42" HP plasma
  • wski
    • Sep 2009
    • 9
    42" HP plasma
    I got this tv to try and see if I could fix it. When it is turned on the screen starts out black then develops spots that expand to cover the screen and will not find a display source that is supplied.
  • dan8139
    • Jul 2004
    • 57
    Re: 42" HP plasma
    I think the panel is physically broken, hope I'm wrong!
    • wski
      • Sep 2009
      • 9
      Re: 42" HP plasma
      the panel isn't cracked but might have the power source for it might be shot, or a leak of the fluid in the screen might be the problem, I don't know.
      • Wizard
        • Mar 2008
        • 2296
        Re: 42" HP plasma
        There are no fluid in a plasma panel it is vacuum with bit of mercury vapor in there.
        Cheers, Wizard
        • PlainBill
          • Feb 2009
          • 7034
          Re: 42" HP plasma
          Without casting aspersions on your intelligence, I have noticed some people have problems distinguishing between Plasma, LCD, and DLP displays. (Recently someone was trying to sell a "42' LCD plasma TV with DLP".) Posting the Model number will go a long way toward eliminating confusion.
          To my inexperienced eye, the problem looks more like a cracked LCD panel than any fault possible with a plasma panel.
          PlainBill
          • wski
            • Sep 2009
            • 9
            Re: 42" HP plasma
            the back panal states it is a plasma, and the whole fills in with the staticy picture, unlike a cracked screen the will only show the screen until the crack.
            • wski
              • Sep 2009
              • 9
              Re: 42" HP plasma
              there is no manual and the model number is: HP PL4260N 42" Plasma HDTV, CPTOH-0602, Product number EK429AA, Manufactured OCT 2006
              • Wizard
                • Mar 2008
                • 2296
                Re: 42" HP plasma
                Checked the model #, is plasma panel. Way it looked, confirm you have correct voltages as it is marked ont he panel itself on the power supply and the two side boards between the power supply. You have digital multimeter?
                If correct, panel lost it's gases/vacuum.
                Cheers, Wizard
                • dan8139
                  • Jul 2004
                  • 57
                  Re: 42" HP plasma
                  Can anyone explain what happened here?
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • Alicat
                    Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                    by Alicat
                    Stopped by this site trying to fix my parents Panasonic Plasma TV.
                    Model number is TH-50PZ85U
                    Power comes on and the red power light stays on solid.
                    Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                    I also hear a few clicks.
                    I also think my parents said there was a thunderstorm and the TV failed after that.
                    Section 6 in the service manual talks about power and no screen,...
                    10-30-2024, 10:09 AM
                  • smic717394
                    by smic717394
                    07-25-2024, 10:16 AM
                  • Zelek11
                    Panasonic Plasma screen interference on left half of screen
                    by Zelek11
                    My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
                    This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
                    10-14-2022, 04:54 PM
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
