Hot air rework temperature help
  • caphair
    • Nov 2011
    • 1249
    When removing/replacing chips. Is it safer to use little to no air flow but higher temp heat or lower heat with more airflow?
    My hot air station is a model 852d+ with a max temp setting of 500c and max airflow temp of 8.
    I was testing melting a ball of lead free solder with a 4mm tip and at 365c 1 air flow speed it melts in 20 seconds. At 340c 4 air speed it melts same amount of time but not sure if more air speed is dangerous for near by components or components on the underside of the board.
    Is the goal to remove chip as quickly as possible or at a slower time? I'm working on small mobile device boards that don't require a preheater.
    I've ran into issues before while practicing where components underneath on opposite end of the board suffered from the heat causing shorts under the bgas.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Hot air rework temperature help
    Using a preheater means you can use your hot air for less time and have less of an effect of components at the opposite end of the board.
    I have mine set to about 380-400c.
    Air speed depends on what I'm removing.
      • 31197
      too much airspeed will cause the heat to effect a larger area.
      you need to set it for the job - desoldering a chip needs more air than a transistor because your moving the jet around the package.
      also, temp needs to be set based on both the solder and the distance beween the part and the nozzle.
      • caphair
        • Nov 2011
        • 1249
        Hmm so for a bigger chip, more airflow but my concern is preventing opposite side of PCB chips getting too hot that solder melts. Would closer high temps less airflow have more or less chance of that happening?
          • 31197
          i keep the airflow pretty low, and the nozzle maybe 5-10mm from the work
          • caphair
            • Nov 2011
            • 1249
            What would your "pretty low" airflow be compared to mine having a max setting of 8?
              • 31197
              couldnt say, my gear is different.
              probably about 20-25%
              • petehall347
                • Jan 2015
                • 4438
                do you not use masking ?
                • petemanuk
                  Help with IR6500 rework station
                  by petemanuk
                  I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
                  1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
                  2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
                  10-14-2022, 12:31 AM
                  Multifix 425-01 and 450-01 Rework Flux Datasheet
                  REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                  - No Clean Formulations
                  - Low residue
                  - Range of activity to deal with different component solderability
                  - Halide free
                  - Suitable for dispensing
                  - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                  Both products are supplied in syringes or cartridges for application by dispensing....
                  10-07-2024, 06:02 AM
                • howardc64
                  820-3536 No Camera Detected fix
                  by howardc64
                  This is probably a unique fix but debug sequence might be useful for future failures.
                  Got the MBP from a laid off repair tech along with other stuff. Poor repair jobs everywhere I looked. On this board, U3900 appears to be just slightly misaligned from prior reflow/replacement. System fully boots. No camera detected is the issue. Pic from my cheap $15 USB microscope
                  Checked the camera connector (J4002). Pin 10/11 voltage generated by U3900 was missing so pretty likely camera wasn't putting out the power rails. That left 3 possibilities
                  08-04-2021, 09:31 PM
                • Mr_Nada
                  Concerns before attempting a Reflow of Laptop's GPU
                  by Mr_Nada
                  I saw some posts at one point talking about doing a reflow but I couldn't find them again so I thought that I would post this here.
                  I plan on reflowing the GPU of this old HP DV2500 laptop but I want to go over what I have and the steps I have to take to guarantee it will come out fine.
                  I have a Yihua 8786D 2in1 Rework station, flux (just some paste that I got from an old Radioshack kit), a couple rolls of Kapton tape and a $15 Thermometer +probe (a TM902C from EMR shielding Solutions if its important).
                  • The paper that came with the thermometer states that the probe
                  10-10-2024, 02:53 AM
                  Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                  The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                  Securing a good thermal interface between...
                  10-07-2024, 04:35 AM
