HM-1004-3 scope part needed
  • mastercare
    • Sep 2010
    • 5
    hi all
    can anyone suggest where i can get a new multiplier for above scope..as mine has started arcing...
    its a good scope or has been any help would be great...
    cheers ref hameg 1004-3
    paul..
  • G-Sting
    iPad Pro A1876 SHORT Part Identify Help Needed
    by G-Sting
    So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
    So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
    i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
    SO My main concern is what part should i order what should i search the name for ?
    on Ipad...
    05-15-2025, 09:30 AM
  • edugimeno
    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
    by edugimeno
    Hi There!
    I'm trying to help my friend who owns a restaurant be just bought.
    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
    It's stuck using, I guess, the 2 sided tape that comes with the strip
    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
    09-05-2024, 09:34 AM
  • vbogoev
    Lenovo S6000 won't turn on. Data recovery needed.
    by vbogoev
    Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
    Code:
    [PWRAP] pwrap_init_preloader
    [PWRAP] pwrap_init
    [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
    [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
    [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
    [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
    [PMIC_WRAP]wrap_init pass,the return
    06-20-2023, 06:36 AM
  • Goblin999
    RTX 3060 EVGA - Part Discover Help Needed
    by Goblin999
    Hello , I have this 3060 EVGA card that doesn`t work . Measured for shorts and resistance , seems ok . Powered it up but doesn`t work , GPU chip is cold . Though this part circled in red is getting very hot and pretty fast so I suspect this is the reason . Can somebody help me discover what this part is . Maybe a data sheet or a similar part ? Thanks...
    02-10-2022, 09:09 AM
  • CraigR
    Used PS5 part needed
    by CraigR
    Client decided to do his own repairs and knocked off this inductor coil. I can not find anyplace to purchase a new one and do not have a donor board so can someone sell me one off their donor board or give me a link to where I can purchase a new one? THANKS!...
    06-19-2024, 02:29 PM
