LG 55UF6450 No Backlights
  • eagle00799
    • May 2012
    • 322
    I have this tv that i'm trying to fix for a family member, LG 55UF6450 Ultra HD 4K LED tv. They said the picture went out but it still had sound, they no longer have the original remote so I have no remote to work with.
    This is what I have so far.
    I can not see any image on screen using flashlight.
    i'm not sure of what input it is on and can not see menu to change the input but have tried all HDMI inputs but it made no difference so no image and no sound so far.
    When powered on the red light on bottom front of tv blinks 2-3 times and lights on main board come on but no flash at all of backlights.
    Voltages I have checked are as follows.
    Main Cap is 160v-off/400v-on
    t-con fuse reads 13.2v-on
    Led+ is 129v on both positives when powered on and 62v when off.
    Voltages on the connector when powered on are as follows.
    PWR-On=3.3v
    GND
    13.3v
    13.3v
    GND
    DVR-ON=3.4v
    P-DIM1=0
    GND
    13.2v
    13.2v
    13.2v
    P-DIM2=0
    Not sure of which one of these controls the BL_ON.
    Any idea's would be appreciated.
  • R_J
    • Jun 2012
    • 9624
    Re: LG 55UF6450 No Backlights
    What is the voltage in the led- pins when on?
    Do you see a quick flash of the led backlight at all
    Put your model number into the search, there are a few other threads on this model
    Like this one: https://www.badcaps.net/forum/showth...light=55UF6450
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      The DRV-ON pin would be the one to turn on the Backlights. If you say you have on both +ve pins to the backlights but does it remain at that voltage or does it go down to a lower voltage and did you measure the -ve backlight pins WRT chassis GND, if so what did you get? From what I read so far it would seem you have a bad backlights issue but we need more info to correctly guide you.
      • eagle00799
        • May 2012
        • 322
        Hi RJ thanks for the reply, I get 8.6v and 6.7v on the 2 negative posts and I get no flash of backlights at all.
        • eagle00799
          • May 2012
          • 322
          Hi Andrew thanks for your reply also, the 129v holds steady on both + posts and I get a 8.6v and 6.7v on the 2 negative- posts
          • eagle00799
            • May 2012
            • 322
            So if I am getting voltage from the negative posts I assume it's shorted backlights?
            • R_J
              • Jun 2012
              • 9624
              Are you sure the backlights are not on? 129v - 8v = about 120 volts to the led's.
              When you did the flashlight test did you have a source connected and did you have audio?
              • eagle00799
                • May 2012
                • 322
                I had a dvd player connected to the HDMI but could not see or hear anything. I have no remote and can not see the menu to switch input.
                • eagle00799
                  • May 2012
                  • 322
                  The LG has 1 button on the bottom that controls everything so it's hard if not impossible to know how to get it to the right input.
                  • Diah
                    • Feb 2013
                    • 6593
                    if the back light voltage as you wrote show 129V. the LED should be light on when tv turn on and this you can easy to see them. if voltage there but thy are out then you have broken ( CUT OUT ) Led one or more.. but in this case with flash light you can see some things on the screen, look close at turn on in the middle of the screen or the top left.
                    • R_J
                      • Jun 2012
                      • 9624
                      connect the dvd to hdmi with dvd power off then turn tv on, then turn on the dvd, sometimes the tv will find it.
                      I guess you could try disconnecting one of the ribbons between the t-con and panel and see if you get anything on half the screen.
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        I agree with the other Learned Techs that are replying to your issue. Turn the TV on and look at the back of the TV. You should see through the holes if the Backlights come on or not Then with the TV on measure the voltage on the two ends of the T-CON Bd. fuse to see if there is any power to the T-CON Bd.
                        • eagle00799
                          • May 2012
                          • 322
                          Ok I lucked out a bit, the remote for my LG DVD player works on the tv so I was able to switch inputs and now I have sound but still can not see any image. I disconnected each side of the t-con 0ne at a time and the side I disconnect will get a very quick and dim flash of light when powered on. I have 13.2 volts to both ends of the fuse on the t-con bd.
