HP All-in-One bios 22-b011nt
  • asliyucegsm
    • Jun 2011
    • 347
    • Turkiye
    my friend
    HP All-in-One - 22-b011nt
    bios dump
    thanks
    • 21124
    Re: HP All-in-One bios
    Post your bios backup .
    • asliyucegsm
      • Jun 2011
      • 347
      • Turkiye
      Originally posted by asliyucegsm
      my friend
      bios dump
      thanks
      mainboard.DA0N91MB6D0 REV.D
        • 21124
        Go to the HP drivers support page: https://support.hp.com/emea_middle_e...model/11792264
        Choose your OS version,then on BIOS.There are 4 different bios versions for this model: 81BA,81BB,82DD and 8432 .
        Download the first bios (ROM Family SSID 81BA) F.46 Rev.A and run the exe ,it will give you the option to save the bios to a file location.The saved file will be the full 8,192KB 8MB bios .
        The second bios in the list (ROM Family SSID 81BB),F.45 Rev.A i found doesn`t give the option screen to save the bios, in this case you have to download an older Previos version , F.41 Rev.A or older. Save the bios for all 4 and try each one .
        (You`ll have to try them all,as you havnt provided your bios backup.The bios backup will have one of those ID`s in it,you can seach with a hex editor to find out which one you need,instead of trying all 4 versions)
        • asliyucegsm
          • Jun 2011
          • 347
          • Turkiye
          my friend
          open close button 3.3 v yes
            • 21124
            my friend
            I don`t understand "open close button 3.3 v yes"
            Did you flash the bios .
            BID081BA https://ftp.hp.com/pub/softpaq/sp885...00/sp88778.exe
            • darkll
              • Jun 2016
              • 3
              • turkey
              he says; ' on/of switch 3.3.v ok'
              • darkll
                • Jun 2016
                • 3
                • turkey
                my friend
                abicim bu nasıl ingilizcedir be adam anlamamış ne demek istediğini
                • nik nik
                  • Dec 2017
                  • 20
                  • nigeria
                  Please help remove admin password
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • Habble7
                    I need a BIOS dump for the Samsung S49CG934SU monitor
                    by Habble7
                    The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                    Suspected Cause:
                    I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • haitham sharabati
                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                    by haitham sharabati
                    Hello engineers 😀,
                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                    🔧 Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                    💀 Problem:😅
                    - Device shows “Administrator Password”...
                    08-07-2025, 04:54 AM
                  • Citymin
                    NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                    by Citymin
                    My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                    The charging red LED lights up, but the charging screen doesn't show any indication.
                    When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                    (I've tried removing the battery and resetting the device, but the issue persists.)
                    NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                    PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
                  • DynaxSC
                    MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                    by DynaxSC
                    Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                    I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                    11-17-2023, 10:56 AM
