Just got an oscilloscope...
  • Tom41
    • Oct 2005
    • 336
    • England
    And I was wondering if you lot have any tips or suggestions as to how I can use it to measure ripple current. I mainly want to use it to check the output of PSUs, both unloaded and under load, and see if the ripple is bad.
    I know that most PSUs do have a small amount of ripple, but how much is too much? So far I've measured a PC laptop PSU, and an Apple iBook PSU, both of which have some ripple. The PC laptop PSU seems to be a constant amount of ripple, but the iBook PSU has the ripple changing randomly! There also seems to be some interference creeping along the line on the scope when I measure that PSU - perhaps the PSU is going bad?
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • bob8701
    • Aug 2006
    Re: Just got an oscilloscope...
    trigger by dc line, because ripple is related with ac frequency harmonic. by the way you need a load for power supply test.
    • chth96
      Is it no harm to replace with capacitor without ripple current rating?
      by chth96
      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
      Rubycon YK DataSheet (b...
      04-19-2024, 05:19 AM
    • Antonynl
      What are typical ripple voltages on a laptop motherboard?
      by Antonynl
      I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
      So I have two questions:
      1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
      2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
      Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
      12-09-2022, 06:51 AM
    • Tarot Superstars
      How not to Damage an Oscilloscope
      by Tarot Superstars
      Hello.
      I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
      I want to learn how not to damage it, and I found instructions on the internet obscure.
      They talk about ground, earth, floating ground, this, that....
      But they don't actually say anything anything useful so far.
      I want to know:
      Don't connect exactly this to exactly there or it blows up.
      For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
      I want to know what not to connect...
      08-29-2023, 02:27 PM
    • AJ847.63e
      Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
      by AJ847.63e
      Hi Folks,
      Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
      I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
      The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
      05-06-2025, 10:37 PM
    • Ady2017
      Is there a manufacturers tolerance for ripple?
      by Ady2017
      Hi all
      I need to replace a 680uF 35V SamYoung NXB cap which has got a ripple of 1820. Whilst passing my local little electronics shop I picked up what they had in stock which was a 680uF 35V Panasonic FC with a ripple of 1655.
      As the ripple rating is only 9% below what the original was I am wondering whether to risk it and fit it.
      The catalogues specify a capacitance tolerance of +/-20% but state nothing about the ripple. If there is a similar tolerance for ripple then I might be worrying about nothing. Does anybody know?
      11-13-2021, 11:46 AM
