Multimeter leads question
  • 2hamburgers
    • Apr 2013
    • 20
    Hey everybody! So i am a noob, bought a radioshack multi ($50). Sometimes i find it difficult to get a reading with my leads. I have to poke them around quite a bit to get a reading and its touchy. Do you think it might be a technique problem or do i need to buy a better set of leads? Whats your opinion guys?
  • mariushm
    • May 2011
    • 3799
    Re: Multimeter leads question
    You can try to clean the tips and the sides with isopropyl alcohol ... get some paper handkerchief, dab it in isopropyl alcohol and rub the tips in the wet paper.
    This removes the oxides and whatever crap is on the metal tips.
    But sometimes the probes are simply put, bad. The metal they're made of can have bumbs and pits that you may not see with your plain eyes and it can happen to not get a good contact.
    Now.. as for buying better leads, I guess it depends on the Radioshack multimeter...as far as I know, radioshack stocks cheap multimeters with not so great specs. You may do better by returning the meter for the money and ordering a good multimeter instead online.
    For example I own an Uni-T UT61E that's great, and you can buy it online for about 60$. The probes it comes with are good, they could use a cleaning with alcohol as well but they work just fine for me. It should certainly be a better base multimeter to buy probes for.
    If you want to go this route, I recommend this seller: http://www.ebay.com/itm/UNI-T-UT-61E...item2ec6ac75bd
    You'll have the meter probably within a week
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      In case it is a problem with the actual wires set the meter on ohms and hold the probes touching in one hand - should read 0.00 then with the other hand gently tug each wire and see if it goes to "1" or "OL"
      • smason
        • 1652
        I agree with Mariushm but I'd go a bit further and use some fine-grit sandpaper to really get rid of any oxidization.
        • 2hamburgers
          • Apr 2013
          • 20
          I will clean and sandpaper them. I didn't think oxidization would be a problem with something i bought new....... I will try the touch test too. Im thinking i got a bad multimeter though, sometimes it has readings when nothing is touching the probes. i think its gonna go back to Radioshack ultimately, i will look at the link you gave me. Thanks everyone for helping me out.
          • retiredcaps
            • Apr 2010
            • 9271
            If the multimeter is in resistance test mode and it is showing something other than out of range when the probes are not touching, you have a defective multimeter.
            --- begin sig file ---
            --- end sig file ---
            • Kiriakos GR
              Banned
              • May 2012
              • 940
              • Greece
              Im thinking i got a bad multimeter though, sometimes it has readings when nothing is touching the probes. i think its gonna go back to Radioshack ultimately. Thanks everyone for helping me out.
              If you are talking about the mV range, this is normal, if you sort the probes and the reading become 0000 the meter is healthy .
              • corrize
                Small and robust multimeter probes
                by corrize
                Hello, I search a new probes for measuring pin of qfn and other very small stuffs. I bought the AE basics ones, but they are no longer sharp. Metal is bad. Do you have a stonger ones ?
                05-13-2023, 02:36 PM
              • magik20
                Wine Enthusiast 170 Bottle N'Finity Wine Cellar Model # 273 02 70
                by magik20
                I'm hoping someone might be able to offer some guidance on repairing a Wine Enthusiast N'finity 170 bottle wine cellar, model 273 02 70.
                I recently acquired this unit for free via Facebook Marketplace, hoping to fix it up as a gift for my wife. I have some basic electronic skills (comfortable with a multimeter, basic soldering, identifying components) but I'm definitely not an advanced technician.
                The main challenge is that when I picked up the unit, the main control/power board had already been removed and the previous owner said it needs a...
                04-30-2025, 04:46 PM
              • ClockChip
                Isopropyl alcohol as a cleaning agent?
                by ClockChip
                Hello All,
                I wanted to check with the board before I do anything foolish and/or irreversible. Can someone please set me straight on the use of isopropyl alcohol to clean electronics? I understand it is commonly used to clean electrical contacts. However, in this case, I am wondering if I can safely immerse a small electronic item in alcohol provided a) all power has been removed and b) I take care to dry it thoroughly before re-applying power.
                The short version is that I am seeking to clean an older used (well-used) electronic item. The basic plan is to immerse it in...
                03-16-2024, 12:10 PM
              • CapSnap123
                Radio Shack Digital Multimeter Cat # 22-811
                by CapSnap123
                I'm trying to fix a digital multimeter. It was working until I blew the fuse (actually the "buzz" for continuity wasn't working). I've now replaced the fuse but it's acting strangely. When I turn the dial to V, nothing happens. But when I turn to anything else, it makes a continuous, very fast clicking sound - like the piezo buzzer is trying to do something. And at each position of the dial (other than V) there are brief flashes of life on the LCD. It doesn't seem to matter if the probes are connected. I wasn't sure where to start, so I've tested most of the diodes and cleaned the...
                12-28-2024, 06:33 PM
              • digitalDNA
                MOSFET maintains voltage drop across G and S only for 3 seconds
                by digitalDNA
                While trying to fix an SMPS, I hear a ticking sound.
                I've checked all capacitors, but none seem to be shorted.
                I then suspected an issue with the flyback transformer which has 3 leads on the primary (used in a push-pull configuration ?) and one of them, which is always connected to GND has a resistance reading in the order of Mega ohms with any of the other 2 leads on the primary.
                But I thought let's check the MOSFETs first::
                The circuit also contains a PFC circuit, controlled by a UCC3818D (D stands for the SMD version),...
                10-11-2022, 11:00 AM
