Help Tektronix 466 repair advice
  • MDOC
    EngineeringTech
    • Mar 2010
    • 146
    Re: Help Tektronix 466 repair advice
    epicfatique
    The Tek 466 is discontinued product (long discontinued!), so don't waste your time calling TEK.
    • epicfatigue
      • Dec 2011
      • 68
      Originally posted by MDOC
      epicfatique
      Yeah i know i called them they had nothing to say about the model,
      i am currently waiting for my HV probe to come, once that arrives i will be able to check that side of things because i believe that is where the problem is lying at the moment.
      • twbranch
        Mad Nerd
        • Oct 2012
        • 153
        Join the TekScopes yahoo group. Those guys know a lot about the old tek scopes. They helped me with my 453.
        • twbranch
          Mad Nerd
          • Oct 2012
          • 153
          Originally posted by epicfatigue
          Kirakos please keep the thread crapping to a pm mate.
          Wanna get this thing fixed not turn it into a war between people.
          Hurling abuse at someone you cant wrap your hands around is a waste of time. I understand this will throw it out of calibration but once its working my work has one i can use to re adjust it, however no one there knows how to use it.
          Anything you can contribute is a big help and i do take everything on board, and it is all appreciated. If i didn't have a family to support i would love to do this as a trade however as we all know life is not always as we would like it to be and i have missed the boat.
          best thing to do with that guy is add him to your ignore list or you will put with that constantly! not tryin to hijack just lettin gyou know
            You have already learnt a lot about troubleshooting this scope, nothing wrong with fixing, learning and develop logical thinking at the same time. When you have good foundation in troubleshooting, it will be real good knowledge to have for the future. So keep on learning.
            • epicfatigue
              • Dec 2011
              • 68
              #26
              Thanks all,
              Its good to know i am not wasting my time, everything in life i learn thus far has been from the ground up and i have always came out better for it.
              Once i have the unit working i was going to buy a signal generator to recal it myself.
              Iv joined the Tek group just need some better equipment i am waiting on some resistors in the mail to build my HV probe,
              Just a simple voltage divider.
              While i was waiting i have been building my variable Power supply,
              Has 4 fixed voltages and 2 variable voltages.
              Also has two different variable voltages controlled by a switch.
              0.5-30V 20amp
              0.5-30V 3amp
              I am just waiting on the double gang pots and my switch to come before drilling the holes in the face plate.
              I made the box so big that it would actually use less space so i could sit my test TV on it.
              Fixed +32V 20 amp
              Fixed -32V 3amp
              These are on two different rails so are isolated from each-other.
              Fixed +18V 20 amp
              Fixed -18V 3amp
              • epicfatigue
                • Dec 2011
                • 68
                #27
                Hey Everyone,
                Post was slow, i finished my HV probe it worked perfectly.
                I did a test before i took the measurements on a lower voltage to ensure the
                divider worked and it did!.
                Sure enough on reduced scan i am getting my near normal operating voltages and on
                normal i am getting well below.
                -----------------Expected-------------------------------------
                TP1501 -3010 Reduced Scan
                TP1501 -1470 Full scan
                ------------------RESULT-------------------------------------
                TP1501 -1702v Reduced Scan
                TP1501 -369v Full scan
                Q1472 Base = Reduced Scan 0.520
                Q1472 Base = Full SCAN 0.460
                Q1492 Base = -7.92 Reduced Scan
                Q1492 Base = -7.92 Full scan
                Q1496 Base = 18.38v Reduced Scan
                Q1496 Base = 18.38v Full scan
                • Jidis
                  Need T-Con Advice (Vizio P602ui-B3)
                  by Jidis
                  I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                  He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                  09-22-2025, 05:10 PM
                • zlr8r
                  Advice on newer EC chip programming eg. MEC5107-LJ BGA
                  by zlr8r
                  Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
                  i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
                  09-16-2025, 09:54 AM
                • Borse2008
                  by Borse2008
                  • There’s
                  07-15-2025, 04:55 AM
                • Green Probe
                  Mosfet Advice
                  by Green Probe
                  Hi, Im looking to replace some EMP21N03 mosfets on an Alienware motherboard, but I'm having trouble finding a legit supplier. The ones that are available from China have pictures with the engraved logo looking very scratchy and sketchy. Nobody in the US sells them. I'm trying to find a compatible mosfet, but I'm not well versed enough to be confident im making the right choice. Does anyone have a suggestion or advice that could help me find the right mosfet? Thanks!
                  05-22-2025, 10:49 AM
                • user234
                  Gigabyte Eagle 3060 Ti - Boardview / Advice request please
                  by user234
                  Recently installed a new motherboard but during the process I seemed to have damaged my Gigabyte Eagle 3060 Ti card.
                  My motherboard ROG STRIX B550-A is detecting an issue with the VGA (light ON)
                  I have attached 2 photo's of my GPU board, one above and the other is what I believe to be the 5V - as you can see, this has visual damage so looks suspicious to me.
                  If I replace this part what are the odds this will resolve the issue? - any additional information on where to source the parts would be much apricated too!
                  This is...
                  05-10-2025, 04:25 AM
