hi friends i need Macbook A1534 820-00045-A Bios Dump with clean me thanks in advance
Macbook A1534 2015 820-00045-A CleanMe Bios Dump
Tags: None
Re: Macbook A1534 2015 820-00045-A CleanMe Bios Dump
with this bios its became very slow plz clear meAttached Filesif you find these attachements useful please consider making a small donation to the site
Try and report..Attached Filesif you find these attachements useful please consider making a small donation to the site
with this no display i post his original then plz clear me and passComment
here it is orignal bios with pass
plz clear pass and clean meAttached Filesif you find these attachements useful please consider making a small donation to the site
try and report...Attached Filesif you find these attachements useful please consider making a small donation to the site
@Murtaza527
With original file the laptop have image?
what´s the problem of the laptop?
try with this fileAttached Filesif you find these attachements useful please consider making a small donation to the site
yes with orignal have display i use one extra bios chip for your bios which earlier you clear password but with that was no display i think because of my bios chip just now i write his orignal bios on that chip with that also no display. i try find same ic first then i do your bios and i post result thanks a lot for helpComment
try this and post reply
use clear pram and reinstal ios
Flash my bios on the original ic chip. Maybe you ic chip isn´t compatible with you motherboardyes with orignal have display i use one extra bios chip for your bios which earlier you clear password but with that was no display i think because of my bios chip just now i write his orignal bios on that chip with that also no display. i try find same ic first then i do your bios and i post result thanks a lot for helpComment
Sorry for late reply i flash on original ic both all upper files but with that no luck no display with original have display but have password plz someone clear passwordComment
Your original dump without password.
try and reportAttached Filesif you find these attachements useful please consider making a small donation to the site
Try it for yourself https://www.youtube.com/watch?v=-O1330jgW9gComment
Hello. Help me remove the password.Attached Filesif you find these attachements useful please consider making a small donation to the site
read the rules..https://www.badcaps.net/forum/troubl...before-postingDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
by AttilaPetheHi,
I have a MacBook Retina Intel _Core M_ 1.1GHz 12_ (Early 2015) A1534, MJY32GR, with a W25Q64BV flash inside. Can someone clear the PIN?
Thanks in advance!...-
Channel: BIOS Requests ONLY!
by twonk9098I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
This model has the newer trackpad which is not clickable when turned off.
At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but... -
by stefanbsThe laptop is Apple Macbook A1534 2017 with board 820-00687-А. The USB-C tester shows no voltage, there is 820-00244-А board available. I looked at both schematics, all connector signals seem to be the same. Did someone try to fit 820-00244-А board in A1534 2017?05-11-2025, 01:08 AM
by obelix24Hi All,
i got one Macbook a1534 boardnumber 820-00244 that is taking only 5V 0,2A
I've tried to replace 3x CD3215B01 chip but it's still behaving same ....
On the board there was blown L4804 so i've replaced it.
when power is connected 5V 0,2A
PPBUS_G3H - 0V
PP20V_USBC_XA_VBUS_F - 5V
I've tried to remove F7040 as mentioned here
https://www.badcaps.net/forum/troubl...1534-820-00244
but there is... -
by envymHi everyone!
I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...06-27-2025, 08:54 AM - Loading...
- No more items.
