Blue esr mester low readings
  • yo0
    • Jun 2013
    • Mexico
    hello, i recently buy a Blue esr meter, i assembly it, calibrate it, run test procedure (.8.8) was ok, testing several resistors all with good readings, low battery warning adjust was ok too, also check all resistors with dmm before install and double check all parts, places and orientation for install in pcb. well as i write before test procedure shows .8.8 and no error codes but... if a test old capacitors for example a pair of 30 years old 10000 uf 50 volts nichicons i pulled from a old Marantz receiver gives me abnormal low reading = 0.02 ohms, almost same as a brand new Panasonic 10000uf/80v 0.01 ohms, i tested a bunch of several sizes old used caps and all shows abnormal low readings 0.0X ohms, just a really severe bulged cap give me 1.3 ohms, any idea?
    any help or opinions will be appreciated.
    best regards
    Pio
    Mexico
  • WB7ODYFred
    • Jun 2013
    Re: Blue esr mester low readings
    You are measuring the ESR Effective Series Resistance, Pio. You have performed some good testing to understand what your ESR meter outputs under good condition for capacitor under test. 0.02, 0.08, 0.2 are good numbers. Yes a bad severely bulged cap gives me 1.3 ohms.
    I work on ATX Power Supply Units good electrolytic capacitors have low ESR, when they bulge or are bad they have ESRs 0.8 or 1.X and above. Think of high frequency AC current, low ESR low heat generated. High ESR high heat generated. Power = I squared R = curent x current x resistance.
    Conclusion: Low ESR is good in power supplies. When the dialectric dries out the ESR goes up. Yet, Some of the smaller 10-100UF capacitors have 1.0 - 2.0 ohm ESR and are still good functionally. 470uf at 6.3V might have an 0.06 ohm ESR.
    So learn as you go, Pio. You are have the basics down pat and are doing fine. Go out and fix some equipment. That ESR meter will make your job easy to quickly test capacitors from the solder side of the circuit board. If a large filtering capacitor has a high ESR, change it out. Greetings from Oregon, Fred
    • yo0
      • Jun 2013
      • Mexico
      thank you very much for your comments, the intention of the original post is i was expecting higher readings in the old used caps, that make me think there is a problem with the meter, maybe defective or damaged part(s)?
      for example, can be an used 30 years old cap still good?
      best regards
      Pio
      • Kiriakos GR
        Banned
        • May 2012
        • 940
        • Greece
        Electrolytic cap's life is measured by: working hours / to specific temperature range.
        Therefore the unemployed cap which is just soldered it does not get effected by aging.
        From the other hand, every cap model has one specific test frequency chosen by the manufacturer, if your meter is unable to test the cap at the suggested frequency the ESR reading would be totally inaccurate.
        If the cap is too old and there is no posted public specifications, then you are unable to compare it and make your mind about it by just measuring ESR.
        The LCR meters are capable for more measurements and the D (dissipation factor ) gives a more realistic picture according to test frequency's , and so even with out given specifications you can tell in which application the spesific cap it can serve.
        Bottom line, you must learn the limitations of your gadget, so to avoid using it at tasks that is not capable to perform.
        • ttmi100x
          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
          by ttmi100x
          Greetings everyone,
          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
          Upon closer inspection...
          07-31-2024, 06:36 PM
          1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
          I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
          This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
          12-29-2024, 07:18 AM
          Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
          This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
          09-07-2024, 05:50 AM
          Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
          This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
          09-07-2024, 05:00 AM
          Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
          This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
