LA-8861P started but only 3.3v and 5v
  • kokono
    • Jun 2018
    • 203
    i have this board ,i have +3VALWP and +5VALWP
    with power supply , green led ist ok and when press start button ,blued led lighing but led near push button dont working .
    i dont have 1.5v line
    maybe RT8207 ist defect ?
  • BlueMidnight
    • Jan 2015
    • 489
    Re: LA-8861P started but only 3.3v and 5v
    If SYSON is 0 volts, then it's too soon for RT8207 to turn on.
    You said you are getting 3V and 5V, so check things that should happen after 3V/5V rails turn on, but before SYSON goes high.
    Some of the important steps in the power sequence include (where low=0V and high=3V):
    - POK (from PU330) goes high
    - +VSB = 19V
    - +3VALW_PCH = 3.3V
    - PCH_RSMRST# goes high
    - CLK_EC outputs 32.768KHz (testable with multimeter frequency setting or other frequency counter tool)
    And, after pressing power button...
    - PM_SLP_S5 goes high
    - PM_SLP_S4 goes high
    If all that happens and SYSON still doesn't go high, then corrupt EC firmware is a possibility. Otherwise, examine closely the first step that is failing to happen.
    • kokono
      • Jun 2018
      • 203
      - +VSB = 19V
      - +3VALW_PCH = 3.3V
      thx for reply
      i am sure that +3VALW_PCH = 0V
      • BlueMidnight
        • Jan 2015
        • 489
        Alright. Next, measure pins on Q5510 to find out why.
        • kokono
          • Jun 2018
          • 203
          i tried again
          - POK (from PU330) goes high (yes)
          - +VSB = 19V (yes)
          - +3VALW_PCH = 3.3V (yes) Q5510 ist active after pressing power button
          - PCH_RSMRST# goes high (yes)
          - PM_SLP_S5 goes high (NO)
          - PM_SLP_S4 goes high (NO)
          whats next sequence?
          • BlueMidnight
            • Jan 2015
            • 489
            Oh okay, that changes things a bit. You'll need to examine the signals related to the power button press itself.
            ON/OFFBTN# (signal from power button to EC)
            - Starts at 3V
            - Drops to ~0V while pressing power button
            - Rises back to 3V after releasing power button
            PBTN_OUT# (signal from EC to PCH)
            - Starts at 3V
            • kokono
              • Jun 2018
              • 203
              - Starts at 3V
              Yes, exactly
              - Starts at 3V
              before pressing power button ist 0v >>after 3v and remain, after 5 second 0V
              • kokono
                • Jun 2018
                • 203
                i think UCL1 ist problem ,i ordered and waiting for it
                I believe that PCH dont answer correctly
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3590
                  • slovakia
                  or ec dont answer correctly to power button
                  • kokono
                    • Jun 2018
                    • 203
                    i tested YCL1 crystal with scop, Nothings
                    i thinks UCL1 dont working
                    • BlueMidnight
                      • Jan 2015
                      • 489
                      If your scope has a high enough bandwidth and sample rate to measure the 25 MHz, then that could be evidence of a problem. But you should double-check the 32 KHz output since that is much lower frequency, and less likely to be affected by the capacitance of your probes.
                      It definitely needs that 32 KHz clock working, or you'll never get the 32 KHz on SUSCLK/CLK_EC after RSMRST# goes high.
                      If the clock is really missing, then that chip could be bad. Although, crystals do go bad too sometimes.
                      • kokono
                        • Jun 2018
                        • 203
                        thx, also i checked CLK_EC(32KHz) , without clock
                        i believe that first UCL1 should make clock for PCH and after it , PCH send 32KHz to EC . is right ?
                        • BlueMidnight
                          • Jan 2015
                          • 489
                          Yes, that is correct.
                          On most boards, a 32.768 KHz crystal is connected directly to the PCH. But on this board, UCL1 generates several different clock frequencies for several different chips on the board by using a single 25 MHz crystal.
