Choosing resistors for loading
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    I am going to make a loading device for psu's using a PCB that I gutted for all parts, a CWT PSNS-235W psu (OKIA 550W). Just cut out, or isolate, the area where the secondary caps go and replace them with resistors. ~2 resistors per rail and one for the 5vsb is perfect. Anyways, what resistors should I get? I did the math for what ohm I should use, using ohm's law of coarse, R=V/I where R=resistance, etc....
    so I want this loading device to load about 200-250W, enough to seperate really crap psu's from repairable ones.
    So I figured I would load the 12v to 10A, 5v to 15A, and 3.3v to 10A, and 2.5ohms for the 5vsb.
    Using Ohm's law, that comes to 1.2ohm's for the 12v, 1/3ohm for the 5v and about 1/3ohm for the 3.3v.
    1. is this correct?
    2. what particular resistors should I get. I plan on putting this in an old psu's case with a fan to help cool it.
    Also, anyone have any dead motherboards that they can pull the 20/24pin main connector and maybe a 4/8pin connector from?
  • etnietering
    • Apr 2009
    • 379
    Re: Choosing resistors for loading
    You are correct in your use of Ohm's law. Something else you need to consider is the power law: P = IV = (V^2)/R = (I^2)R. 15A @ 5V is 75 watts - a lot of power to be dissipated by 2 resistors that would fit in the outlines for output caps. Even with a fan and heatsinks, you should still use resistors that are rated for about twice the power they're going to dissipate. Here's what I would do: forget the circuit board altogether. Fashion some sort of mount for the inside of the PSU case out of scrap metal, and just mount power resistors directly to that mount and the metal case (with arctic silver). For the resistors I would get:
    3.3v - 3x 1ohm 20-25W (they'll each be dissipating about 11W)
    5v - 3x 1ohm 50W (they'll each be dissipating 25W)
    12v - 4x 5ohm 50W (they'll each be dissipating 28.8W)
    -12v - 1x 120ohm 2-5W (to dissipate 1.2W)
    5vsb - 1x 5ohm 10W (to dissipate 5W)
    so the totals would be:
    3.3v - 9.9A - 32.67W
    5v - 15A - 75W
    12v - 9.6A - 115.2W
    -12v - 100mA - 1.2W
    5vsb - 1A - 5W
    for a grand total of 229.07W
    so 230-235W total with a fan. This will still get EXTREMELY HOT though, so be careful! If you have extra scrap metal you can fashion extra heatsinks for the inside of the case. For this much power (especially on the 12v) you might want to add a molex accessory connector or two in addition to the main ATX connector for getting power to your unit.
    You should be able to find resistors on digikey. High power wirewound resistors like this for direct chassis mounting, or to-220 or to-247 package resistors like this for heatsink or direct chassis mounting would work. If you can rig a second fan onto the unit I would highly recommend it. Good luck!
    edit: oops! didn't see you wanted to load the 5vsb to 2A. That would be either a 2.5ohm resistor rated for 20W, or 2 5ohm resistors at 10W each. This adds 5W to the total, making it 234.07W, so about 240 with a fan or two.
    • 370forlife
      Large Marge
      • Aug 2008
      • 3113
      Heat shouldn't be a problem, I have a ton of those dell/newton proprietary psu's I gutted for parts, the heatsinks in those are pretty think and so are the cases themselves. Sandwich them between the heatsinks and case should be enough to keep it pretty cool.
      • etnietering
        • Apr 2009
        • 379
        Yeah that should work, just make sure there's adequate airflow - don't cramp the resistors too close to each other.
        • 370forlife
          Large Marge
          • Aug 2008
          • 3113
          Hmm, this may be an expensive project, maybe some other time...
          I could also use my case for a lambda II elevator controller from the radisson, my brother works there and got it for me when they were throwing it out.
          Anyways, the case on that is almost bulletproof, good for dissipating heat.
          Spending too much, I just ordered something that may make other's raise their pitchforks at me in heresy.
            • 31277
            you can get film resistors in to218 packages for heatsink-mounting,
            but you'd need a big sink and serious fan.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Just an idea - maybe instead of resistors, you can get some car light bulbs (headlight, tail light, etc.). Perhaps go around car shops and ask if they have dead headlight bulbs. The reason you want headlight bulbs is that most are 2 bulbs in one (low beams and high beams). Chances are the high beams would still work.
              If not that, you can also try some type of heating element. The thin ones in hair dryers usually have pretty low resistance.
              Either way, keep in mind that 230 watts is a lot of heat. 1 PSU box might not handle it too well.
