Tektronix 2232 100mhz
  • heavymachines
    • Mar 2011
    • 1028
    Thinking about buying this for possibly under 100 bucks will this suffice for tv repair?
    TEKTRONIX 2232 100MHZ 2-CHANNEL DIGITAL STORAGE OSCILLOSCOPE
    It comes with probes and a pouch. Yeah i will need to learn how to use it but i think i can.
  • KYBOSH
    Tektronix 422 with No Power
    by KYBOSH
    Picked up a Tektronix type 422 oscilloscope locally for a few bucks last year.
    It wouldnt power on at all so I stowed it away under my bench for later testing.
    Today I remembered it was down there and pulled it out to see what was what.
    I checked for continuity and everything checked out.
    There was a burned smell and a resistor was replaced with a temporary replacement (see yellow box in picture).
    The burned smell is very pungent/acidic and I am not familiar with these vintage electronics to know whether I am smelling the remains of the replaced resistor or...
    02-03-2024, 07:56 PM
  • vanel
    tektronix 5103n(D11) Oscilloscope creap
    by vanel
    I tried to figure out which section this belonged in, but imaging is the one that seemed closest. I have a tektronix 5103n(D11) and the horizontal line is always slowly creaping down. Even if I have it probing a voltage. I tried probing a 9V battery and it would show 9V at first then very slowly keep moving down. Is there an adjustment I can make or is the scope in need of reapir? Thank you.
    10-07-2023, 07:34 AM
  • ivcho_gd
    tektronix ths720 schematic needed
    by ivcho_gd
    Hello, I have a problem with ch2 of tektronix ths720 scope.
    It suddenly stop working and indicate input.
    do you have any suggestions for troubleshooting or schematic to check.
    Thank you!...
    04-26-2023, 10:04 PM
    Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
    by sam_sam_sam
    I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
    I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
    I tested the battery cells there are installed right now and they are testing good with no issues that I...
    02-04-2025, 08:08 PM
  • flc1988
    Tektronix TDS220 power supply
    by flc1988
    Dear,
    I have a TDS220. I don't know what voltage output power supplu "Ault Korea". Does anyone have the power supply schematic or the output voltages?
    01-07-2025, 06:28 AM
