Lg 50pj550 no STBY light
  • dzyk2000
    • Jul 2018
    • 41
    • United Kingdom
    Hello everyone.
    Where can I find a list of smd capacitor for EAY60968701?
    I suspect that c310 is defective
    I changed 3br1565jf ... but I had a short circuit after the soldering. I checked all the nearby components and are good. It replaced 3br1565jf with a new one, but I have no voltage, except in the drain pins 3br1565jf and in the first coil of the T301. no voltage between pin 4 and 5 of 3br1565. I have no voltage on the secondary coil at T301. I need some help. Thank you.
  • dzyk2000
    • Jul 2018
    • 41
    • United Kingdom
    Re: Lg 50pj550 no STBY light
    Originally posted by dzyk2000
    Hello everyone.
    UPDATE
    Who can help me with the t301 measurement, I want to know what resistance have primary and the secondary coils and what voltages needs to have at the entrance and exit when they are in stby
    • R_J
      • Jun 2012
      • 9553
      Did you check R305? what resistance did you measure?
      The transformer is likely ok and the DC resitance of the windings will very low. You do know these circuits operate at high frequency, 67kHz, your meter will not measure that.
      Do you have any standby VOLTAGE, it should be around +5 volts
      C310 is also very likely ok
      They do have repair kits for this board
        1) In standby with TV just plugged into the out, the DCV on the top pin of the transformer in your picture should be about incoming ACV x 1.414, so if your AC is 230VAC then the DC V will be about 352V DC.
        2) The DCR of the transformer will be really low resistance, most of the time will <1 Ohm, you can only use Ohm meter for checking for open winding.
        3) Your drawing of the connection of PIN 2 does not look right, that is the CS which should be connected to the very low Ohm current sensing resistor and Ground. Look at the application circuit in the spec sheet to see how each pin of that SMPS IC is connected.
        4) c310 is connected to BA (pin 3), see page 17 about the cap connected to that BA pin.
        https://cdn.badcaps-static.com/pdfs/...64ff9dcede.pdf
        • dzyk2000
          • Jul 2018
          • 41
          • United Kingdom
          Thank you R_J and Budm.
          R305 have 0.34 ohm, i think is ok.
          I have no 17v, no 5v or 3,5 v
          Can you have a look at this picture.
          I dont know where need to start checking 5v fault.
          3br1565
          pin 1 drain - 327v
          pin2 cs - 0V
          pin3 BA - 0,1v
          pin 4 VCC - 0,5V
          pin6 fb - 0,1v
          p813 have 0v on 17v pin, 5v pin, stby pin, ac det pin
          error det 0,1v
          • dzyk2000
            • Jul 2018
            • 41
            • United Kingdom
            3br1565
            pin 1 drain - 327v
            pin2 cs - 0V
            pin3 BA - 0,1v
            pin 4 VCC - 0,5V
            pin6 fb - 0,1v
            error det 0,1v
            Power Supply Basic Operation AC Voltage is supplied to the SMPS Board at Connector SC101 from the AC Input assembly. Rectified by the Bridge rectifier D101 generates a primary B+. The Power factor circuit generates a Primary supply which can be read at Fuse F302 160V. This primary voltage is routed through T301 and routed to the Standby 5V supply. The STBY5V (standby) is B+ for the Controller chip on the back of the board (IC701) on the SMPS and output at P813 pins 13 and 14 then sent to the Main board for Microprocessor (IC1) operation (STBY 3.49V RUN 5.23V). When the Microprocessor (IC1) on the Main Board receives a “POWER ON“ Command from either the Power button or the Remote IR Signal, it outputs a high (2.43V) called RL_ON at Pin 15 of P813. This command causes the Relay Circuit to close both Relays RL101 and RL103 routing AC to the Bridge Rectifier D101 which then routes the primary voltage to the PFC circuit (Power Factor Controller) 390V which can be read measuring voltage at Fuses F302 (390V)
            I have 390 v with rl101 and rl103 off, why?
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Are you 100% certain they are off or does off mean off/removed from the board??
              • dzyk2000
                • Jul 2018
                • 41
                • United Kingdom
                Yes, was checked out of board , im 100% . But i dont undrestand why have no voltage at EY317 T301
                In D101 is no AC that mind rl101 is open
                  So if you run the power supply board by itself without having it connected to other board but just the AC input, do you still get 390VDC on the main filter cap (measured right between the two legs of the cap, not chassis GND)
                  • dzyk2000
                    • Jul 2018
                    • 41
                    • United Kingdom
                    Yes, power supply is on my bench, is not conected on main board or ysus . I have 327v in input at T301, but nothing on the output. i changed again 3br1565 and now i have in pin3 1,5v, in pin 4 0,5v, pin 6 0.3v.
                    i dont understand why no have 5v (3.49v)
                      Without having the board connected to other board and have Voltage on the main filter caps in the PFC circuit is that relay RL101 has to be closed, so you should verify that is no DC on the coil (measure right across the coil) of RL101. If the coil Voltage is not present then it mans the contact is stuck closed. RL103 is used for bypassing the NTC when PS-ON is present.
