Dell 9550 LA-C361P AAM00 Schematics needed
  • reddemonic
    • Jun 2015
    • 42
    board can power up fine, the board has a minor liquid damaged.
    some of these components is slightly corroded. i want to replace these parts
    i can see the silkscreen of the chips but i need to know the value of these resistors and caps.
    does anyone have this schematic.
    cheers
  • aspenpup
    • Jan 2019
    • 2
    Re: Dell 9550 LA-C361P AAM00 Schematics needed
    Did you ever have any luck on finding schematics? I have a Dell 9550 that is out of warranty by just a couple of month. System will briefly turn on but then turn off. Can not get past POST, no logo splash. Unable to get into Bios (F2) or diagnostics (F12). Could just be bios issue but already replaced battery. I would like to check voltages and see if there is any physical problems. I actually suspect a bios issue, visual inspection looks good. Would really like to see some schematics
    • Cipher
      • Mar 2014
      • 3
      • United Kingdom
      I have the schematics see attached file. I'm issues with this board too really looking to get some insight what you guys are getting in readings around.
      Im getting not getting any voltage at all from source, gate and drain I am thinking about replacing them as it just doesnt make any sense why dont get voltage see attachment.
      Would love to hear your thoughts.
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        probably the mosfets are shorted to ground. place one prod of your multimeter to ground and poke the mosfets to see if it is shorted be sure to disconnect the battery and power adaptor first. hope this helps..
        Never stop LEARNING because life never stops TEACHING!
        • Duranitron
          • Jul 2014
          • 544
          • Philippines
          cheers
          I'm just suggesting if the mobo is working fine just clean it. don't try to keep it nice looking. this is one of many techs and hobbyist motto "if its not broken don't fix it". hope this helps..
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            try a known power adapter first that works, have you done the short circuit test? probably there is a short in the board.. most likely mosfets in the powersupply section. try to visual check first some mosfets and fuse burns or burst try to check the IC that is connected to the mosfet. try this place one of your multimeter prods to ground and poke the other one to the suspected parts. hope you find the fault.. hope this helps..
            • alas3376
              • Nov 2011
              • 382
              • BENIN
              cheers
              these are probably 12uF 25V capacitors. but firstly, you need to clean them to make sure the contacts are ok
              • Cipher
                • Mar 2014
                • 3
                • United Kingdom
                I checked those mosfets I mentioned their not faulty its just that the gate voltage of pq213 is 20v so it cant saturate source-drain.
                The issue I now looking at is that B+ voltage is 13.5v all across the board does anyone know where B+ gets generated off.
                I really appreciate anyone helping me out on this.
                  • 21922
                  PU300 - BQ24777RUYR ,pin 27 .
                  • Comrad_SU
                    • Feb 2014
                    • 31
                    • Ukraine
                    Thank You Bro!
                    • mitchw
                      • Dec 2016
                      • 152
                      • Slovenia
                      Hey, I need boardview for this board, trying to repair liquid damaged board with some components missing
                      • mitchw
                        • Dec 2016
                        • 152
                        • Slovenia
                        Hey, found a .BRD file online, but it is 68 MB size (extracted). My boardview software won't open it.
                        Anyone knows what program I should use?
                        • Rezistor
                          • Jun 2021
                          • 302
                          • USSR
                          Allegro Free Viewer 17.2
                          • AL._.EX
                            • Dec 2022
                            • 896
                            • Belarus
                            Boardview
                            • its service
                              • Feb 2021
                              • 147
                              • india
                              Thx bro
                              • Mido alaa
                                • Apr 2018
                                • 3
                                • Egypt
                                aam00 la c361p rev 2.0 i need boardview plz
                                • tomodachi
                                  • Apr 2012
                                  • 611
                                  • Turkey
                                  Thank you
                                  • kingkong computers
                                    • Sep 2018
                                    • 211
                                    • pakistan
                                    BOARDVIEW FILE 100% WORK BDV FILE
                                      DELL XPS 9550 Notebook 15 Specification for Upgrade or Repair
                                      This specification for the DELL XPS 9550 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9550 boardview and 9550 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9550 Notebook...
                                      09-06-2024, 07:11 AM
                                      09-06-2024, 05:54 AM
