How modern Rubycon MCZs look like?
  • long_double
    • Jul 2007
    • 10
    I have to confess, I buy Rubycon off eBay (Hong Kong or China). Closer to Germany I couldn't find anyone, who could ship in 50 pcs batches.
    So I've bought recently Rubycon 1800uF/6.3V/8mm and they were gray on black, which is opposed to what I usually see - gold on black. Moreover in a batch I received there were K and T-shaped (Panasonic-style) caps...
    So my question is: how Rubycon currently looks like?
    Thanks.
  • Wizard
    • Mar 2008
    • 2296
    Re: How modern Rubycon MCZs look like?
    What is marked on (series) and have photos of printings on the side and views of different scoring on tops of capacitors and view of bungs?
    Thank you and cheers, Wizard
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      If you got a rubycon with a "T" vent, its a fake. Rubycon caps are still made in Japan, not china....atleast all of mine are. Chinese Rubycons are typically fakes.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • Scenic
        o.O
        • Sep 2007
        • 2642
        this reminds me of some Rubycon MCZ's i pulled out of a dead intel mini itx board.
        previous owner tried to use passive cooling instead of active.. toasted some caps.. tried to recap the board but it's still dead
        (POST code card still gets stuck after a couple codes.. no picture) ...bummer..
        however.. the MCZ's i desoldered looked genuine, but had the cheapo circle bung?!
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          Originally posted by Scenic
          Wow, Had me fooled till I saw that. Those were good fakes!
          Team : 49813
          Join in!!
          Team Stats
          • Scenic
            o.O
            • Sep 2007
            • 2642
            the interesting thing is that those were original caps that the board came with.
            so intel got into the fake trap? :O
            Boards in question are the Intel D201GLY (Celeron 215) and the D201GLY2 (Celeron 220)..
            everything after those model numbers just says if it's active or passive cooled. (trailing "A" usually)
            edit: pics of the D201GLY
            passive cooled version (with those 2 MCZs next to the CPU)
            http://image.blog.livedoor.jp/materi...d/cd8b9478.JPG
            passive and active side by side
            http://image.blog.livedoor.jp/materi...d/0defc1a6.JPG
            edit2: another interesting fact about those boards: the 12V 4pin input has a place for a cap, but none of the boards i've seen had it populated..
            • yyonline
              • Jul 2009
              • 692
              Hmm, interesting. I too have seen 820uF MCZ with the cheap-looking circle bung. It came off a Intel D865-something board, so that'd make it '05 vintage, or thereabouts. I thought about posting a thread about it, but life's been kinda hectic the past few weeks.
              These suspect Rubycons were on the CPU VRM, and they were mixed bung styles - some had the cheap looking one, some had the normal Rubycon half-circles with the dot in the middle. All had the same date codes, and all measured OK with the same ESR and capacitance.
              I got bored, so I dissected a few of them. I dissected a suspect Rubycon and another Rubycon from a completely different board. The interiors were identical in electrolyte color and smell, and I unrolled all the paper and found them to be the same length.
              So...In my case, it was either the best counterfeit ever, or Rubycon just used the wrong bungs? *shrugs* Either way, they went in the trash bin as I wasn't going to re-use suspect caps. I didn't take any photos of my dissection exercise, but I'll see if I can find some of the suspect Rubycons in the trash container to see if it's the same style circle bung as Scenic found, or something altogether different.
              • long_double
                • Jul 2007
                • 10
                It's me again. Here are the photos of the caps in question.
                Is there a FAQ on how to identify fake Rubycons?
                Does anybody know if MCZs can be grey (as on my photos) or they should always be gold-colored?
                I measured capacitance rating of these fake-MCZs and on most of them it is around 1480uF (nominal is 1800uF). But on some it is 2200 or sometimes 2400.
                • Wizard
                  • Mar 2008
                  • 2296
                  All are fakes. Wrong look of printing (especially MCZ) and capacitance all over the map, cross and T scorings. The true Rubycon is K scoring and slightly bold printing with stylized script of "Rubycon".
