Smart Tweezers? Do They Work?
  • Nerfinator
    • Feb 2015
    • 56
    I'm looking at getting a set of "smart tweezers" to test capacitors without removing them from the board. However, I was always told the only way to test a cap was that you had to remove them from the board first.
    I'm looking at one of these from eBay. Smart Tweezer
    My question is, do they work as advertised? Will I be able to test smd caps onboard or should they still be removed to test to make sure they are not faulty?
    I don't wanna get by my ignorance.
    Thanks in advance.
    Re: Smart Tweezers? Do They Work?
    If there are other components connected in parallel with the cap which will be the load, and if there are other caps connected in parallel, then you cannot tell which cap is bad.
    Always remove the cap or any components off the board to test.
    • retiredcaps
      • Apr 2010
      • 9271
      The ebay listed auction item doesn't test ESR either.
      --- begin sig file ---
      --- end sig file ---
      • redwire
        • Dec 2010
        • 3912
        I have the SmartTweezer ST5S. Excellent on MLCC's and tantalums and SMD parts.
        They work really good, but (presently) the limit on measuring capacitance is to 999uF. They are doing a firmware update so range may get better.
        They can get confused in "Auto" mode if the circuit has resistance or diodes, put it in Manual mode to get your reading or pull out the part.
        • Nerfinator
          • Feb 2015
          • 56
          Thank you for the replies, I really appreciate it. I'm going to hold off for now then on smart tweezers as I'm not doing enough TV work to offset that kind of cost, but I'm glad to hear the ST5S work well.
            • 31197
            i just hold the meter probes like chopsticks!
            • dellxps15
              • Feb 2014
              • 1598
              • italy
              ive bought a cheap small tweezer (20€ ship included), and they are ok with resistor, but for capacitor if they are soldered im unable to read them properly....