                      What DC V do you have between C377?
                      "The Power factor circuit generates a Primary supply which can be read at Fuse F302 160V. This primary voltage is routed through T301 and routed to the Standby 5V supply." That is wrong. Where did you get the info from?
                        Is this your EXACT board?
                          "i dont understand why no have 5v (3.49v)" I do not understand the (3.49V). What is the 3.49V reading?
                          The 5.1V (switched Q352) and the 17V (switched Q356) are switched power supplies.
                          • dzyk2000
                            • Jul 2018
                            • 41
                            • United Kingdom
                            After t301 i have no voltage, betwen pins of c377 i have 0v, relay is mounted without black cover to see whats hapening, n the picture above, where I wrote the voltage of 3.7 v. this voltage starts at 1v and increases if there is more time connected. I do not have the ac voltage in d101 but on the output I find the tension I am talking about above
                            • dzyk2000
                              • Jul 2018
                              • 41
                              • United Kingdom
                              this is the text from training manual.
                              Power Suration AC Voltage is supplied to the SMPS Board at Connector SC101 from the AC Input assembly. Rectified by the Bridge rectifier D101 generates a primary B+. The Power factor circuit generates a Primary supply which can be read at Fuse F302 160V. This primary voltage is routed through T301 and routed to the Standby 5V supply. The STBY5V (standby) is B+ for the Controller chip on the back of the board (IC701) on the SMPS and output at P813 pins 13 and 14 then sent to the Main board for Microprocessor (IC1) operation (STBY 3.49V RUN 5.23V). When the Microprocessor (IC1) on the Main Board receives a “POWER ON“ Command from either the Power button or the Remote IR Signal, it outputs a high (2.43V) called RL_ON at Pin 15 of P813. This command causes the Relay Circuit to close both Relays RL101 and RL103 routing AC to the Bridge Rectifier D101 which then routes the primary voltage to the PFC circuit (Power Factor Controller) 390V which can be read measuring voltage at Fuses F302 (390V) and F801 (389V) from “Hot” Ground. AC Detection (AC Det) is generated on the SMPS, by rectifying a small sample of the A/C Line and routed to the Controller (IC701) where it outputs at P813 pin 16 (4.45V) and sent to P301 to the Main Board where it is sensed and monitored by the Main Microprocessor (IC1). If AC Det is missing the set will come on, but shut off in 10 seconds. When RL_ON arrives, the run voltage +5V source becomes active and is sent to the Main Board via P813 (5.24V at pin 5, 6 and 7). The (Error Det) from the SMPS Board to the Main Board can be measured at pin 8 of P813 (2.88V STBY and 4.93V RUN), but it is not used. The RL-ON command also turns on the 17V (Audio B+ 16.79V) which is also sent to the Main Board. The 17V Audio supply outputs to the Main board at P813 pins 1 and 2 and used for Audio processing and amplification. The next step is for the Microprocessor IC1 on the Main Board to output a high (3.27V) on M_ON Line to the SMPS at P813 Pin 17 which is sensed by the Controller IC701, turning on the M5V line and outputs at P811 pins 9 and 10 to the Y-SUS board. The Controller (IC701) also uses the M_ON line to turn on the VA and the VS supplies. (Note there is no VS On Command in this set). VS is output at P811 to the Y-SUS board P201. (VA pins 6 and 7 and VS pins 1 and 2). Note: The Va is fused on the Y-SUS then routed out P209 to the X-Board Left. VS is also routed out of the Y-SUS P206 pins 1 and 2 to the Z-SUS P2. AUTO GND Pin 18 of P813: This pin is grounded on the Main board. When it is grounded, the Controller (IC701) works in the normal mode, meaning it turns on the power supply via commands sent from the Main board. When AUTO GND is floated (opened), it pulls up and places the Controller (IC701) into the Auto mode. In this state, the Controller turns on the power supply in stages automatically. A load is necessary to perform a good test of the SMPS if the Main board is suspect
                                If there is no AC feeding the bridge D101 then there is no way you can have that 390VDC on the main cap.
                                  "Fuse F302 160V" But you have 327VDC, right?
                                  • dzyk2000
                                    • Jul 2018
                                    • 41
                                    • United Kingdom
                                    q352 and q356 are not powered by t301?
                                    • dzyk2000
                                      • Jul 2018
                                      • 41
                                      • United Kingdom
                                      yes
                                        RL_ON is 0V, correct?
                                          Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                          by sam_sam_sam
                                          I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                          I also have back when Light of America had these light bulbs available for yard lights
                                          The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                          While the Lithonia lighting fixture has all most certain bulb failure
                                          So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                          I have only had this light fixture for not more than a year if it...
                                          07-02-2023, 03:45 PM
                                          LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 03:40 AM
                                          LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 09:10 PM
                                          09-06-2024, 08:40 PM
                                        • serious_electron
                                          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                          by serious_electron
                                          Hello Everyone!
                                          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                          06-28-2025, 02:57 PM
