X390 Yoga nuvoton
  • jacksomething
    • Jun 2021
    • 10
    • United Kingdom
    X390 Yoga nuvoton
    I am new to this forum and I already apologize for my english! I spent some time trying to find a solution to unblock a lenovo thinkpad x390 Yoga, which probably has, according to a diagram I found online, a NPCE388 Embedded Controller. I don't know much about laptop hardware but whith your help I could maybe manage to do it! In an other thread AAAC wrote:
    "Or if you have an EC/KBC programmer you can READ, ERASE and PROGRAM EC/KBC, disconnect all source of energy for 1-2 minutes, then reconnect and use Lenovo Maintenance Utilities (UEFI version) to enter Model Number, Serial Number and other data.
    As far as I know ThinkPad X390 has NUVOTON embedded controller, so you may be able to program it using keyboard connector on motherboard." (https://www.badcaps.net/forum/showth...=87588&page=26)
    So here are the steps I think I should follow, tell me if that is correct.
    -disconnect the battery and the CMOS battery
    -connect the embeded controller to a programmer via the FPC keyboard connector
    -read and dump the EC, save it in case something goes wrong to come backe to the previous BIOS.
    -erase everything on the EC
    -write the EC with a new bios with the "bios update utility" (is it a .bin file?) from lenovo x390 Yoga (https://www.lenovodrivers.download/l...-yoga-drivers/)
    -boot with Lenovo Maintenance Utilities (UEFI version) to enter Model Number, Serial Number, etc. (where can I download this bootable image and where to find the serial number when the label is unreadable on the back of the laptop?)
    In the manual of the laptop, it's written that if the password is lost, we should replace the motherboard... so do you know if this method is working? Do someone have any experience with unlocking an thinkpad x390 Yoga? I think that your answers could also be helpful for other people facing the same problem on this forum.
    Thank you very much for your help!
    PS: the thinkpad x390 and x390 YOGA are not the same, for example they don't have the same embedded controller.
    Here are the links to the diagram of the thinkpad x390 Yoga.
    and also this link for a more detailed diagram of the different parts https://www.scribd.com/embeds/505887...ntRav5tlToCCWR
  • rifmann
    • Feb 2019
    • 37
    • europe
    X390 Yoga nuvoton
    no solution for Lenovo X390 Yoga ?
    nuvoton chip
    • Anthon87
      • Jun 2021
      • 2
      • Spain
      Re: X390 Yoga nuvoton
      I'm interested as well
      • jacksomething
        • Jun 2021
        • 10
        • United Kingdom
        I found a complete detailed shematics of the laptop.
        I also post the Lenovo maintenance utility (bootable) file.
        I notice that in an other thread some people managed to unlock a lenovo thinkpad t490, which is also a 9th generation lenovo laptop (although it has an MEC1663 EC and not an NPCE388 like the x390 yoga) , see https://www.badcaps.net/forum/showthread.php?p=1048073
        Hope that someone with more knowledge can help!
        Thank you!
        • jacksomething
          • Jun 2021
          • 10
          • United Kingdom
          The detailed schematics that has been mentioned on the previous post can be found here: https://www.badcaps.net/forum/showthread.php?t=96612
          (my last post was edited because there is a specific "Schematic Requests ONLY!" section to post schematics)
          • black0hackers
            • Jul 2020
            • 369
            this one one P1
            • jacksomething
              • Jun 2021
              • 10
              • United Kingdom
              any solution?
              • cgtec
                • Feb 2014
                • 56
                • France
                Originally posted by black0hackers
                this one one P1
                to read it need jtag ...
                • black0hackers
                  • Jul 2020
                  • 369
                  for x390 yoga nuvoton how to read
                  nuvoton NPCE388PB0BX
                  • TopMan007
                    • Dec 2020
                    • 8
                    • Czechia
                    Use Vertyanov (ideally Original not clones) software 8.2.x on forum not 7.x as this has limitation for 128kB files... 8.2 test version reads bigger dumps (256kB)...
                    Settings for Nuvoton
                    LBB-1 KB_pins=32 LEFT DOWN 05MM FLASH=256 JENK=13 TCK=7 TMS=18 TDI=22 TDO=4 (tested kinoxa)
                    • electronica
                      • Apr 2014
                      • 88
                      • algeria
                      use svod3 programmer . dont need to disassemble the laptop just use the keyboard connector to read the EC firmware . then program with new fresh firmware you find it in the bios update from lenovo website. the laptops with npce microcontroller ar very easy to unlock with svod
                      • jawal37
                        • Feb 2013
                        • 41
                        • afric
                        thinks for this
                        unlock good x390 youga
                        • black0hackers
                          • Jul 2020
                          • 369
                          But how to read?
                          • keczuk
                            • Dec 2019
                            • 84
                            • WWW
                            Pinout for LBB-2 motherboard X13 Yoga gen 1 ? from LBB-1 not working. in both schematic show will be same.
                            • dav_br
                              • Jan 2022
                              • 1
                              What type of hardware can I use to read from EC chip using keyboard connector?
                              • peste
                                • Dec 2016
                                • 13661
                                • ROMANIA
                                it depends on what programmer you have ... the software comes on CD, once you receive the programmer ... what programmer do you have ???
                                • radicalsolutions
                                  • May 2020
                                  • 14
                                  • www
                                  Well, with my vertyanov 4.0 36 pin kb connector, i had to use
                                  LBB-X KB_pins=32 LEFT DOWN 05MM FLASH=256 JENK=20 TCK=26 TMS=15 TDI=11 TDO=29
                                  • mohammad faisal
                                    • Apr 2015
                                    • 9
                                    • pakistan
                                    i need yoga x390 novaton ec 256kb file
                                    • joby91
                                      • Sep 2018
                                      • 43
                                      • german
                                      i also need the ec dump. Can someone share?
                                      • Stefan Steff
                                        • Mar 2024
                                        • 369
                                        • Romania
                                        Try with this EC dump...Give a feedback please
                                        • Maxpower3
                                          Brand name and Model Type for Lenovo error 2202 product name is invalid
                                          by Maxpower3
                                          Info for error 2202 LenovoThinkPad models and type
                                          Extract from ThinkPad Maintenance Utilities Configuration File
                                          plnsrv.ini Version 1.01
                                          Some information that may be useful
                                          There must also be missing models, add them to the list if you know of any.
                                          Code:
                                          brand name
                                          20B1=ThinkPad Edge E445
                                          20B2=ThinkPad Edge E545
                                          20BC=ThinkPad Edge E145
                                          20BM=ThinkPad X140e
                                          20BL=ThinkPad X140e
                                          20A3=ThinkPad X230s
                                          20AH=ThinkPad X230s
                                          20AK=ThinkPad X240s
                                          20AJ=ThinkPad X240s
                                          02-21-2024, 10:27 AM
                                          Lenovo ThinkPad X390 Yoga Hybrid (2-in-1) X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X390 Yoga Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X390 Yoga boardview and X390 Yoga schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 03:30 PM
                                          09-06-2024, 02:30 PM
