Sharp LC-70LE660U - Panel Q's... Each side works opposite cable disconnected
  • geeforce
    • Oct 2017
    • 87
    Hello!
    I do not have the 2-5 blink error, it basically seems to maybe flash once on startup(never turns off).
    It will just flash briefly when I turn it on, the dim backlight flash.
    I cannot turn off with remote or power button.
    When I disconnect either side of the t-con, the side disconnected goes white and the other side looks fine (sharp logo etc). So BOTH sides show the image when the opposite is disconnected.
    Is this an obvious panel fault? Doesn't seem to have side tabs like other posts mention, there are little flaps with ic's on them on the sides... but not sure i should be ripping them off lol.
    Where should I be going from here? Trying to read through all the threads - I feel like this should definitely be pointing me in the right direction.
    Any thoughts?
    adding pics from my phone shortly.
  • geeforce
    • Oct 2017
    • 87
    Re: Sharp LC-70LE660U - Panel Q's... Each side works opposite cable disconnected
    Ok, lies.
    So while trying to and failing to upload photos- made it work for now. Read anothers post where they throught it was good to go and failed out.
    Basically after operating the TV with disconnected tcon sides, or them back together and it works.
    Loaded internet, no updates.
    There are two lines visible on the screen though. See pictures. Bad panel? I expect it to fault out again soon.
    • yohnsee
      Semi-noob
      • Dec 2017
      • 198
      • Hungary
      Originally posted by geeforce
      Ok, lies.
      about the visible lines. This kind of vertical line is caused by a bad bonding between the flat cable on the top/bottom (source drivers), that connects the LCD screen itself to the slim pcb. It can not be repaired, unless you have a tab bonding machine, but it can be worked around. You need to press gently on the flex cable that is the closest to the line on top/bottom of the screen. If it makes it go away, you have to think out something to constantly get that area pressed. Some uses heat gap pads (i think it is the best solution), some uses rubber, etc.
      The horizontal line is caused by a gate driver. There are many articles on BC, how to handle this. But we can walk you trough, if you want to make it go away.
      Cheers, Janos
      • geeforce
        • Oct 2017
        • 87
        Thanks Janos,
        I'll mess around with the lower tabs, maybe try cleaning them too.
        My set has tiny ICs attached along the side, maybe 4-5 per side on tiny tabs not connected to anything... I'll play with those too.
          Since your set has both a dead horizontal and dead vertical line, I am inclined to suggest impact damage, or a failed pixel that has shorted and killed both drive lines. Nothing much you can do.
          • geeforce
            • Oct 2017
            • 87
            True that Tom! Thanks for all your invaluable help on this forum!!! Your answers often provide light!
            I took the plunge and ripped off the panels tab bonds on the right side (side which showed the horizontal line with tcon half disconnected).
            The horizontal line is gone! Yay.... Too bad is got a vertical line. Fail. Of well.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4462
              • Italy - Milan
              Hi, i don't understand well your first posts, but i can see well the images, so with a pressure on the source driver it doesn't make difference? You don't have to press the glue strip but on the chip itself...
              • geeforce
                • Oct 2017
                • 87
                Unfortunately it seemed to make no difference, I put a heatsink foam piece between the chip and the frame to try and help cool/provide pressure. Didn't work, nor did any manipulation of the cof-bond tab thing.
                All good...
                I will have to take the tv apart down to the diffusion layers to clean it properly. The PO sold it to me in pieces and the the diffusion layers were damaged(kinked) and had oily finger prints... Long story, but thought I bought a complete, but broken tv. Got it home found out leds were removed... called seller he tells me he thought they were broken so took them out (he stripped 30% of the screws... had to use a drill on 6). Ended up asking him for EVERYTHING he thought was garbage from the panel... picked up the diffusion layers, some frame peices and the led lights. Definitely not sure if I got the diffusion layers right, but think I did based on some glue residue lol... Too bad, panel is damaged from his shotty work removing the led bar I think. Some people need to stay away from electronics lol.
                One issue still, when I click the Netflix button on remote it seems to lock the tv... only thing I can do is hold PWR on remote for about 6-10 seconds to force a restart. Ideas?
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4462
                  • Italy - Milan
                  The vertical line is black? In effect it tends to let me think it's a three-output failed at the same time and not a connection problem, let we remember that in source drivers the 3 subpixels are displayed one per clock cycle. I think a very brief spike have destroyed in the moment the pixel at the crossing point of 2 lines was displayed. It's only story now.. I'm thinking, is there any overvoltage suppressor on the TCON's??
                  • Rozp
                    70LE660U dark cloud or black screen with sound.
                    by Rozp
                    Hello Everyone,
                    This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                    I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                    08-29-2023, 05:25 PM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • SmartSarah
                    Sharp LC70LE747 Flickering - darkening gradually to the right side
                    by SmartSarah
                    Dear,
                    I can not pinpoint the following problem on my Sharp TV LC70LE747E.
                    While the left side of the screen is not affected at all the right side of the screen gradually fades to a kind of dark. I can best describe this darkness like a totally worn out CRT display or a gamma correction totally out of range. This darkness flickers like a flame, a dark one tough.
                    Sometimes when I restart the TV it disappears for a while.
                    The problem worsened over time the last few months.
                    I've replaced the t-con module without success. The problem remains.
                    05-23-2022, 01:00 PM
                  • Dirtyphinger
                    screen shot with right side disconnected and new transistor
                    by Dirtyphinger
                    New transistor and right side ribbon disconnected
                    02-08-2019, 09:39 PM
                  • ttmi100x
                    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                    by ttmi100x
                    Greetings everyone,
                    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                    Upon closer inspection...
                    07-31-2024, 06:36 PM
