Lenovo Carbon X1 12298-2 LMQ-1 48.4LY06 Boardview/Schem?
  • angel-boy
    • 550
    • Romania
    Need Schematic LMQ-1 12298-2 48.4LY26.021
    thanks
  • by_mex
    • Feb 2014
    • 57
    • turkey
    Re: Need Schematic LMQ-1 12298-2 - X1 Carbon
    thanks
    • inflex
      • Aug 2012
      • 545
      Looking for boardview/schematic for the X1 12298-2.
      Currently is trying to boot, keyboard lights up for a second or two, touch-bar is active and responding, completely black screen, no energizing.
      Fan will spin up for about 3 seconds, then stop for another 15~20 before spinning up again indefinitely.
      YouTube Repair Videos - https://www.youtube.com/user/19PLD73
      FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
      • khaahk
        • Dec 2013
        • 814
        • Estonia
        Re: Lenovo Carbon X1 12298-2 LMQ-1 48.4LY06 Boardview/Schem?
        Check if cpu responds to heating. Schematics i have not seen. Try another bios if no response to heating.
        • inflex
          • Aug 2012
          • 545
          I made a copy of the BIOS (16M) compared it to another one, a reasonable level of similarities, so I have my doubts the BIOS is at fault explicitly; though it might be the data line pullups, clock gen issue, or bad cap not getting voltage up high enough on one of the rails, all could respond to heating.
          • piernov
            • Jan 2016
            • 4439
            • France
            BIOS corruption can happen on one bit and be sufficient for the computer not to boot. Also sometimes an external programmer will read the chip properly, but while booting the computer cannot. You should still try to flash it. Some "bad" EEPROM may work under specific thermal condition.
            Also check if you have PLT_RST# on the mini PCIe port. (or M.2, dunno what's in there)
            • khaahk
              • Dec 2013
              • 814
              • Estonia
              This bios is from working machine, windows serial nr removed.
              CPU heating i meant that these mainboards might respond to heat like AMD chips. Worth to try before trying to waste time on deep diagnostics.
              MOD EDIT: Bios Moved to new thread - https://www.badcaps.net/forum/showthread.php?p=1054064
              • inflex
                • Aug 2012
                • 545
                I'll give it a try later. If that one does work, what's the offset to set the Windows serial?
                • inflex
                  • Aug 2012
                  • 545
                  Just noticed, your chip is the MX25L12805, mine is the 12873E, I imagine that's not going to matter, but thought I'd make note of it.
                  • khaahk
                    • Dec 2013
                    • 814
                    • Estonia
                    EEF175h
                    • inflex
                      • Aug 2012
                      • 545
                      Tried the new bios, no change.
                      • khaahk
                        • Dec 2013
                        • 814
                        • Estonia
                        If you find similar schematic with the same EC then maybe attach a post card to LPC and check if it gives some information. Memory and cpu are next in line for suscpects. Neither are good if i remember correctly this mainboard has nasty underfill under both. How much amperage is drawn?
                        • Jehmin
                          • Sep 2018
                          • 4
                          Anyone Find these?
                          • Jehmin
                            • Sep 2018
                            • 4
                            Same problem Turning on Fan spin for a few seconds and shutting off and repeating the same steps.
                            Anyone find the Schematics?
                            Also can a capacitor have 2 different voltages?
                            Or is this part even a capacitor? Looks like a ceramic cap to me.
                            When tested with multi-meter
                            It may not have a side going to ground and some of these get 2 different voltages on each side. Especially bottom left.
                            Voltage: Tested with power plugged into board. One side lead on ground other on each each side of suspected caps.
                            The Ceramic caps in question are coming from the ThinkEngine Chip
                            I think 3 of them did not have a side going to ground. The labeled boxes are not the exact caps. The photos is not of the exact board in question and photo found online.
                            • Jehmin
                              • Sep 2018
                              • 4
                              • Pferd5
                                • Mar 2018
                                • 72
                                I have bought an non-working X1 which had fan spin but no screen. I tried to reflow the RAM like Rossemann does (with the light touch) but ended up just heating them without the movement or slightly touch.
                                NOW! IT WORKS!
                                First real notebook repair!!!
                                Rossmann is right, what an adrenalin rush! DAMN does this feel good!
                                • Enko
                                  • Oct 2018
                                  • 2
                                  • Croatia
                                  Did you manage to fix it? Mine spins for a few seconds, then stops, then tries again and stops again for good.
                                  • pratyush
                                    • Sep 2018
                                    • 69
                                    • India
                                    Thinkpad Carbon X1, LMQ-1 MB 12298-2
                                    Need schematic...
                                    • pratyush
                                      • Sep 2018
                                      • 69
                                      • India
                                      Re: Thinkpad Carbon X1, LMQ-1 MB 12298-2
                                      If this one is unavailable then provide me any other related schematic diagram...
                                      • sparrow2719
                                        • Oct 2015
                                        • 69
                                        • Indonesia
                                        I do have LGS-1 X1 Carbon schematic and boardview if you want it.
                                          Lenovo ThinkPad X1 Carbon Notebook X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X1 Carbon Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon boardview and X1 Carbon schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-07-2024, 07:20 AM
                                          09-07-2024, 07:19 AM
