Back to Back Transformers
  • pintglass
    • Jul 2019
    • 79
    • United Kingdom
    Im currently building an isolation transformer from 2 240v-12v transformers, wired with the 2 12V secondaries joined to give 240V out, which I am getting.
    The Issue I have is that I'm getting 100Hz out from 50Hz in.
    Can anyone tell me why that may be?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Back to Back Transformers
    Either you're measuring it wrong or the source transformer has a rectifier output... ?
    • pintglass
      • Jul 2019
      • 79
      • United Kingdom
      Both the transformers are from old 12V battery chargers both of which had rectifiers in them aswell.
      If the transfomers had rectifacation would they still need a seperate rectifier.
      I'm just measuring with my multimeter and going off what its reading which is 100Hz
      • petehall347
        • Jan 2015
        • 4429
        • United Kingdom
        closest i could find without using diodes is this .but your set up isnt like it ... maybe try moving the transformers further away from each other ...
          Show us how you have them all connected up.
          You need to connect the 12V winding directly together, no diode, nothing but just the 12VAC winding of each transformer.
          240VAC into first transformer 240VAC winding, 12VAC winding of first transformer to 12VAC winding of second transformer, 240VAC winding of second transformer for 240VAC Isolated output.
          • pintglass
            • Jul 2019
            • 79
            • United Kingdom
            Thats how I've got them setup.
            I've attached an image of how there wired. The transformer in the bottom of the image is the 240V in, with a fuse before it, then the two 12V's are connected together then the output is the transfomer at the top.This goes into a power meter display then into a DPST switch.
              So direct connection without any diodes anywhere, you are seeing 240VAC 100Hz at the output?
                • 31138
                you may be getting transfer between the transformers because they are oriented in line with each other.
                magnetic flux through the air or even the metal baseplate.
                do you have a scope?
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  The coupling is a nice theory but doesn't really hold water, you need a phase shift of some sort to get doubling and coupling is in phase or at least very close to be in phase. Still doesn't explain...
                  What about the frequency of the 12V between the two? What about after the measurement jig before the first transformer?
                  I have to say that there's some measurement issue or some other noise source like the measurement jig... Scope would indeed be nice.
                  • redwire
                    • Dec 2010
                    • 3912
                    PZEM-021 energy/power meter uses a capacitive-dropper for power and likely causing some ringing on the AC waveform output of the second transformer when it has no load on it. Are you sure you've got the right winding, I see some steel lamination cut off and extra windings on it and 247V label?
                    Connect a light bulb load on the output and I'd guess the frequency reading would mysteriously half.
                    • pintglass
                      • Jul 2019
                      • 79
                      • United Kingdom
                      Yes with direct connection and no diodes my multimeter is showing 100Hz
                      Yes I have a scope
                      I only get 50Hz on the 12V windings
                      Even if I disconnect the energy/power meter I still get 100Hz on the output Transformer.
                      The output transfomer does have more than one tap but I still get 100Hz on both of them.
                        • Jul 2011
                        • 6057
                        You do have the right phasing or you will not get the right voltage or current
                        On the primary and secondary winding
                        I done this before and you have to get it right for it to work correctly
                        • pintglass
                          • Jul 2019
                          • 79
                          • United Kingdom
                          What do you mean by having the right phasing ?
                            • Jul 2011
                            • 6057
                            Have you noticed that on some transformers have a dot on them on one corner one side then on the side of the transformer there is another dot on the opposite corner
                            This is the phasing of the transformer when you hook up two in series you hook it one way when you hook it up in parallel you hook up another way
                            This also depends on the transformer you are using
                            Most transformers are not marked by the way
                            If you google how to determine the phasing you should be able to figure it out
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Again this does not make sense. Phasing at most will invert or not invert the sinusoid of the AC current, but the downstream equipment should not care what phase it's running at. You can try swapping the connection of the 12V/low voltage wires to put things in phase.
                              This must be some noise problem that your meter is picking up though I'd say the 100Hz is a second harmonic that the meter is picking up. The only thing that sticks out at the moment is that your secondary transformer is using two windings hooked up in parallel or this should be the case. A mismatch may cause some weird behavior. What if you use the two transformers the other way around -- use the low impedance of line power to override the parallel winding mismatches?
                              • pintglass
                                • Jul 2019
                                • 79
                                • United Kingdom
                                Do you mean that the output transformer's 240V side has dual windings in parallel, as I am only connected to one of them.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  yeah you have a mess there, can't exactly tell how you're connected. Might be some noise being introduced there too, dunno...
                                    • Jul 2011
                                    • 6057
                                    No what I am talking about is if you have it out of phase then you will not get any voltage or current or you are shorting both transformers out
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      The windings are all in parallel and the signal (AC line) is symmetric/sinusoidal, so you don't have to worry about it.
                                      If one was planning to make a voltage doubler out of these transformers, they'd need to be in series, and this would make a difference.
                                      However 0° or 180° phase difference, the peaks and valleys would all appear at the same time, cancelling each other out. Need a phase shift to double the frequency somehow...
                                      • redwire
                                        • Dec 2010
                                        • 3912
                                        This schematic diagram might help. If OP can verify.
                                        Phasing is important for the dual-primary tranny but more so if they were autotransformer connected which is what sam is talking about.
                                        Adding a small load will get rid of the frequency doubling OP is seeing.
                                        I want an earth ground connection and don't see it.
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 08:10 PM
