Help with Component identification.
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    Hi guys, grateful if anyone can help with identifying part number of the following IC.
    Laptop: HP pavilion X360 convertible
    Motherboard: Bucks_NVDIS_MB; 16871-1; 448.0BZ03.0011
    IC marking: BAC71H
    Location on board: PU4502
    I can't seem to find schematic for this motherboard but reversing the tracks I am fairly confident its the IC responsible to produce 5V.
    Additionally if anyone can also provide part number for the following component (same motherboard);
    IC marking: AWV7EE
    • 21841
    Re: Help with Component identification.
    Its a Silergy SY8288CRAC i think .
    • Spider1211
      • Oct 2019
      • 532
      • Mauritius
      Thank you!!! Pin mapping looks to be same. Any idea about the other IC? Most likely it'll be the 3.3V.
      Attached is the connection diagram of the SY8288CRAC if anyone needs it.
      • Spider1211
        • Oct 2019
        • 532
        • Mauritius
        It seems the AWV7EE could be SY8286BRAC. Grateful if anyone can confirm same.
          • 21841
          SY8286BRAC maybe.
          Edit: yes i agree its a SY8286BRAC
          • Spider1211
            • Oct 2019
            • 532
            • Mauritius
            Great! Attached is connection diagram for SY8286BRAC if anyone needs it.
            • vedoza
              • May 2015
              • 37
              • newyork
              hi guys, grateful if anyone can help
              IC marking: T109 5016
              • mon2
                • Dec 2019
                • 14659
                1) how many pins?
                2) U4001 on which logic board?
                3) can you post a clear picture of the part?
                "T109" will likely be the SMD marking to identify the component.
                "5016" is likely the datecode where this marking means 50th week of 2016.
                Perhaps the attached by Ricoh ?
                Does your device match the package as per attached?
                See here:
                https://dtsheet.com/doc/1338465/r1191h
                • vedoza
                  • May 2015
                  • 37
                  • newyork
                  Originally posted by mon2
                  1) how many pins?
                  See here:
                  Thx bro ...
                  You great some
                  mainboard : X540up
                  schema : PU8801 IC replacment compatible
                  SN1409049DPUR
                  • mon2
                    • Dec 2019
                    • 14659
                    Ignore my post. It does not match.
                    See attached for PU8801 details.
                    https://www.arrow.com/en/products/sn...as-instruments
                    You should be able to find these on Aliexpress.
                    TI p/n SN1409049DPUR
                    https://www.aliexpress.com/item/4001...ad4b397e9904-0
                    Try Louis in NY - he may carry them in stock:
                    https://www.rossmanngroup.com/
