LG 60PA6500 EBR73712701 SMD resistor help
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Hi, I need help with a resistor that was blackened and measuring a non standard value desoldered(around 7k OHMs), R513 on the picture, online I could only find a picture on shopjimmy that was really high res but still hard to make out what it was, ended up soldering a 2R2 since it looked like that in the picture, the TV powered on but the image was poorly sustained, same symptom as before.
    I don't want to damage this board because it is expensive, so I won't try to turn it on until I have the right resistor.
    Whole history of the TV: Bad upper buffer board, shorted, someone else messed up Z and Y boards with some garbage soldering job and replaced the caps on Y board with shitty ones, that's taken care of, no shorts on any P105 optocoupler or IGBTs, no other open resistors.
    If someone has this board please can you tell me what value is R531, that close up zoom photo is my board.
  • R_J
    • Jun 2012
    • 9556
    Re: LG 60PA6500 EBR73712701 SMD resistor help
    That 2R2 value seems very low, what is the ic number? It looks like there are other similar ic's on that board, what is the value of that same resistor?
    I would guess the value from the picture as 272 (2.7k)
    • Biruslapio
      • Nov 2013
      • 552
      • Brasil
      The IC is a P105 optocoupler, it's switching Q509 mosfet, the resistor trace is linked to pin 6, which is VCC, P105 pins are 1, 3, 4, 5, 6.
      1 - K
      3 - A
      4 - GND
      5 - VOutput
      6 - VCC
      Another P105 on this board has a 2R2 going in pin 6, some others P105 have 10 or 15 OHM resistors on the same trace, but could also be a 272.
      • Biruslapio
        • Nov 2013
        • 552
        • Brasil
        Update:
        Fixed, huge thanks to user "living to camp" for uploading a photo of the area.
        How I repaired it: Upper buffer IC failed, image was flickering and dark, shut down after seconds, VSCAN was unstable, replaced the board. Y-SUS 2R2 resistor R513 measured 5k+ OHMs, replaced and the TV is now working.
        Now to actually use the smart features of the TV, only Netflix is still usable, Youtube is gone and no Amazon Prime, nor the integrated browser can access anything relevant.
        To use my phone as a remote I had to download LG TV Remote 5.4 legacy app from apkpure, to try and use screen casting via Wi-Fi Direct, I tried LG SmartShare-webOS 1.2.9 or 1.4.0, LG TV Plus 2.2.4, none of these work.
        With SmartShare-webOS the TV recognizes my phone, but displays "unknown error" when trying to access it.
        You can't adjust picture settings on the home page, the UI is all white and the TV gets frying hot, so annoying and poorly developed by LG, I always enable energy saving in plasmas, small brightness loss for a big improvement in durability for all the components inside the TV, especially for this model that has common Ydrv failures.
        • jinu_j
          Dell 2209WA - power supply - Fusible Resistor replacement
          by jinu_j
          Hi
          I am trying to repair an ancient Dell 2209WA Monitor which suddenly shut off with a pop sound. On investigation found that one of the fusible resistors had blown. Further investigation identified multiple components as faulty because of which the fusible resistor blew. Please refer the attached circuit diagram showing the components that were found to be damaged.
          1. FR950 - blown fusible resistor - 0.2 Ohm 1W
          2. Q950 - shorted Q950 MOSFET - 650V 10A N Channel Mosfet
          3. R835 - Blown Resistor - 20KOhm SMD resistor
          4. D930 - Shorted Schottkey Diode...
          05-03-2025, 10:51 PM
        • mikey5791
          Need help to replace burned resistor in 350w atx psu
          by mikey5791
          Hi to all forum members,
          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
          12-26-2024, 04:55 AM
        • MidnightRoller
          Can a resistor lose resistance after hot air?
          by MidnightRoller
          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
          02-02-2022, 11:46 PM
        • artvandalai
          What resistor ohm will work better to repair this waterpik?
          by artvandalai
          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
          01-05-2025, 04:10 PM
        • chth96
          Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
          by chth96
          I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
          Since then, This AC/DC adaptor have been out of order.
          But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
          After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
          And Is there any possibility that it will suddenly explode as well as to be out...
          12-03-2023, 04:40 AM
