Resistance soldering anyone?
  • mariushm
    • May 2011
    • 3799
    I was thinking how hard would it be to make some kind of laser soldering machine by re-purposing a bluray laser diode and realized it would be pretty hard to control the temperature with a home made machine.
    Browsing the Youtube videos and admiring the laser soldering machine "hardware porn" I stumbled onto a resistance soldering video for an American Beauty soldering machine that uses some tweezer system to solder using resistance:
    http://www.youtube.com/watch?feature...&v=sn63FOWqesk
    This thing is expensive at 479$ but other than the tweezers it seems to be just a 100 watt transformer with voltage control.
    I've found even some pdf files where people showed how they made one using a car battery charger (12v 5-10 amps) and some foot pedal and regular carbon rods.
    edit: the document i mention is here: https://cdn.badcaps-static.com/pdfs/...ee11818840.pdf
    Now my questions are these...
    * has any of you worked with something like this? Are they as easy as they seem to be?
    * how safe are to use with some of these smaller diameter holes on PCBs? And especially how safe is to warm up the pins of capacitors or resistors and so on?
    They say the heat is very centralized unlike regular soldering techniques but it seems to me there's a higher chance to accidentally raise the heat to some ridiculous temperatures.
    I'm especially puzzled a bit about how it would produce quality soldering because all I've learned so far says both metal parts should be heated and then fed solder to create a good welding but using this method I'd only heat both surfaces if I somehow press one onto the other with the tweezers.
    Seems a bit hard to put pressure under magnifying glass and at the same time be careful about how much it heats and so on.
    Thanks in advance for any clarification you more experienced guys can give me.
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    Re: Resistance soldering anyone?
    I personally think I could do better with a regular iron for thru hole or hot air for SMD work.
    • severach
      • Aug 2007
      • 1055
      Resistance soldering is usually avoided for electronics because the current could pass through the board or part leads and damage semiconductors. It works fine for high current devices where a little current can't hurt anything or jewelry where stray heat from an iron would damage the finish. Soldering the resistor would be fine so long as the semiconductors were unpopulated.
      I don't like it because it's an expensive device that does much less for electronics than a lower cost hot air gun. I can desolder and resolder a 128 PQFP with hot air. I would need to use one to see how well the tip maintains its ability to conduct in a dirty solder environment.
      All the Youtube examples I've seen so far are with high current tolerant applications or unpopulated boards and in all those examples hot air assist would have been my first choice.
      Not that resistance soldering is bad but I wouldn't get one until the need arises.
      sig files are for morons
      • Agent24
        I see dead caps
        • Oct 2007
        • 4950
        • New Zealand
        Without reading the links this sounds like one of those "cold heat" irons.
        Basically a miniature spot welder I think, and not good for PCB work at all.
        Even if you ignore the fact that the voltage can kill your parts, the joint will be crap (think: cold heat = cold joint)
        Good article here: http://www.epemag.wimborne.co.uk/cold-soldering.htm
        Or the conclusion if you're lazy: http://www.epemag.wimborne.co.uk/cold-soldering2.htm
        No, I say keep your traditional iron, and if you want to spend money, spend it on a better iron.
        If you want to do SMD without hot air, research 'drag soldering'
        -David VanHorn
        • CG2
          Janome DC3050 Sewing Machine Pedal Resistance
          by CG2
          OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
          Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
          04-14-2023, 07:53 AM
        • cind12
          GTX 1080 TI Gigabyte Aorus low resistance on vmem
          by cind12
          Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
          Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
          The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
          Resistance on 12V 4K ohms (Power present when on)
          Resistance on 12V PEX 4K ohms...
          12-08-2023, 09:09 AM
          Building a Laser / Spindle Engraving Machine very challenging
          I have been trying to build this engraving machine for last few months it has very challenging to get the part together
          I had bought a very small engraving machine a few years and it sat in the box it came in because I could not find a reasonable priced laser controller and the same thing about the the motor controller ( plus the table was to small for what I want to do with it )
          I have some challenges about the machine controller as well because I want an offline function so I can run the project with out having a computer hooked to machine controller
          09-27-2020, 04:43 PM
          ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
          This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-12-2024, 03:28 PM
        • Nagy Daniel
          Lowest possible resistance on laptop motherboard rail - Guide Table request
          by Nagy Daniel
          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
          So, I generated a table with AI so I can...
          03-04-2025, 08:24 AM
