Desoldering Question.
  • Lucretia
    • Oct 2004
    Hi. Its been awhile since i've soldered on a motherboard. The last one
    I did was an 8088XT in 1990. SOME silly person (Ok, me :oops: )
    Plugged the connectors on wrong and blew out a cap . I replaced them
    and Voila! it worked again. (Gotta love those indestructable XT's )
    Anyway, My question is simple. Can i just use my desoldering iron to remove the solder through the bottom of the board? Will this damage or
    remove the foil insert? Or will it simply not remove all the solder necessary to remove the cap? I'm not an expert in soldering, so far be
    it for me to question Topcat's How-to, but I'm curious. ( Although I doubt the XT MB was 6-layer)
    Lucretia
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    if your desoldering iron gets hot enough it should do the trick.
    the danger of tearing out the feedthru in the board comes from pulling the leads out before the solder is fully melted.
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • viewerau
      Remove excess solder
      by viewerau
      Can someone tell me how (or if) I can remove this excess solder?
      I made a novice boo boo.
      The board is an edge board from an lcd tv, and it connects to the tv panel via a fixed cof strip.
      I had to remove a surface mounted multi diode chip (yes I did a bad job) but got some residue solder on the pins when cleaning it up with a ribbon wick.
      Can I get that excess off, as I believe it is causing interference to the panel, shorting or something, that effects just a small portion of my image.
      Any pointers please?...
      08-16-2023, 03:52 AM
    • corrize
      Best way to solder LVDS connector for beginner (and qfn) ?
      by corrize
      Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
      I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
      I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
      See the test :
      https://youtu.be/bNAzC-EvqHs?t=1767
      With hot air from bellow the board, that's...
      03-09-2023, 02:57 AM
    • Geeker007
      Friend messed up my laptop motherboard while working on my bench
      by Geeker007
      Hi All,
      So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
      So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
      I have not tried putting...
      06-16-2025, 01:40 PM
