HP Z600 PSU Delta DPS-725AB Dead
  • arrgh
    • Dec 2017
    • 15
    • Italy
    I have an HP Z600 Workstation that worked fine until somedays ago. Now, it won't power up and the green led on the PSU is not turning on.
    Pulled out the PSU from the chassis and opened it. No visibile signs of burned ICs from what i see.
    The model of the PSU is a Delta DPS-725AB, and the PCB is a DPS-725AP.
    I've made some high res photos that are attached.
    I've done some general testing and I found IC902, that is a TNY279PN, was shorted (I think): drain-source resistance was about 2-3 ohms.
    I've a brand new TNY279PN at home so I tested it and the drain-source resistance was about 5.5Mohms. Thinking it was the problem, I replaced the IC on the PCB, but the PSU still not working.
    I've replaced also the 100nF capacitor on the BP/M line but nothing changes.
    Voltage on the main big caps is about 322V, I marked it on the photos.
    Other reads over the TNY279PN:
    EN/UV voltage: 1.89V
    BP/M voltage: 1.80V (from the datasheet I've read that it should be over 5.85V, I'm right?)
    Main cap positive-Drain: ~320V
    Drain-Source voltage: 3.90V
    I think this circuit with TNY is for 5Vsb but I'm not sure, can you confirm? If so, the D-S voltage should be ~5V
    What can be the problem, and what could I test to find it with you?
    Thanks all in advance
    • 31253
    Re: HP Z600 PSU Delta DPS-725AB Dead
    check fuses and fuseable resistors,
    and replace any cap less than 100uf related to the chip
    • R_J
      • Jun 2012
      • 9607
      This ic is likely for the standby voltage but this is not how the ic operates, the internal mosfet switches the primary of the transformer, it is the transformer secondary winding, diode and cap that gives you the 5 volt standby. Download the datasheet and look at the sample schematic. You need to check the Drain voltage with respect to HOT GROUND (main bridge rectifier negative lead) The drain voltage should be close to 300 volts, the source voltage should be at hot ground. Check R901, it might be open
      • arrgh
        • Dec 2017
        • 15
        • Italy
        Thank you for these information R901 is as fusible resistor, right? On the top it's written 10ohm F1J... Desoldered it, and tested: totally open, not 10ohm.
        The replacement that I found is a FRN01WK0100A10 by Royal Ohm, can be good? If not and I'm wrong, let me know.
        Thank you
        • R_J
          • Jun 2012
          • 9607
          Yes, the resistor will work, but I will almost guarantee the ic is bad, I would also replace C905 & C907, since this is the standby circuit, it is on all the time and the caps can dry out over time (they could be ok but they are cheap to replace)
          • arrgh
            • Dec 2017
            • 15
            • Italy
            Here's an update after replacement components arrived.
            Components replaced as suggested:
            IC902
            R901
            C905
            C907
            PSU is fully working now, tested under stress and with several on/off cycles. For now everything is ok!
            Thanks for your precious advices and for your time
            • R_J
              • Jun 2012
              • 9607
              Thanks for the feedback, Glad to here it is working, long live the power supply
              • wilson.cjr.phys@gmail.com
                • Aug 2021
                • 1
                • Brasil
                Hi!
                I am new on BadCaps community.
                I work on a research center in Brazil, and we have several HP Z600 workstation. Many of them are presenting failures on power supply model Delta DPS-725Ab.
                So I will appreciate if someone could provide the schematic diagram of Delta DPS-725Ab power supply.
                I thank you for helping.
                Regards
                Wilson Carvalho Jr
                • Dlas
                  • Aug 2022
                  • 1
                  • Venezuela
                  Salutes, I have a similar problem with DPS 725AB, it starts with green led, a¿nd give voltage output for about 20 econds and then goes off totally, I am not sure what the standby cables are though (green and violet?), I someone can orientated me please
                  • PeteS in CA
                    • Aug 2005
                    • 3581
                    • USA, Unsure of Planet
                    I see that this is not a P/S with a standard 20- or 24-pin ATX connector. However, if Delta followed ATX-style color coding inside the P/S, purple would be the 5V Standby.
                    Another question, server power supplies sometimes will run for several seconds and then shut down if the fan never ran. Does the fan run during the 20 seconds it has output voltage?
                    PeteS in CA
                    • OKRPKCOMP
                      • Dec 2020
                      • 439
                      • PAKISTAN
                      may i know the alternate ics for IC902
                      in hp z600 power suply
                      Thanks in advance
                      • OKRPKCOMP
                        • Dec 2020
                        • 439
                        • PAKISTAN
                        can i use
                        ic TNY280PN ????
                        • only4dragon
                          • Apr 2023
                          • 1
                          • china
                          sure, i just repair my dps-725ab by this chip, and work well now!
                          • HristoM
                            • Jun 2023
                            • 4
                            • Bulgaria
                            Hello! I have encountered the same problem in this thread , changing the IC with a TNY276pn instead of a 279 (no stock in my country) and changing the R901,C905 and C907 with the same values. After repair , the PSU turns on without shorting the PSON and 5Vsb pins (when shorted the PSU turns off) and when plugged in a computer , the bios says it has found "Non-oem hardware". i require your help as this is a very confusing case for me , and i dont know where to start looking.
                            Thanks in advance!
                            • Tarek Allam
                              • Oct 2023
                              • 1
                              • cairo
                              hello and welcome, thanks for the advices
                              i have a problem with this machine after less than 3 minutes it forcedly shutdown and there is no response until unplugging the power cord and the main caps discharged, then plug it again and powering on the machine and it continuing to do the same things as a closed loop.
                              i have checked the value of the fusible resistor and its not shorted.
                              i have changed the TNY279 with the TNY280 they are the same except the TNY280 holds much power referring to its datasheet.
                              i have changed the the capacitors 100uf/50v.
                              the machine is working successfully without any forced shutdowns.
                              many thanks for your efforts
                              Biomedical Engineer Tarek Allam
                              • viet anh nguyen
                                • Apr 2024
                                • 3
                                • Viet Nam
                                Hello everyone! I have a problem with this PSU. After using it for a while, I think it is overheated. My computer shutdown and the PSU is hot. When i disemble the cover and find out the heat sink is really hot. It that the problem that cause my pc turned down? Anyone got a solution for this. Should i repaste the thermal paste or change the fan?
                                  MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                                  This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-07-2024, 03:40 AM
                                • Junkrepair
                                  Calculating ESR from tan delta -- tan delta's dependence on capacitance
                                  by Junkrepair
                                  I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                                  I found this nice little description of the conversion:
                                  Calculating capacitor ESR from Tan(delta)
                                  https://forum.digikey.com/t/calculat...-from-tan/2633
                                  It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                                  06-12-2023, 02:45 PM
                                  HP Z600 E5645 Specification for Upgrade or Repair
                                  This specification for the HP Z600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z600 boardview and Z600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP Z600 is accurate, safe, error...
                                  09-12-2024, 03:44 PM
                                  HP Z600 X5650 Specification for Upgrade or Repair
                                  HP Z600 E5649 Specification for Upgrade or Repair
                                  09-12-2024, 03:36 PM
