ASUS X540L schematic
  • sorinede
    • Jul 2009
    • 19
    Hello to all , i need this schematic.....latop work only on battery ..i have found on motherboard the second mosfet from dc in connector has low resistance (in short) M.B. is x540lj rev2.0 ASUS
    Inscription on mosfet is m3054m....the first mosfet near dcin plug is m3056 this is ok ..i have measured it with multimeter and show aprox.540 ohm , the internel diode , so i think is a n-channel mosfet
    i have not find a datasheet on internet...thank you in advance..
  • sorinede
    • Jul 2009
    • 19
    Re: ASUS X540L schematic
    OK i have solved this laptop by replacing with AON6414A..now it charging the battery , in windows show level of battery and the mosfet did not become got...
      • 21881
      I see you solved it now. Heres the link to the datasheet anyway, for reference .
      https://www.alldatasheet.com/datashe.../QM3054M6.html
      • sorinede
        • Jul 2009
        • 19
        ok thanks for datasheet , it seems original mosfet has high current then aon6414 but more low timings......but laptop still charging battery...hope it is ok...thank you for datasheet ..i didn't find it..
        • Chieftain
          • May 2016
          • 72
          • Greece
          Any schematic anyways?
          • servis_null
            • Oct 2014
            • 82
            • Croatia
            I have just this if it can help someone.
            Boardview and some kind of a "repair guide" .
            • Albertoq
              • Jul 2019
              • 11
              • Perú
              thank you
              • cybernova
                • May 2015
                • 34
                • IRAN
                Thank you bro
                • toldi73
                  • Feb 2020
                  • 1
                  • Polska
                  Thank you, you helped me a lot
                  • hungkd
                    • Mar 2020
                    • 1
                    • vietnam
                    thank you
                    • Abdulkadertabbakh
                      • Feb 2018
                      • 10
                      • syria
                      Thanks, asus x540l 2.1 Is There boardview ?
                      • ozenx
                        • Jan 2019
                        • 5
                        • turkey
                        Thank you
                        • samanthban
                          • Feb 2014
                          • 253
                          • Sri lanka
                          Thank you
                          sigpic
                          • charle1x1
                            • Apr 2018
                            • 2
                            • Zimbabwe
                            Thank you
                            • mcckds
                              • Dec 2013
                              • 14
                              • indonesia
                              trims...
                              • fichamba
                                • Dec 2011
                                • 134
                                • Spain
                                Thanks!
                                • reassor
                                  • Apr 2021
                                  • 181
                                  • Poland
                                  Boardview
                                  • alterr333
                                    • May 2019
                                    • 43
                                    • México
                                    you rock mate, cheers
                                    • dqtech
                                      Badcaps
                                      • Jul 2018
                                      • 639
                                      • N/A
                                      thanks you
                                      • jelatang
                                        • Mar 2013
                                        • 15
                                        • id
                                        thank you
                                        • AppleLover123
                                          Asus X712EA 3 volts after the first mosfet
                                          by AppleLover123
                                          Hey guys,
                                          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                                          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                                          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                                          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                                          Now i thought something...
                                          12-15-2024, 07:49 AM
                                        • Scotchmist
                                          Asus GA502D keeps blowing mosfet
                                          by Scotchmist
                                          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                                          I have removed the mosfet and can run the laptop no problem
                                          The MOSFET is FDPC5018SG
                                          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                                          08-24-2024, 02:23 PM
                                        • MicroSMD Lab
                                          ASUS ROG Zephyrus GPU Mosfet repeat failure
                                          by MicroSMD Lab
                                          The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                                          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                                          01-10-2024, 06:36 AM
                                        • Joshwa
                                          Asus ROG G703GI BOARDVIEW / SCHEMATIC request
                                          by Joshwa
                                          Hello, please i need a schematic for my Asus ROG G703GI laptop.. I think my motherboard has a problem with the sound. Thank you!!
                                          10-16-2025, 06:21 AM
                                        • someonenotyou
                                          ASUS G513R - cannot remove MOSFET
                                          by someonenotyou
                                          Hi.
                                          I have a ASUS G513R laptop with shorted MOSFET (MP86959GMW-Z 45A).
                                          I tried to preheat the board to 200C brom the bottom and with rework station set to 400C I flowed it for about 2min. The MOSFET does not come off.
                                          Of course, I did not force it, but tried to lift it up with tweezers.
                                          Is it possible, that these MOSFETs are glues to the board? Or it got welded to the board from the short? It looks intact, no signs of blowing up.
                                          10-10-2025, 11:05 AM
