Help! Small solder joints.
  • ajcox1234
    replied
    Re: Help! Small solder joints.
    Here's the link to the new board. If you look closely at the picture in the body of the listing, you can see some Nichicon model numbers. HM, HN, HD, etc. The polymer capacitors are Sanyo's, it has a few KZG's in it, but KZG's just don't like heat. This board has 6, and it's 8 years old and they're still working. I believe that they'll be just fine. http://www.ebay.com/itm/270925234344...ht_6588wt_1044
  • ajcox1234
    replied
    I know, but it has OST's all over the board. I found another one on eBay with Nichicon and Rubycon capacitors on it.
  • Agent24
    replied
    If yours works now with new capacitors it should be just fine...
  • ajcox1234
    replied
    Found a board on eBay with all Panny's... I may buy that one, and replace the whole board.
  • ajcox1234
    replied
    I'm not taking it out of the case again. It's working perfect now, Prime95 will run for hours. The new capacitors seem to be working fine, as the system is perfectly stable. I'm typing this on it right now.
  • Agent24
    replied
    If you can post a photo of the joints, it might give clues as to why they look bad.
  • ajcox1234
    replied
    Desoldering wasn't a problem, soldering the new caps in was hard, the solder looks terrible on the new joints, but they do work. I've put pressure on them, the joints are secure, just not good looking, at all. The Dell Dimension 3000 I recapped from a bad Nichicon HN (2005 date code) with a Rubycon MCZ 10v 1000uF took solder really really well. I thought I killed that ASUS, it amazed me that it POST'd when I pressed the power button.
  • Agent24
    replied
    Preheating definitely helps.
  • retiredcaps
    replied
    Originally posted by ajcox1234
    I'm never soldering on an ASUS motherboard, ever again. lol.
    It is not just ASUS. Pretty much all motherboards are multilayer and the copper planes suck up all the heat from the iron tip making it hard to desolder. Having a clean tip, flux, 60/40 solder, and the correct tip helps alot. A chisel tip is good for desoldering. The sharp conical tips don't have a lot of surface area for heat transfer.
  • ajcox1234
    replied
    Recapped the board tonight, was a pain in the a$$, thought I killed the board, but it's booted up and playing a YouTube video as I type this. I'm never soldering on an ASUS motherboard, ever again. lol.
  • ajcox1234
    replied
    I've ran small FFT's on it in Prime95 for about 2 hours and 30 minutes now, still going strong.
  • mockingbird
    replied
    They're OST (I know they're a bad brand, but if you keep them cool, they'll be fine), and UCC KZG (They don't like heat either, but I keep at computer pretty cool, so I won't replace the rest of the capacitors unless they bulge.
    OST and KZG don't always bulge... You should have replaced them.
  • ajcox1234
    replied
    It was an 8 piece set. No reason to, none of the other capacitors are bloated. They're OST (I know they're a bad brand, but if you keep them cool, they'll be fine), and UCC KZG (They don't like heat either, but I keep at computer pretty cool, so I won't replace the rest of the capacitors unless they bulge.
  • mockingbird
    replied
    Yea, I'm pretty sure their stuff is legit. Did you order only two? Why not re-cap the whole board?
  • ajcox1234
    replied
    I bought them from here http://myworld.ebay.com/ny-electroni...id=p4340.l2559
    They all have the same date code, 0524. The bung in all of them look the same, as well as the vent. They don't look fake to me, and I've seen a lot of MBZ's.
  • Agent24
    replied
    Unfortunately just because they don't say Rulycon doesn't mean they're not fake.
    eBay is a big haven for fake capacitors. The fact they gave you more than you ordered seems suspicious to me - why would a legit seller with a genuine product give you more than you paid for unless by accident?
    Who did you buy them off?
  • ajcox1234
    replied
    I haven't tried desoldering or soldering on it yet. I will tomorrow once I get the 45w desoldering iron. I got my Rubycon MBZ's today, I ordered 8, and I got 12! Score! Thanks eBay! And they're not Rulycon fakes either!
  • Agent24
    replied
    I've struggled with some boards, with a 60 watt digital soldering station and even an 80 watt desoldering gun I borrowed, and after research and a bit of testing I have come to the conclusion that some boards (or some areas on the boards) are really only easy to work on with pre-heating.
    replied
    Another thing you can do is pre-heat the board. I have a sub $20 heat gun for this that works great - I just blast the area of the board below the caps for 10-20 seconds or so and then use the soldering iron to heat the pads one by one on each cap and then wiggle the cap out. If you don't have a heat gun, a hair dryer will can also work okay - you'll just need to heat the board for a bit longer.
    Flux and/or 60/40 lead solder is also very helpful.
    In any case, don't be afraid that you'll burn the board with your soldering iron - you very likely won't. Keeping the iron on a joint for 10 seconds or more is usually not fatal.
    Lastly, make sure the tip of your iron is clean and well tightened.
  • barry wilkins
    replied
    A good quality flux will help because it allows the heat to melt the solder.Manufacturers of electronic PCBs seem to make the PTH,s very small so components are a tight fit. If the capacitors are defintely going to be replaced you could always cut them off the board and take the pins out the board.
    Barry Wilkins
  • jm1234
    Solder joints on heat sinks matter?
    by jm1234
    solder joints on heat sinks - how much do they matter? Could poor joints on heat sink cause issues if they are not properly joining to hot ground?
    I'm looking at power source module of Panasonic plasma TV and I see many of these having visually poor quality, but could they matter? In general I would guess no, but I saw a video where someone was stressing out the importance of tightening the screws when fastening the power source board specifically for the ground to be connected properly.
    04-28-2024, 04:38 AM
    HP 280 G2 Small Form Factor PC i3-6100 Specification for Upgrade or Repair
    This specification for the HP 280 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 280 G2 Small Form Factor PC boardview and 280 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-12-2024, 03:44 PM
    HP ProDesk ProDesk 600 G2 Small Form Factor PC ProDesk 600 i5-6500 Specification for Upgrade or Repair
    This specification for the HP ProDesk ProDesk 600 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Small Form Factor PC boardview and ProDesk ProDesk 600 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-12-2024, 03:36 PM
    HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i3-4130 Specification for Upgrade or Repair
    This specification for the HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
    09-12-2024, 03:28 PM
