ESD safe with no ground at the outlet?
  • mathog
    • Mar 2010
    • 2655
    Our house was built in the 50's and most of the outlets are not grounded. The walls are plaster so running ground wires into the outlet boxes would be a heck of a lot of work. The outlets have mostly been changed to three prong GFCI, but the ground hole is not connected to anything, as there is no ground wire in the boxes. This wasn't a problem with my previous soldering irons, all two prong, but I'm going to buy an ESD one, and presumably those must use three prong cords. (And I do want it to remain ESD safe.)
    The options that come to mind are:
    1. run a long extension cord to one of the kitchen or bathroom outlets.
    2. fake a ground by modifying a short extension cord, connecting ground to common.
    Neither is very attractive. I really don't want a long cord attached to a live soldering station, lest somebody give it a good kick and drop a hot iron on the floor. The other one, well, yuck.
    Anybody have a better solution? (And no, moving is not an option.)
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: ESD safe with no ground at the outlet?
    Wire it to the room heater... If the house is old it doesn't have PVC pipe hence it is a big earthed piece of metal.
    A working TV? How boring!
    • mathog
      • Mar 2010
      • 2655
      Room heater? Do you mean a hot water radiator? I don't recall ever seeing one of those in California. We have a central furnace (natural gas) with air ducts. The ducts have some foil in them but I doubt they would work as a ground. There are iron water pipes under the floor, however getting to them is not so easy (plaster walls). In any case, under the current US electrical code outlets are not supposed to be grounded that way. Even running a ground wire to an outlet separate from the other two wires is not code compliant, all 3 conductors are supposed to be within the same sheath.
      Short of spending a lot of money to rewire the house, a temporary solution, employed only for the ESD work, will have to do.
      • wirenut
        • Mar 2011
        • usa
        Actually according to the nec you can run a grounding wire to a cold water pipe, or if your grounding is up to date any non gas metal pipe. If your near a kitchen or bathroom(cold water pipe) or can fish a wire (minimum 14 awg)to basement or crawl space(cold water pipe or main service box) and connect it to the box AND gfi then you will be grounded and conform to the code. You will need to make sure there isn't a dielectric coupling (usually used to connect galvanized pipe to copper to eliminate corrosion from dissimilar metals) and that no pvc pipe or pex pipe has been used, and use a grounding pipe clamp like those used for grounding the main service, if you opt for a water line.
        • PlainBill
          • Feb 2009
          • 7034
          Here's a few ideas, free and worth every penny of it.
          If the outlet is on an outside wall dig a trench and run 14GA UF cable (rated for direct burial) from the outlet location back to the breaker box. Run it inside PVC conduit anywhere there is danger of someone digging. Also run it inside PVC conduit up the outside of the house to the outlet box.
          Run the cable through the attic and down inside an inside wall. Install a new outlet box for the new outlet, don't try to reuse the old one.
          I've run electrical cable in older homes by pulling the baseboard, knocking a hole in the plaster below the baseboard level and drilling holes through the studs.
          The 'Do It Yourself' reference for these projects is Richter's 'Wiring Simplified', it costs about $8.00. The heavy version is 'Practical Electrical Wiring'. I don't know the rules where you are, but it may be worthwhile to talk to the electrical inspector for your area.
          PlainBill
          • tvguy12012012120
            by tvguy12012012120
            02-07-2025, 05:13 PM
          • EasyGoing1
            Question on AC grounding - found an old device that has me confused
            by EasyGoing1
            So I needed to find something that I don't use so I could cut the power cord off of it and use it in a project.
            So I found this ... Radio Shack looking device that apparently takes an external TV antenna as an input as well as RCA connections as inputs Then on the front you can choose to have it send out to the TV on channel 3 or 4 - though I have no idea what it does with the two different inputs...
            But anyway, I figured before I cut the cord and toss the device in the trash, I should bust it open and see if there's anything useful inside to add to the spare parts...
            02-14-2021, 06:17 AM
          • mkdj
            Acer TravelMate P214 - N19Q7 main power rail shorted to ground
            by mkdj
            Dear all,
            I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
            I have checked resistance across each of the 4 MOSFETS. I have the following readings:
            Both N-Channel Mosfets: nothing odd
            P-Channel MOSFET number 1:
            source - drain : 117 kOhm
            source - gate: 96 Ohm
            gate - drain: 117 kOhm
            P-Channel MOSFET...
            08-20-2025, 06:08 AM
          • barry101
            Apple 820-3662 VCore shorted to ground.
            by barry101
            Hi, Would appreciate some help.
            I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
            Get charger light but no fan spin or chime. No liquid damage.
            Found PPBUS and VCORE both shorted to ground. Other rails were ok.
            Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
            With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
            Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
            06-24-2025, 07:34 AM
          • Chaks
            Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
            by Chaks
            TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
            The specs says ...
            High antenna efficiency 868MHz ISM Band
            5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
            The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
            1. Should I Fix it with a glue.
            2. Should I fix it with a double side adhesive tape
            3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
            12-09-2024, 11:06 AM
