Insignia NS-55D510NA19 backlight problem
  • brucetv
    • May 2015
    • 281
    • united states
    This Tv came in with no backlights, audio was fine and with the flashlight test it showed the image was fine. Took measurements at led connector CNB801 and nothing. The backlights came on fine using a backlight tester so I pulled the combo PS/Main and put the board under the microscope and found a blown resistor at R8310, blown cap at C6316 and after replacing both she fired up fine. Before you assume it's the backlights look very close especially in this section.
    Re: Insignia NS-55D510NA19 backlight problem
    That is R/C snubber for the MOSFET, good find.
    • motorpontoon
      • Jan 2021
      • 1
      What is the voltage for the CNB801 going to the backlight lights. I have 45.5 volts Dc.
      Also what voltage do i need to test each strip #303T C550033
      • mjbok
        • Dec 2021
        • 2
        Could not use the link for the teardown pics. Is that still active?
        • Dobrowol
          Asus GA402RK keyboard and kb backlight problem
          by Dobrowol
          Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
          04-28-2025, 04:30 PM
        • ononos
          LG M2362DP Backlight problem
          by ononos
          hello everyone!
          As the title states i am an owner of an LG flatron M2362DP 23 inch monitor Tv. Since i currently use it as a tv i'm posting the problem on the "troubleshooting tvs and video sources" section.
          I'm from Greece so English isn't my native language, so please forgive me for any mistakes i make. I have basic knowledge in electronics, and although i have a degree, many things have changed since i finished a 2 year coarse (over 30 years ago). Occasionally i repair easy stuff, mostly things that break at home like appliances.
          So i decided to try to...
          03-12-2023, 05:05 AM
        • fanaticgames
          Samsung UE32D4010 Backlight problem, led ok
          by fanaticgames
          hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
          02-22-2023, 09:46 AM
        • SolarFlare
          Mi TV 4 Pro-Samsung Panel LSC550FN20 - Video problem, backlight and Audio works fine.
          by SolarFlare
          My barely 3 year old TV has stopped displaying video, although the video output comes for a few seconds after turning ON which displays the manufacturers logo then shows the home screen (all this with some blue flicker) then the video goes blank and the screen is dark blue with the backlight on. The audio output works perfectly and the TV also takes in voice commands(smart TV).
          The TCON board has the following Chips -
          Samsung VTU63A0
          RT6939 - 2nos.
          and all these chips are getting real hot within a minute, I dont know if this is normal....
          06-26-2022, 08:58 AM
        • grbo92
          Backlight problem Acer LA-031P
          by grbo92
          i have one acer Nitro 5 without backlight on my desk.
          Mainboard model: LA-L031P GH53Z REV 1B
          Attached schematics and boardview are REV 1A, slightly different as REV 1B.
          11411_LA-L031P-Acer_Nitro_5_AN515-45_AN517-41-GH53Z_Rev_ (1).zip
          Repair history: customer cleaned dust and changed thermal paste, shortly after that there was no light
          Notebook boots without problem and shows only image without backlight, HDMI output working. Optical inspection done, no burned or broken components. Tested also with a new display module....
          09-09-2024, 03:49 AM
