Need software for Intelligent universal programmer lk48
    replied
    Re: xp48 programmer
    only a mod can do that.
    it does explain that arguement we had over wether they had removed the parallel port version or not.
    i was unpacking it with win7 64bit and you obviously had the last decent o.s. m$ ever made
  • megaraider
    replied
    Re: xp48 programmer
    Originally posted by stj
    just read some interesting shit at the makers site,
    with the latest software releases you MUST use win-XP and it MUST be 32bit or the installer wont install the parrallel port software.
    if your on Vista or newer and/or running 64bit it will ONLY install the UXP usb-port software version!
    i suspect it's because they use a 3rd party parrallel port driver from jungo.
    Thanks, good to know.
    imo it would be more helpful if you move your post to the 'original' thread.
    replied
    xp48 programmer
  • mgaloi1970
    replied
    Re: Need software for Intelligent universal programmer lk48
    Originally posted by Skybug2
    did you manage to find a valid license file or a patch to use the software Labtool uxp or dataman?
    thanks
  • megaraider
    replied
    o.k. i have other problems then, fucking windows is screwing around.
    Just a hint: try installing previous versions and watch the behavior. If problem persist then it's, most likely, win screwing around.
    replied
    i'll take notes and open a thread for it
  • megaraider
    replied
    i did, i'm getting a 12gig file that only installs 1 folder with a usb icon.
    LT**UXP_1300_WIN7.exe (CRC-32: 567212F4)
    Installed folders ...\Labt00l-**UXP, and ...\Labt00l-**XP:
    See screen capture files attached.
    replied
  • megaraider
    replied
    from ADV??
    Yes, follow the 1st link on your own post.
    replied
    from ADV??
  • megaraider
    replied
    did you just do that or just print it? [...]
    Did it all myself yesterday, top to bottom! [Copy / paste is not my style ]
    ALL fully tested under W7
    replied
    Originally posted by megaraider
    Here we go again:
    1. Download:
    'LT**UXP_1300_WIN7.exe' (~12.5MB)
    or
    'LT**UXP_1300_WIN10.exe' (~12.6MB)
    2. Install.
    3. Check installed folders ...\Labt00l-**UXP, and ...\Labt00l-**XP
    Either win7 or win10 installation file will create both folders.
    4. Patch the exe file:
    For 'WLT**XP.exe @0x0003DF80 from 0x55 to 0xC3
    For 'WLT**UXP.exe @0x0043DEF0 from 0x55 to 0xC3
    And again, please do us all an obvious favor:
    - Don´t post obvious strings: Advant3ch 3quipment, labt00l, ...
    We really do not need the devil's search engine to find us...
    - stop attaching large files widely available on internet to posts.
    - use g00gle
    - DIY - ALL information you need is here
    i downloaded about 8 versions yesterday and none created 2 folders anymore!
    i also tried the version from DataMan and got the same problem.
  • megaraider
    replied
    Here we go again:
    1. Download:
    or
    2. Install.
    - use g00gle
    replied
    no, single folder with the usb version in it
    i think the download should be over 20meg
  • PitMakot
    replied
    This version have both folders
    replied
    actually it looks like the fuckers have removed all the XP versions from the downloads!
    i may look at wayback-machine later.
    replied
    i think that works with both interfaces
  • comatuning
    replied
    but is presente exe only uxp, not exe for parallel port. i have labtool with only parallel port because usb is dead. on old pc with XP work fine, but old pc is dead
    replied
    yes, in there is the exe file
  • comatuning
    replied
    look this photo
