Isolation Transformer...DIY or DIE?
  • romansroad
    • 123
    We're in the process of moving and I can't find my isolation transformer (as well as my variac and the left half of my brain). Anyway, in Alfred P. Morgan's "Boy Book of Electricity", published around, oh, 1929, I recall a picture of two transformers with identical secondaries being connected to create an isolation transformer of sorts. Here's my crazy, cheap idea. (Keep in mind the already established frugal Scottish heritage).
    I have UPS's sitting around that people threw out because the 12v battery was more $$ than a new power supply. I saved them (like everything else!) planning to use the power components for something. What about connecting them back to back? I know there might be some voltage loss, and I haven't had a look at the secondaries, but they do put out some current when backing up the PC's. I have built a resistance soldering unit using a microwave transformer, and it works great. Rewound the secondary with taps for my voltages and it makes serious current flow. Actually miscalculated on the size of the working leads as they did get a bit warm even with 8 gauge...but that's another story....
    So, will this be an episode of Home Improvment where my wife is calling 911 or is the newly dubbed "Tartan Tranformer" possible?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Isolation Transformer...DIY or DIE?
    Two UPS transformers back to back should do. PSUs are stressed more when the line voltage is lower, so it may actually be a good idea to do it like this.
    A working TV? How boring!
    • harp
      isolation transformer from two 240/12, wiring?
      by harp
      When is talk about making isolation transformer on poor-man way, always I see schematic 240/12-12/240.
      So, I wonder, is this wiring from my attachment it work, bringing some good feature or it is bad idea and why?...
      11-25-2022, 05:11 PM
    • ohren
      Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
      by ohren
      Hello!
      I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
      Measured voltages with no load:
      After rectifier diodes
      12V: 6.17 V
      5V: 5.67 V
      Secondary transformer pins AC measurement (really don't know if this says anything)
      12V: 2-2.5 V
      5V: 1.04 V
      I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
      03-18-2023, 10:33 AM
    • mikey5791
      Is it possible for transformer substitution?
      by mikey5791
      Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
      Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
      My questions are
      1. How do i test to see if the transformer is in good working condition?
      2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
      Hope you guys understand what i was asking. My intention is...
      11-03-2022, 02:11 AM
    • dennis_elx33
      3PHASE STEP-DOWN Transformer in Check
      by dennis_elx33
      Hello All,
      i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
      Problem statement: Power tripped Off
      Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
      Action Done:
      1) Replaced the faulty parts with good spare.
      2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
      12-02-2024, 06:52 AM
      ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
      This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
      09-06-2024, 04:40 PM
