Help! Small solder joints.
  • ajcox1234
    • Feb 2011
    • 57
    I have an ASUS motherboard with 2 bad capacitors, I have replacements but the joints are very small, my desoldering braid won't remove the solder. What else can I use to desolder the bad capacitors?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Help! Small solder joints.
    Add some 60/40 solder to the joint first.
    --- begin sig file ---
    --- end sig file ---
    • ajcox1234
      • Feb 2011
      • 57
      Can I use my 100w Weller or should I use my 45w Radioshack iron with a chisel tip?
      • mockingbird
        • Dec 2008
        • 5484
        I try to wick the pads on these boards, so I know how you feel. 3/4 of the time, it won't completely wick, especially if the pad is near something that absorbs a lot of heat, like a copper coil or a grounding plane.
        What you will have to end up doing is trying to coax the cap in while holding the iron to the pad. Be careful not to rip up the pad. If you do, you may as well toss out the board unless the lead has attached to the via (I think you can test this with a multimeter).
        Of course use the 100w.. It's not wicking with the 100w!? I thought the reason it wouldn't wick for me was because I use a 25w.
        • retiredcaps
          • Apr 2010
          • 9271
          I would use the latter. Add some 60/40 solder to joints. Then heat up the same joints while pulling/rocking on the cap from the other side.
          Once the cap is loose, heat up a stainless steel sewing needle from the backside and push until it clears the hole. I just switched to this method from a solder sucker and it is way easier.
          • mockingbird
            • Dec 2008
            • 5484
            I'm not able to clear holes with a sewing needle. It just gets stuck in there.
            • ajcox1234
              • Feb 2011
              • 57
              Thanks. I'll get some 60/40 to make the joints bigger, then use the wick to remove the rest of the solder and remove the bulging Ltec's.
              • ajcox1234
                • Feb 2011
                • 57
                Looking on the Radioshack site, I found a nice desoldering iron. I've decided to buy one of those on Friday, with some 60/40 Rosin Core solder to desolder the old Ltec's and solder in the new Rubycon MBZ's.
                • barry wilkins
                  • Aug 2009
                  • 172
                  A good quality flux will help because it allows the heat to melt the solder.Manufacturers of electronic PCBs seem to make the PTH,s very small so components are a tight fit. If the capacitors are defintely going to be replaced you could always cut them off the board and take the pins out the board.
                  Barry Wilkins
                    master hoarder
                    • May 2008
                    • 12170
                    Another thing you can do is pre-heat the board. I have a sub $20 heat gun for this that works great - I just blast the area of the board below the caps for 10-20 seconds or so and then use the soldering iron to heat the pads one by one on each cap and then wiggle the cap out. If you don't have a heat gun, a hair dryer will can also work okay - you'll just need to heat the board for a bit longer.
                    Flux and/or 60/40 lead solder is also very helpful.
                    In any case, don't be afraid that you'll burn the board with your soldering iron - you very likely won't. Keeping the iron on a joint for 10 seconds or more is usually not fatal.
                    Lastly, make sure the tip of your iron is clean and well tightened.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4951
                      • New Zealand
                      I've struggled with some boards, with a 60 watt digital soldering station and even an 80 watt desoldering gun I borrowed, and after research and a bit of testing I have come to the conclusion that some boards (or some areas on the boards) are really only easy to work on with pre-heating.
                      -David VanHorn
                      • ajcox1234
                        • Feb 2011
                        • 57
                        I haven't tried desoldering or soldering on it yet. I will tomorrow once I get the 45w desoldering iron. I got my Rubycon MBZ's today, I ordered 8, and I got 12! Score! Thanks eBay! And they're not Rulycon fakes either!
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4951
                          • New Zealand
                          Unfortunately just because they don't say Rulycon doesn't mean they're not fake.
                          eBay is a big haven for fake capacitors. The fact they gave you more than you ordered seems suspicious to me - why would a legit seller with a genuine product give you more than you paid for unless by accident?
                          Who did you buy them off?
                          -David VanHorn
                          • ajcox1234
                            • Feb 2011
                            • 57
                            I bought them from here http://myworld.ebay.com/ny-electroni...id=p4340.l2559
                            They all have the same date code, 0524. The bung in all of them look the same, as well as the vent. They don't look fake to me, and I've seen a lot of MBZ's.
                            • mockingbird
                              • Dec 2008
                              • 5484
                              Yea, I'm pretty sure their stuff is legit. Did you order only two? Why not re-cap the whole board?
                              • ajcox1234
                                • Feb 2011
                                • 57
                                It was an 8 piece set. No reason to, none of the other capacitors are bloated. They're OST (I know they're a bad brand, but if you keep them cool, they'll be fine), and UCC KZG (They don't like heat either, but I keep at computer pretty cool, so I won't replace the rest of the capacitors unless they bulge.
                                • mockingbird
                                  • Dec 2008
                                  • 5484
                                  OST and KZG don't always bulge... You should have replaced them.
                                  • ajcox1234
                                    • Feb 2011
                                    • 57
                                    I've ran small FFT's on it in Prime95 for about 2 hours and 30 minutes now, still going strong.
                                    • ajcox1234
                                      • Feb 2011
                                      • 57
                                      Recapped the board tonight, was a pain in the a$$, thought I killed the board, but it's booted up and playing a YouTube video as I type this. I'm never soldering on an ASUS motherboard, ever again. lol.
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        It is not just ASUS. Pretty much all motherboards are multilayer and the copper planes suck up all the heat from the iron tip making it hard to desolder. Having a clean tip, flux, 60/40 solder, and the correct tip helps alot. A chisel tip is good for desoldering. The sharp conical tips don't have a lot of surface area for heat transfer.
                                        • jm1234
                                          Solder joints on heat sinks matter?
                                          by jm1234
                                          solder joints on heat sinks - how much do they matter? Could poor joints on heat sink cause issues if they are not properly joining to hot ground?
                                          I'm looking at power source module of Panasonic plasma TV and I see many of these having visually poor quality, but could they matter? In general I would guess no, but I saw a video where someone was stressing out the importance of tightening the screws when fastening the power source board specifically for the ground to be connected properly.
                                          04-28-2024, 04:38 AM
                                          HP 280 G2 Small Form Factor PC i3-6100 Specification for Upgrade or Repair
                                          This specification for the HP 280 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 280 G2 Small Form Factor PC boardview and 280 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 03:44 PM
                                          HP ProDesk ProDesk 600 G2 Small Form Factor PC ProDesk 600 i5-6500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk ProDesk 600 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Small Form Factor PC boardview and ProDesk ProDesk 600 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 03:36 PM
                                          HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i5-4570 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                          09-12-2024, 03:28 PM
