Load Testing Audio PA Amplifiers
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi, one of my customers who rents out equipment for events and carnivals asked me to make a passive dummy load so the can test amplifiers under full power without causing noise problems to other nearby businesses.
    He wants 8 ohm and 4 ohm loads, originally he asked for 8 ohm 500w resistors, and I said we could use two resistors in parallel for 4 ohm 1000W
    Then I found these cheap power resistors on Alibaba. It says they are 'Braking' resistors, but they seem to be suitably rated for my purpose
    https://www.alibaba.com/product-deta...147691533.html
    I figured with 8 of these (costs only 33 euros in total) connected in various series/parallel combinations he could have 2x 8R 2000W, 2 x 4R 1000W or 1x 4R 4000W load
    He also wants to know if he can have a lower powered monitor speaker attached so he can hear the sound quality, but at a less than deafening volume, when load testing Amps.
    See the attached dickyCAD image.
    Q1. Can I use these resistors for Audio load testing? If yes, Maybe I should place cooling fan(s) near the resistors or bolt them to a large piece of metal?
    Q2. How best to implement the Monitor speaker? Can it be done like shown in my diagram?
    Rich
    Follow me on YouTube
    Learn Electronics Repair
    • 31278
    Re: Load Testing Audio PA Amplifiers
    you probably need to blow some air over those.
    not a huge amount, but enough to stop them being able to burn anything - like wire insulation!
    • redwire
      • Dec 2010
      • 3912
      You can use mains heaters - ovens, stove elements as low cost load resistors. You must have a fan of course. 500W or 1000W convection cooled is no good.
      You can blow amplifiers doing full power tests, a 15kHz sine-wave is very stressful for output transistors as an example. If it's just music, how does he know it's clipping? He'll need an ACV meter to show watts.
      Since wirewound resistors have some inductance, it's a good idea to include an RC snubber as some cheap amplifiers have no (internal) protection diodes and the voltage spike kills transistors.
      The Alibaba resistors are cheap and doubtfully "non-inductive" on a spiral wrap, and also rated power is forced-air cooling.
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        Correct me if I am wrong though, but don't speaker coils also have some inductance?
        To be honest those resistors are so cheap it doesn't seem worth the bother messing with stove elements
        • barry wilkins
          • Aug 2009
          • 172
          When I was an engineer we had 1000W RF generators ,these actually American radio transmitters.
          We had oil filled dummy loads for testing ,but they were 50 ohms.
          You can get devices which are actually electronic resistors , I made a small load fo testing the exciters .
            • 31278
            i remember a 50ohm load project in a magazine years ago,
            it was 2 sheets of tin with a huge number of parallel metal-film resistors soldered between them,
            and then it was suspended in a paint-can filled with oil.
            very cheap to build - totally stable.
              We use non-inductive loads in our lab to test amplifier output power, reactive loads for testing stability, we use lots of AP in our lab.
              https://www.ap.com/technical-library...eactive-loads/
              https://www.aikenamps.com/index.php/dummy-loads
              • redwire
                • Dec 2010
                • 3912
                My reply seems to have vanished
                Yes loudspeakers are inductive, a large woofer has several mH.
                But a crossover network has the Boucherot cell or Zobel whatever you like to call it which also acts like a snubber. Cheap amplifiers missing the output protection diodes and Zobel so they get nuked pretty easy.
                So I would put a RC snubber like 0.1uF X-cap+10R-33R few W series resistor just to tame the inductive kick. You can easily check with a scope, inject a low power square-wave and see what the waveform looks like.
                I'm not sure how "non-inductive" the cheap resistors are, they have a steel rod and brackets and who knows how they are wound, NiCr I think but they mention stainless steel
                Mount the resistors on a metal, non-flammable enclosure, using high-temp silicone wire. Cooling fan pointing right at the resistor(s). There is a shock hazard 1kW 8R is 90VAC. I'd have LED or light to show some idea of the power output, you have to know if you're clipping or not. Before the guy blames the amp.
                Feeding the monitor speaker at say 1/100 power should be OK.
                • dicky96
                  Sun Seeker
                  • Mar 2017
                  • 1825
                  • Spain
                  OK, so it seems not too difficult to get some suitable power resistors and fans.
                  How about a solution so he can hear the quality of music on a monitor speaker (at variable volume) while running the amp at high power into the dummy load?
                  This is something the customer is asking for, so we don't really need to discuss whether it is a good idea or not
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5085
                    • New Zealand
                    Add the speaker in parallel to the load but include a series resistor for it to lower the signal level so it doesn't get blown?
                    -David VanHorn
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      That may not work too well.
                      Because speakers are inductive and also generate back-EMF from the moving mass of the cone, a series resistor decreases the ability of the amplifier to shunt this back-EMF. This increases sound distortion, especially with bass. On that note, if you ever wondered about the Damping Factor (DF) parameter listed for on some amplifiers, it's the ratio of speaker impedance over amplifier's output stage impedance to ground. So for DF = 50 and rated speaker load @ 8 Ohms, the amp's output stage impedance is 8 / 50 = 0.16 Ohms. In that regard, higher DF means lower output stage impedance, which means the amplifier is able to drive the speaker cones more accurately and shunt more of their back EMF... which means less speaker distortion.
                      @ dicky96: how about just hook up an oscilloscope to the output of the amp and show the output with various synthetic waves at various power levels. Square and triangle waves should easily show any misbehavior, if there is any. Obviously don't push high frequencies at full power, as redwire suggested, as that may stress the output Q's harder than normal and blow something. Besides, NO ONE will ever dump 500 or even 1000 Watts @ 1 KHz, even in a carnival setup - that will blow most tweeters and midrange drivers right away and literally be a painful experience for anyone listening nearby. The bulk of power in music/audio is in the bass. Above 200-400 Hz, the power drops considerably.
                      As for the idea of using heating element as a load - I've done it before while also having a speaker hooked in series with it. Works great for pushing an amplifier to maximum volume levels without worrying about overloading the speakers.
                      • AJ847.63e
                        Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                        by AJ847.63e
                        Hi Folks,
                        Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                        I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                        The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                        05-06-2025, 10:37 PM
                      • TinkerTron
                        Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                        by TinkerTron
                        Hey everyone,
                        I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                        Instead, here's what's been bugging me so far:
                        The schematic...
                        03-06-2025, 02:03 PM
                        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        09-12-2024, 02:20 PM
                        HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                        This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                        09-06-2024, 10:56 AM
                        HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                        This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
