Samsung 65" Curved 4K Light Seeping Out At Top
  • Michale32086
    • Nov 2011
    • 1453
    I have a Samsung 65" Curved 4K.. This is actually my home TV and it's on the wall, so I can't get at the model number..
    It came in as a "repair" but all it needed was the CONNECT box so, to the best of my knowledge, it hasn't been cracked open...
    The problem is, there are some lighted areas at the very top of the display... It's noticeable, but not grotesquely so...
    When I was working on the previous LG 4K, I noticed that there was black tape around the edges and I was thinking that might be there to prevent this LED "Seepage" issue.. But, thinking it thru, that doesn't seem to make any sense...
    Any ideas as to what could cause this and if it's fixable??
    Thanx...
  • mmartell
    • Oct 2013
    • 3189
    Re: Samsung 65" Curved 4K Light Seeping Out At Top
    Ahh one of the Bains of LCD tv manufacturing I'm afraid... Some have massaged the area a little in the hopes of "seating" affected components. Others have tried jamming thin pieces of paper or plastic (credit card) between the bezel and the screen.
    Don't think it can be solved properly without screen removal.
    • Michale32086
      • Nov 2011
      • 1453
      Yea, and I can imagine that screen removal of a curved panel is 10x more fraught with problems than a regular panel..
      Don't think I want to attempt it, since the problem is so minor..
      Thanx for the reply...
        09-07-2024, 05:50 AM
      • howardc64
        Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
        by howardc64
        TV was fixed just after removing Samsung's rear snap cover.
        This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
        Maybe PSU->backlight connector didn't have a good contact?...
        07-23-2025, 12:34 AM
      • Kaar3l
        Samsung QLED QE65Q7FNAT only standby light
        by Kaar3l
        TV: Samsung QLED QE65Q7FNAT
        PSU: BN4400940A
        MB: BN94-12832K
        I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
        09-24-2024, 01:35 PM
      • marcinq
        Samsung UE60KS7000 No Standby Light
        by marcinq
        I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
        I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
        05-26-2025, 11:36 AM
      • ChristianBr01
        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
        by ChristianBr01
        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
        04-23-2025, 01:48 AM