                          There needs to be a 32.768 KHz clock signal on pin 9 of UCL1. This goes to the the PCH via PCH_RTCX1. After RSMRST# goes high, the PCH will copy that clock to its SUSCLK/CLK_EC pin for the rest of the board to use.
                          The other clock signals generated by ULC1 are important too, but not until later in the startup process.
                          • kokono
                            • Jun 2018
                            • 203
                            Update :
                            i changed UCL1 but ist same
                            another idea ?
                            • jaroslav.psenicka
                              Lenovo Yoga 2 13 LA-A921P - missing SYSON
                              by jaroslav.psenicka
                              I have a LA-A921P here on AC adapter
                              • power LED on
                              • button SW1 (power) pressed
                              • the CPU gets warm
                              • fan not spinning
                              • no dead short found anywhere
                              • +5VALW/+3VALW present
                              • DDR_VTT_PG_CTRL is 5V
                              • SYSON is 0V
                              the +0.675VSP and +1.35VP is missing, assuming because of missing SYSON signal
                              SYSON is not shoted to ground
                              the SYSON is generated by U51 hope it's not it
                              Is there anything i can test?
                              Many thanks,
                              -jp...
                              04-16-2024, 06:38 AM
                            • mat2k
                              Lenovo 300-15IBR - No SYSON, no SUSP#, bunch of missing voltages
                              by mat2k
                              Hello, I've been struggling with this one today. I'm troubleshooting a Lenovo 300-15IBR (board BMWC1/BMWC2 NM-A471) that turns on the power LED and does a bit of fan spin but nothing else. 3v3sb and 5vsb present, no 1.05v, no 1.35vddr, no vcore, no 1.8vsb.
                              BIOS has been reflashed with one I found here, supposedly tested OK by someone else. I don't have an EC programmer unfortunately.
                              I looked around and SYSON is 0v, SUSP# is 0v too. Forcing them to 3v3 enables the 1.35v rail, but the 1.05v and 1.8v rails are still missing (generated by PU704). EN_1P05A signal is 3.3v, and IN_1P05A...
                              12-01-2024, 11:00 PM
                            • phuzzyday
                              Sony KD-70X690E. Started with reset loops.. then it got more complicated. I'm at wits end!
                              by phuzzyday
                              First of all, thank you everyone who helps others in here! You guys are treasures! Please bear with me, this may be long. I have tried a LOT.
                              First, my wife said the TV was turning off and on. When cold it would be fine for several minutes, then it would start resetting.
                              I opened it up and noted there are two main lines coming out of the supply besides the backlight., The T-Con 12V line and the main 12V line.
                              TRIED 1 - I scoped power coming from Power Supply while it was all still connected. I noted that just before it reset, the 12V line going to the T-Con was going...
                              03-26-2025, 05:53 PM
                            • ncoy1123
                              Getting started repairing HP Chromebook 11a g8 EE Motherboards
                              by ncoy1123
                              Hello, I'm pretty new to component level repair and have only ever done things like replace headphone jacks or connectors, if those are even considered component level repairs. I have some Chromebook motherboards that are dead that I would like to practice on, but I'm not exactly sure where to start. I have HP Chromebook 11a g8 EE and HP Chromebook 11a g6 ee and their layout looks very similar. The issue that I have is there's power to the USB ports, but they don't actually turn on. There's no display output, and the way that usually flashes when it posts doesn't do anything. I was wondering how...
                              10-21-2023, 09:16 AM
                            • SaYHell0
                              macbook pro a1989 macbook started But no screen on extern or intern display.
                              by SaYHell0
                              Hello i guess i have another logic board as the usual a1989?
                              Iam new into smd fixing but i want to learn That because that makes so much fun
                              I guess i Found my Problem?
                              Problem was: macbook started But no screen on extern or intern display.
                              Cpu/gpu was very Hot after trying a few commands with reboot...
                              06-01-2023, 03:48 PM
