YH-853AAA soldering station any good ?
  • petehall347
    • Jan 2015
    • 4426
    looking to buy a hot air gun but found this instead which would be lots better if any good and worth the money .
    anybody use one ?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: YH-853AAA soldering station any good ?
    Looks like a cheap £30 hot air gun above a pre heater with a crappy iron attached.
    • petehall347
      • Jan 2015
      • 4426
      anything better for similar price ? might go to £200 for right tool .
      • diif
        • Feb 2014
        • 6978
        • England
        What are you after ? I'm looking looking to upgrade my hot air station to a Quick 861DW.
        I have one of those hot air stations with the pump in the base, whilst it's ok, it tends to be a little inconsistent with the heat.
        • petehall347
          • Jan 2015
          • 4426
          just need something that works .i do very little right now but with tools that can do it for me i might well do more . 2 jobs now waiting for at least hot air gun . pre heater looks a good thing to have on tap . adjustable iron with all those tips looks handy too ..apparently this is a hakko copy .
          • diif
            • Feb 2014
            • 6978
            • England
            It depends if the iron is a good or poor clone. The poor ones have a gap between the element and tip so poor conductivity. I have 3 of those types here I don't use, I bought a £25 T12 clone and a handful of tips for around £3 each and it's so much better.
            If you want some cheap hot air, I'm sure the 858D+ has been mentioned around here and other places as an ok piece of kit. It's around £30.
            The only time i'd want to use a pre heater would be doing BGA rework on laptops and TVs, that thing is to small for them. It might be ok for phone work..
            There are many T12 clones available with a few different style handles. The best one I have found is this one in this link. The other handles I've seen are much clumsier to hold. https://www.aliexpress.com/item/2018...2857177827.htm
            • petehall347
              • Jan 2015
              • 4426
              seeing a white page from link .. i need something soon .. i looked at hot air only then thought led changing . etc .
              • petehall347
                • Jan 2015
                • 4426
                i could work around a decent hot air blower for now .. .. that is what i was looking for first . selected low price first and saw shite things . so went other way . i like antex but cant afford it ..top class company .
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Ooops https://www.aliexpress.com/item/QUIC...857152188.html
                  I've used a cheap hot air station for a few years now, and apart from slight variations in it's temperature from one day to the next it does the job. It's type with the pump in the base rather than the handle.I shall however be getting a Quick 861DW fairly soon though, it's a little over £200. https://eleshop.eu/quick-861dw-hot-air-station.html
                  • petehall347
                    • Jan 2015
                    • 4426
                    was wondering if in case any part failed out of warranty if it could be easily repaired with higher grade parts ?
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      I doubt it. And what higher grade ? It's cheap hot air and a cheap iron, a t12 cartridge based iron is an upgrade from the one on the all in one and is £30. The hot air can't be upgraded.
                      I got a hot air and iron station similar to the one in the photo with the tips that go over the element. I used it once and unplugged the iron as it was garbage. I bought a t12 iron and have been very impressed. I've used both for a couple of years now and whilst neither has let me down, I'm hoping to buy a Pace ADS200 and the Quick 861DW.
                      • petehall347
                        • Jan 2015
                        • 4426
                        my iron in use is fine so dont care about it ,, antex 30w i think .. 1mm tip too big so need smaller . one blob of solder brings the solder sucker into action . luckily i dont need to get too close with it . leaves pins properly soldered after small touch ups .. i need this thing for component removal and replacement of such as bga or soldered behind . or soldering with paste .or a simple reflow to correct my shit work thats connected fine anyway . i have more work stacking up if it will do it ..
                        i did read into this a bit and looks like hakko copy .. so would hakko plug in and is it any better ? it all looks the same in the pics .. wish it was like old days when you could go and look and maybe try it first ...
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          Looks like Hakko, but will be like all the other clones, large gap, so poor thermal transfer and next to a £30 t12 a steaming turd. The t12 cartridges are also Hakko clones, but are far superior.
                          • petehall347
                            • Jan 2015
                            • 4426
                            bloody living nightmare trying to save the planet ... suppose i could use fit for purpose clause if its really crap .
                              master hoarder
                              • May 2008
                              • 12175
                              +1000000
                              T12 is the way to go. Calling those cheapo irons with 900M tips (the type that slides over the heating element) as shit is an understatement. Even my 30 Watt Radio Shack iron with its worn out small Copper pencil tip is more powerful and easier to use. Unless you're a pro at machining and can make your own copper tip with a very tight fit for those 900M irons, you're better off not getting one.
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                Or take the advice and avoid the Chinese all in one piece of crap and buy individual tools that are cheaper over all and will be better quality.
                                • radcliffkaty1
                                  • May 2018
                                  • 7
                                  Did you checked the "Makita HG551V 1020-Degree Heat Gun"? This is one of the cheapest(£80.76 ) and best hot air gun I found. You can get it from various eCommerce stores.
                                  • petehall347
                                    • Jan 2015
                                    • 4426
                                    thats a paint stripper gun
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      LOL
                                      It can still work, though, as it has variable heat output and not just "high" and "low" settings like most cheaper heat guns. It's probably going to take a few boards as victims before you get used to the tool and figure out what temperature and airflow give the best results, though. I'm already doing that with a regular cheapo 2-speed heat gun that I got for $20, and I can reflow most things easily without overheating/burning anything.
                                      For £80.76, though, you really can just buy a hot air station instead and not have to worry. And if you need more heat, then get one of those cheapo 2-speed heatguns, and use perhaps as a bottom heater on the low setting. Here in the US, you can find these for about $10 in Harbor Freight Tools (not the best quality, but they do work), or $20-30 in other stores.
                                      • petehall347
                                        • Jan 2015
                                        • 4426
                                        have been looking at this one .. i like antex https://www.ebay.co.uk/itm/Soldering...IAAOxy3HJTHt8n
                                        • mkbehbeh
                                          KSGER C245 Soldering station PSU 220V only?
                                          by mkbehbeh
                                          I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
                                          I am...
                                          04-17-2023, 03:11 PM
                                        • Peter_1402
                                          Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                                          by Peter_1402
                                          Hi Everyone,
                                          I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                                          1. Soldering iron works great
                                          2. There is a burnt mark on the hot air gun handle.
                                          I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                                          Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                                          Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                                          Reed switch tested ok with a magnet.
                                          From the above test, I can conclude...
                                          07-12-2025, 11:50 AM
                                        • nbdy
                                          QUICKO soldering station
                                          by nbdy
                                          HI,
                                          Have a QUICKO soldering station with no numbers for the model ... (think it's a KSGER or similar copy)
                                          All worked nice, till some day it heats the iron till it was RED (HOT) ...
                                          Turned it off, and tryed today again, and all the same, even with a second iron ...
                                          The display shows that the iron is not connected, like not inserted in the handle ...
                                          The second thing is that it has 6 pins connector and can't find a handle that is similar for my station ...
                                          Has someone some advice what to do, where to look, even how to...
                                          01-07-2024, 05:44 PM
                                        • sparcktikus
                                          Ersa Rds 80 soldering station burnt resistor
                                          by sparcktikus
                                          Hi
                                          I have an Ersa rds 80 soldering station which has developed a fault and just showing err on display
                                          I have found a burnt resistor on pcb can anyone help me identify this resistor if you have a circuit diagram or similar unit
                                          The printed circuit board markings are rd80 ver 2.0 and the resistor in question is R6
                                          Many thanks...
                                          04-04-2023, 04:29 AM
                                          HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-12-2024, 02:20 PM
