Can I flash a working BIOS from one computer to another of the same make, model, etc?
  • TyMercer
    • Nov 2025
    • US
    Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't and the thing stopped showing video. I think somehow I managed to corrupt the BIOS as I tried to restore to factory settings.
    Looking on the BIOS request forum, I see that there lots of people who can provide clean BIOS files, but I'm trying to understand where those come from. For example, could I merge the .bin file I get from reading my good BIOS chip with the file on the corrupted one? Do I go line by line looking for differences and correct them by hand? Or as my topic suggests, can I just flash the .bin file from the working computer onto the BIOS of the non-working one? A Google search says no, but a Duck Duck Go search says yes. I"m at the theoretical stages here, so I don't even know for sure if the two machines use the same BIOS chip. I just first want to understand how the clean BIOS files are generated and I want to see whether I can generate one myself.
    Please do let me know if I need to move this and I look forward to learning from you experts. It may take awhile to reply as it's a busy time of year for me, but I'll be back in eventually.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12420
    It's perfectly fine if you "clear Me" and copy the DMI from the old file over.
    • maanee11
      Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
      by maanee11
      Hello Everyone,
      I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
      It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
      In the website, you can only see specs etc.
      I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
      11-08-2025, 04:08 AM
    • to5it0
      by to5it0
      10-24-2025, 01:35 AM
    • abhorsen
      Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
      by abhorsen
      Hey guys,
      Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
      Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
      Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
      07-06-2023, 10:22 AM
    • survivalbloke
      If I flash this bios file, will it just work, or does it need the ME cleaning?
      by survivalbloke
      I'm not a super pro like some here, when it comes to firmware. I have a machine with the following specs:
      ENVY X360
      15-ew0013dx
      SN: CND2261KS3
      Prod: 698V0UA
      Board: LA-M021P Rev 1A
      Chip# Winbond 25R128JVSN​
      Basically, when I power it up, I get no video, and the fans run hard - nothing else. Seems like a BIOS issue to me, so I posted a request in the BIOS request section. I haven't heard anything back(and that's fine) So I tried downloading the BIOS from HP, then I extracted it and flashed it onto the chip. Unfortunately, all I get is the power...
      10-09-2024, 08:40 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
