Parts Finders; I challenge you! USB3 Jack Needed!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    I need to find this USB3 port off a Dell Inspiron 3463 AIO motherboard that was damaged. There's a number on the top of it: "DR17264", which crossed with nothing. I struck out with digikey and mouser and even ebay....perhaps I'm not using the correct search terms....but this is annoying!! Parts hunting apparently is indeed an art!!
    So here it is, find me one!!
    The board is ready & waiting for a new one....no I didn't scorch the board, that's just flux paste....the holes are clear and ready.
    If you need pics any more detailed than this, just say so....
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • 31283
    Re: Parts Finders; I challenge you! USB3 Jack Needed!
    https://www.aliexpress.com/item/32883547115.html
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      The 'tongue' is oriented upside down in comparison to the original....which would have the device backward....would that not have it technically wired incorrectly?
      It annoys me to no end that seemingly none of the US parts houses have these.
      Team : 49813
      Join in!!
      Team Stats
        • 31283
        well spotted, it wont fit on the board.
          • 31283
          type4??
          https://www.aliexpress.com/item/1005001701318635.html
          crap image - but it has the contacts the right way.
          too bad there is no pin/underside shot
          • R_J
            • Jun 2012
            • 9623
            never mind, I saw the tongue was wrong after uploading them
            I found this BSC brand from ali but it is nla
            Then I found this: https://es.aliexpress.com/item/32874903071.html
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16959
              Originally posted by R_J
              The 'tongue' orientation is the same as stj's.....but the through hole pins *look* the same as well as the body anchor solder points....perhaps it doesn't matter the orientation.....but logic tells me it'd be wired backward and bad things would happen when you plug a device in.
              Team : 49813
              Join in!!
              Team Stats
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                By Joe, I think that's it!! I ordered a couple.
                Muchas gracias, Amigo!!
                Team : 49813
                Join in!!
                Team Stats
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  If only I signed-in yesterday...
                  Does this look like your port?
                  https://www.digikey.sg/product-detai...409-ND/7902374
                  it's Digikey P/N: 380-1409-nd
                  manufacturer P/N: SS-52000-001
                  I actually have one in a parts bag and probably won't ever use it. I bought it for my HP Pavilion p7-1534 / p7-1233w / MS-7778 build, because the case had a busted USB 3.0 port, which I couldn't find a replacement for at all. The Digikey part above was somewhat close, though not exact... so it ended up being easier to repair the old busted port with hot glue and cardboard than to rewire with a new port. Yes, it ended up looking a little off , but it works and I haven't been able to break it with use so far - though I am a little more careful when insterting USB devices than most people.
                  Anyways, if the above port works with your application, but you also don't want to order just that from Digikey, let me know. I can just mail you mine. Like I said, I probably won't ever use it.
                  • televizora
                    ghettomodmaster
                    • Nov 2016
                    • 957
                    • Bulgaria
                    Topcat, I understand your pain. I stumble onto this problem every time I need a specific type of connector, mostly while repairing tablets or phones. The problem is that even if a connector at first glance physically looks like the correct one, when you buy it, at least half of the time the dimensions, pin locations or etc are off by a small, but still significant amount. If you have the opportunity, find and buy already defective board for spare parts. Some of the connectors are used only on a particular board and are really hard to find. Because of Right to Repair, I really hope that this type of things would be standardized some day, although I highly doubt it.
                    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16959
                      The 'tongue' orientation in that one appears to be the same as stj's... If the ones I've got coming don't work, I'll go from there.
                      I guess they want to make us repair guys earn our money! I hate trashing any good hardware for things as meager as a friggin USB port....
                      Team : 49813
                      Join in!!
                      Team Stats
                        • 22109
                        If the new USB socket legs don`t line up with holes just snip them off and solder a wire through each hole then solder to the socket body at the sides.Done that repair on plenty of laptops before. If you want the proper part number for the usb socket you should find it in the schematic , its available at some paid sites,can`t find a free download unfortunately, the file name is "Dell Inspiron 3064 3464 3264 AIO - 15107-1.pdf"
