new rework solder station
    define "rework"
    • the Noof
      • Aug 2016
      • 6
      soldering desoldering. SMT, through hole
        • 31087
        so iron, desoldering iron, hot air?
        • the Noof
          • Aug 2016
          • 6
          This a small operation. We populate new PCBs. Build prototype PCBs. Do upgrades of boards. Repair PCBs from the field. Need hot air and vacuum.
            • 31087
            best small hot air is the quick 861DW - look it up on youtube
            vac not so easy to say.
            • llonen
              • Sep 2014
              • 495
              • hampshire
              I have been using a collection of MBT250's, ST115 and a couple of ST45 with a dozen or so Pace hand-pieces. Cant generally fault them other than the pricing I guess, that said all of my Pace equipment was obtained from lab clearances at a substantial saving over new. Other than some of the tips being a little difficult to obtain in the UK I don't find any problems. I do use a hakko fr803 for my larger mass SMD hot air work until such time as I can locate a Pace BGA rework or Pace Thermo at a cost I am willing to pay. At least half of my work is required to meet IPC soldering standards or some of them at any rate.
              • llonen
                • Sep 2014
                • 495
                • hampshire
                When I get back to the Lab tomorrow I will put up a more complete list if it is any use to you.
                • vanrepair
                  • Oct 2018
                  • 10
                  • canada
                  Still looking for a rework station? I have a spare Metcal MRS-1100A setup I could let go of
                  https://www.tequipment.net/Metcal/MR...hoCogoQAvD_BwE
                  • trvr
                    • Mar 2019
                    Do you still have your spare Metcal MRS-1100A?
                    • chiefcrypto
                      • Apr 2019
                      • 13
                      • England
                      I've heard good things about the hakko fx-951 station, can't speak from personal experience though.
                      • shahnld
                        wds-580 rework station issue
                        by shahnld
                        Good day.
                        i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
                        Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
                        kind regards...
                        03-28-2024, 01:14 PM
                      • minimania
                        Need Schematic for jbc am6800 rework station
                        by minimania
                        hi all im looking for a Schematic for jbc am6800 rework station
                        mine has stopped working fully
                        it started with turning off when switched on then after a few off and ons it worked sort of for awhile
                        now it wont turn on at all...
                        01-28-2025, 03:44 PM
                      • shahnld
                        Seamark ZM-R6200 Rework station
                        by shahnld
                        Good day Experts.
                        I have recently aquired a rework station SEAMARK ZM-R6800,. Is there anyone using this or some other similar station and give me some info about profile temp curve etc for removing leadfree soldered gpu chip..? just 1 profile will be enough to get started.
                        Kind regards
                        01-24-2024, 10:55 AM
                      • petemanuk
                        Help with IR6500 rework station
                        by petemanuk
                        I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
                        1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
                        2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
                        10-14-2022, 12:31 AM
                      • Crystaleyes
                        Tenma (Farnell-rebranded) 21-10115 solder station question
                        by Crystaleyes
                        Olá.
                        Looking for some help clarifying something.
                        I have a Tenma (Farnell-rebranded) 21-10115 solder station which recently burnt out the ceramic element.
                        The station is 60W / 28 volts, 110v.
                        Right now I'm in Brazil and finding an equivalent element has proved to be not possible, so today I bought a 'Yaxun' 50W 24v iron in the hope that it would work.
                        Both irons have a five pin plug.
                        The Tenma had pins 1 & 2 and pins 4 & 5 shorted with pin 3 being the ground. No means of measuring the temperature.
                        10-19-2021, 08:08 PM
