MacBook A1534 MJY32GR Early 2015 PIN blocked
  • AttilaPethe
    • May 2023
    I have a MacBook Retina Intel _Core M_ 1.1GHz 12_ (Early 2015) A1534, MJY32GR, with a W25Q64BV flash inside. Can someone clear the PIN?
    Thanks in advance!
    • 21641
    Re: MacBook A1534 MJY32GR Early 2015 PIN blocked
    Thanks in advance!
    What is the logic board number 820-??? ,and EMC number
    • AttilaPethe
      • May 2023
      EMC Number: 2746
      Board number I can not tell, I soldered wires to the test points of ISP to read/write, so I ca not move the board... Sorry.
      • kevingill
        • Jun 2013
        • 152
        • England
        I've blanked out between the $SVS markers in the bin file.
        Hope this works for you.
        Remember to PRAM reset three times.
        • AttilaPethe
          • May 2023
          Thanks I solved it meantime. I wrote a new clean dump in it, changed serial, and after that no PIN after the restore operaration. Thanks anyway!
            Apple MacBook Air 13" Early 2015 Service Guide
            Apple MacBook Air 13" Early 2015 Service Guide...
            10-15-2024, 02:06 AM
          • limakan
            Macbook A1534 early 2016 backlight
            by limakan
            Hello !
            I have an issue with my Macbook A1534 early 2016
            Core m3 (M3-6Y30)
            1,1 GHz, 8Gb, 256 Gb
            Backlight issue : at power on, the LCD screen is 100% white, when I turn the LCD panel some glitches appear, sometimes (around 45°) the LCD is coming back to normal, but very few times.
            I replaced the flexible cable LVDS ==> no effect, still same issue
            it seems the board is 820-00244 (to be confirmed ?)
            I have attached the schematics for 820-00244.
            Can you help me in troubleshooting this issue ? is it...
            08-25-2023, 02:15 AM
          • Constantinos
            Macbook Air Early 2015 820-00165 No Backlight
            by Constantinos
            Hello everyone.
            I am trying to repair a friend's macbook air.
            The initial problems were that there was nothing on the display.
            The board was water damaged.
            After disassembly, I noticed that the fuse was still ok but there was a burned capacitor.
            After cleaning the entire board with IPA and replacing the capacitor (L8304 on schematics), I now have the picture without backlight.
            The macbook boots and everything works, except for the backlight
            There was considerable water damage around the u7701 chip
            I haven't repaired macbooks before, but after watching...
            07-16-2023, 01:58 PM
          • twonk9098
            Macbook Pro mid 2015 battery required to boot?
            by twonk9098
            I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
            The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
            This model has the newer trackpad which is not clickable when turned off.
            At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
            If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
            12-10-2024, 06:51 PM
          • stefanbs
            Fit 820-00244-А board in Apple Macbook A1534 2017 820-00687-А
            by stefanbs
            The laptop is Apple Macbook A1534 2017 with board 820-00687-А. The USB-C tester shows no voltage, there is 820-00244-А board available. I looked at both schematics, all connector signals seem to be the same. Did someone try to fit 820-00244-А board in A1534 2017?
            05-11-2025, 01:08 AM