              • Toasty
                • Jul 2007
                • 4171
                Toaster(s).
                veritas odium parit
                • Khron
                  • Sep 2006
                  • 1350
                  • Finland
                  I've suscessfully used some car lighbulbs for load-testing an Antec i revived, a couple weeks ago
                  Details can be found HERE
                  • etnietering
                    • Apr 2009
                    • 379
                    Well I have a sort of update for this - I made a small dummy load for testing/loading power supplies. Originally, it was just the big resistor zip tied to the heatsink. It was connected to a molex connector, and ran the 12v line at about 4A (it's a 3 ohm resistor). This worked well enough, but would crossload the PSU VERY heavily (I couldn't even draw an amp on the other rails). It's not attached to the PSU, that's just a convenient place to put it while it's in operation.
                    Here's a picture:
                    And here's another picture:
                    So, I ordered two 1 ohm resistors, to load the 3.3v rail and 5v rail to several amps (3.3A on the 3.3v and 5A on the 5v). They're thick film resistors in TO-220 packages, so they mounted very easily to the heatsink. I also added a 15 ohm resistor for the 5vsb, so it will draw 1/3 A from that rail. So the total power draw is as follows:
                    3.3v * 3.3A = 10.89W
                    5v * 5A = 25W
                    12v * 4A = 48W
                    5vsb * 1/3A = 1.67W
                    for a total of 85.56W.
                    Not a real heavy load, but enough to make sure things are working properly, and the load is even enough for the voltages to be happy. I also added an LED for each rail. As I was searching through all my LEDs, I found that I could match the LED color to the color of the wires that carry that voltage. So there's a yellow one on the 12v, red on the 5v, orange on the 3.3v, and purple on the 5vsb. These let me know which rails are working, and are a good indication of whether or not the heatsink will burn me if I touch it (all 4 on = hot, only purple on = cold). The whole thing is powered from the ATX connector of the PSU. I used 2 wires (18 gauge, from an old power supply) for each power rail (except the 5vsb), and 6 ground wires. The switch shorts PS_ON to ground, turning the unit on and off. I know having the LEDs unprotected like that is very unsafe, but I didn't really want to put a whole ton of effort into making some nice LED board, and I think it looks pretty cool with them all floating like that
                    Here is an after picture:
                    Here is another after picture:
                    Currently it's plugged into my 350W L&C that I recapped. The DC load is around 85-90W (the voltages are almost spot on), and it's drawing 124W from the wall, for an efficiency of about 70%...ouch!
                    What do you guys think?
                      • 31277
                      i think you should drill a couple of holes for the resistor before it melts those cable ties.
                      • Khron
                        • Sep 2006
                        • 1350
                        • Finland
                        And try to keep the heatsink fins vertical; helps with the cooling
                        • mur
                          • 21
                          Just found this:
                          http://www.chirio.com/electronic_load.htm
                          google translate helps
                          http://translate.google.com/translat...tm&sl=it&tl=en
                          I think this is a very cool load tester. But to test pc supply you would need to have at least 3 of those loaders to load all rails. Go check it out
                          • etnietering
                            • Apr 2009
                            • 379
                            Well I have an update - I got a 4.7 ohm resistor, which I connected to the 12v line. 4.7 ohms @ 12v is 2.55A, and about 30.6W. So this brings my dummy load to:
                            3.3v - 1 ohm - 3.3A - 10.89W
                            5v - 1 ohm - 5A - 25W
                            12v1 - 3 ohm - 4A - 48W
                            12v2 - 4.7 ohm - 2.55A - 30.6W
                            5vsb - 15 ohm - 0.33A - 1.67W
                            for a total of 116.16W. The new resistor is connected through a molex adapter, so it can be connected independently of the rest of it. With this extra load, my logisys runs at almost 75% efficiency! Whippee....
                            This increases the total load, and skews it a bit more towards 12v, which will be useful for newer power supplies.
                            • AJ847.63e
                              Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                              by AJ847.63e
                              Hi Folks,
                              Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                              I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                              The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                              05-06-2025, 10:37 PM
                            • TinkerTron
                              Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                              by TinkerTron
                              Hey everyone,
                              I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                              Instead, here's what's been bugging me so far:
                              The schematic...
                              03-06-2025, 02:03 PM
                              KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                              by momaka
                              For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                              http://www.rmac.kingwin.com/products.../abt_650MM.asp
                              I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                              What mostly drew me into buying it is its 2x PCI-E power connectors...
                              03-29-2022, 11:34 PM
                              A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                              by momaka
                              More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                              And a shot of the label:...
                              01-26-2022, 03:26 AM
                            • прямо
                              Viper22A 5VSB circuit
                              by прямо
                              So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                              In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                              01-13-2024, 07:05 PM