                  Cheers, Wizard
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    lots of pics of genuine caps
                    https://www.badcaps.net/forum/showthread.php?t=588
                    • long_double
                      • Jul 2007
                      • 10
                      OK, here are more photos. They are taken from one auction on eBay. Is there fakes among them?
                      I personally doubt about 2200uF, because V in 6.3V is too big.
                      • Wizard
                        • Mar 2008
                        • 2296
                        Those are genuine caps in that photos. You have been taken or the seller was not looking very closely at his stock or knowingly selling fakes.
                        Cheers, Wizard
                        • AudioCraZ
                          • Sep 2009
                          • 147
                          Always remember, not all people take pictures of what they are selling, they will usually google search for an image of what they have that look exactly the same, but you still may be sold fakes. You never know till you get that box at your door....
                          • long_double
                            • Jul 2007
                            • 10
                            Well, I buy on eBay, because I could not find anyone in Germany, who could deliver what I want in 50 pcs batches.
                            Maybe someone could suggest a good reseller?
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              you can get Panasonic FC's on reichelt.de
                              http://www.reichelt.de/?;ACTION=2;LA=2;GROUPID=4000
                              otherwise.. send an email or a PM (he's registered on this forum) to big pope
                              http://www.capsmod.net/caps/
                              or try the PCMC Store (send a message to that guy what caps you need and the quantity)
                              http://tinyurl.com/pcmcstore <<< prices in eur and german ebay site.
                              for the other ppl.. just replace the top level domain to the ebay on in your country.. i.e. replace the "ebay.de" with "ebay.com" or "ebay.ca" or whatever..
                              edit: oops.. i forgot RS..
                              http://de.rs-online.com/web/search/s...018+4294417669
                              you can also PM topcat (owner of this forum)... but idk about the shipping costs..
                              • long_double
                                • Jul 2007
                                • 10
                                They do not have Rubycon in stock at all. German version of RS-Online has only 10% of what US site has.
                                • long_double
                                  • Jul 2007
                                  • 10
                                  I also checked the other links you gave me and they also do not offer MCZs.
                                  That's what I've been saying, that MCZs are really had to find in Germany. Especially in small batches.
                                    • 31051
                                    why not use panasonic if you cant get ruby?
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      yeah, pannies are just as good.
                                      sigpic
                                      (Insert witty quote here)
                                      • Scenic
                                        o.O
                                        • Sep 2007
                                        • 2642
                                        http://stores.shop.ebay.de/PC-Mother...&submit=Finden
                                          MSI Modern MODERN 14 C12M-651IT Notebook 14 Specification for Upgrade or Repair
                                          This specification for the MSI Modern MODERN 14 C12M-651IT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MODERN 14 C12M-651IT boardview and MODERN 14 C12M-651IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 07:12 AM
                                          MSI Modern Modern 14 B10MW-640 Notebook 14 Specification for Upgrade or Repair
                                          This specification for the MSI Modern Modern 14 B10MW-640 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Modern 14 B10MW-640 boardview and Modern 14 B10MW-640 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 02:20 AM
                                          MSI Modern MODERN 14 B11MOU-481CA Notebook 14 Specification for Upgrade or Repair
                                          This specification for the MSI Modern MODERN 14 B11MOU-481CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MODERN 14 B11MOU-481CA boardview and MODERN 14 B11MOU-481CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 02:00 AM
                                          MSI Modern MODERN 14 B11MOU-480CA Notebook 14 Specification for Upgrade or Repair
                                          This specification for the MSI Modern MODERN 14 B11MOU-480CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MODERN 14 B11MOU-480CA boardview and MODERN 14 B11MOU-480CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          MSI Modern MODERN 14 B11MOU-479CA Notebook 14 Specification for Upgrade or Repair
                                          This specification for the MSI Modern MODERN 14 B11MOU-479CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MODERN 14 B11MOU-479CA boardview and MODERN 14 B11MOU-479CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