                          • eagle00799
                            • May 2012
                            • 322
                            Pic of t-con bd, fuse F1 13.2 volts to both sides
                            • R_J
                              • Jun 2012
                              • 9624
                              This is where you take out your scope and check the signal on the lvds cable, without it the problem could be with the main board or t-con, I suspect main board myself.
                              If you disconnect the small white plug from the t-con do you get brighter backlights?
                              • eagle00799
                                • May 2012
                                • 322
                                When I unplug the small white plug the lights come on full screen.
                                • R_J
                                  • Jun 2012
                                  • 9624
                                  Ok, so your backlights are ok, and the power supply is ok, others have had problems with the mainboard. Shopjimmy had all 3 boards for under $90.00 but are out of stock.
                                  • eagle00799
                                    • May 2012
                                    • 322
                                    Thanks for your help guys, I will see if I can find a main board. I have done some browsing and have seen many different boards for the LG 55UF6450, curious if any of those will work if I can't find the exact board that's in this tv.
                                    • Andrew F. Ali
                                      • Jan 2014
                                      • 2450
                                      • Trinidad & Tobago
                                      The EAX- - - - - part number on the Main Bd. MUST match for the TV to work. Other boards that look similar but do not carry the same part No. would be outfitted with different software that will not math the T-CON Bd.
                                      • Diah
                                        • Feb 2013
                                        • 6593
                                        hmmm. most always tinny small boards from LG need heating later , as they used at manufacturing halogen free since 2015.
                                        use hot air or backing offen ( with out air fellow ) to rebel the main board .. or just the reheat the main processor
                                        • EvazX
                                          ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                                          by EvazX
                                          I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                                          Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                                          For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                                          However, after some time, the replacement motherboard...
                                          08-25-2025, 06:09 PM
                                        • max789
                                          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                          by max789
                                          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                          I made the following tests:
                                          1. Disconnected the main board from Power Board = backlight works.
                                          2. Connected the main board and disconnected the T-Con = backlights does not work.
                                          So I ordered a main board from Ebay also BN41-02156A but from...
                                          01-18-2024, 06:56 AM
                                        • jesterace
                                          Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
                                          by jesterace
                                          Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
                                          However, I am in a dilemma.
                                          I tested the backlight outputs with the lights disconnected...
                                          10-20-2024, 10:15 AM
                                        • x_orange90_x
                                          Sony KD-75X750H no backlights
                                          by x_orange90_x
                                          I just removed the back cover to test the backlights because when I first plug it in it will flash once and then start dark but I can see the image. I got 131v on string 1 and 167v on string 2. Usually when I get a bad set the meter reads 300v and they won't light up. When testing, each set lights up inside the tv. When I plug in the power and check the leads with my multimeter both strings are only about 3v.
                                          Does this difference in voltage between the strings indicate that the lesser has bad LEDs? Or is it normal that they are not the same voltage? I've read some about this tv and...
                                          07-16-2025, 07:49 PM
                                        • jimbofz
                                          toshiba 65ul2163 dbl no backlights NOT BACKLIGHTS?
                                          by jimbofz
                                          Hi this vestel 65in tv had classic no backlights ,so nothing new there!
                                          tested with b/l tester and the b/l seemed to be fine
                                          so investigated psu 17ips72 (on this 65inch there are 3 fets and control iv type DB83630P)
                                          did a thorough check on b/l circuit all ok .
                                          When i tried again with b/l tester all ok .but then when i reinstalled psu all worked fine ,
                                          could there be a component on psu that is causing the protection mode to stop b/l
                                          .maybee causing it to be too sensitive?
                                          it seems to me if the b/l have been on with my tester ,within a couple of minutes...
                                          06-07-2025, 10:11 AM
