best place to get pcb flux ??
  • tonyuk
    • Feb 2014
    • 238
    • uk
    hi im after some pcb flux but need fast cant find anyone near me does anyone have link for some plz
    Re: best place to get pcb flux ??
    I recall maplin selling it. Not particularly good stuff but it works.
    • tonyuk
      • Feb 2014
      • 238
      • uk
      went there today they dont sell anymore
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        have you got a rs trade counter by you what part of uk are you in?
        • mariushm
          • May 2011
          • 3799
          I buy from a local store. Some Polish brand Topnik :
          http://termopasty.com/pg_176_172_3_3_1_topnik_tk83.html
          Store sells it at around $4 for 50ml, cheaper in larger bottles (but i didn't need more)
          If this local store stops selling it, I'd probably find it on hotair.pl or other polish stores, or I may just get colophony from dealextreme.com or other sources and mix it with isopropyl alcohol and make cheap flux this way.
          • tonyuk
            • Feb 2014
            • 238
            • uk
            thanks
            • tonyuk
              • Feb 2014
              • 238
              • uk
              im east sussex bexhill
              • Agent24
                I see dead caps
                • Oct 2007
                • 4950
                • New Zealand
                Depending on your required usage will depend on what type you should use...
                -David VanHorn
                • GR-TEK
                  • Apr 2014
                  • Greece
                  If you need flux for BGA or SMD rework then I sugest CS-FLUX. You can order it from ebay here
                  http://www.ebay.com/itm/390792468898
                  and there is a video on youtube about it here
                  http://www.youtube.com/watch?v=p8HN8iw2BHY
                  It is made in Greece so it should be delivered in EU and USA in less than a week ( I am also in Greece and I receive it next day). I run a laptop repair shop and I have tryed all kinds of flux that I could find. This is the best flux by far for VGA reflow . Since I descovered it I only do reflow on GPUs and I have practicaly 100% success and almost zero returns.
                  • chth96
                    Is it good to use chemistronic flux off es835b for flux remover?
                    by chth96
                    I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                    Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                    11-17-2023, 07:25 AM
                  • acedogblast
                    by acedogblast
                    11-02-2024, 05:13 PM
                  • evilkitty
                    Flux causing high resistance short?
                    by evilkitty
                    Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
                    Temp is on the left humidity is on the right
                    i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
                    The pin out looking down from the top is (note this is common cathode)...
                    07-17-2024, 09:38 AM
                  • chth96
                    How can I remove flux with the smallest rubbing?
                    by chth96
                    I have tried to bridging tiny broken trace which is shown in the below link,and I found that it is impossible to remove any flux after soldering task.
                    Is it possible bridging tiny broken trace - Badcaps - Capacitor Search Engine​​
                    Because the 0.02 mm copper wire is very very fragile,So It broke itself very easily whenever I tried to rub excess flux with cotton bud.
                    Is there any way to remove flux with the smallest rubbing or without any rubbing?
                    Any reply would be appreciated.
                    11-24-2023, 05:22 PM
                    Multifix 425-01 and 450-01 Rework Flux Datasheet
                    REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                    - No Clean Formulations
                    - Low residue
                    - Range of activity to deal with different component solderability
                    - Halide free
                    - Suitable for dispensing
                    - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                    Both products are supplied in syringes or cartridges for application by dispensing....
                    10-07-2024, 06:02 AM
