Bios dump for a1278
  • bluestar77
    • Apr 2015
    • 57
    • sudan
    Bios dump for a1278
    Hi there I need help finding bios dump for Apple MacBook Pro a1278 820-2530-a k24 emc 2326
  • angel-boy
    • 550
    • Romania
    Re: Bios dump for a1278
    hi , try this .
    • bryanpoints
      • Aug 2017
      • 57
      • Philippines
      tested sir ANGEL-BOY THANKS
      more power badcaps
      • snakepit7
        • Dec 2015
        • 29
        • mexico
        Thanks!!!!
        • outsider
          • Apr 2014
          • 104
          • localhost
          Thansk!!!
          • mferna14
            • Jun 2018
            • 1050
            Thanks angel-boy., BIOS worked 100% clean .... April 26th 2020
            • 65c102
              • Apr 2017
              • 28
              • england
              got my beeping macbook back on its feet
              thanks angel-boy
              do you guys know of a simple guide for editing this bios so I can put my original serial number ?
              • firulilla
                • Jun 2014
                • 64
                • spain
                thanks for sharing
                bios worked,,thanks
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • mkdj
                  ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                  by mkdj
                  Dear all,
                  I have a ASUS ZenBook UX480F with the following symptoms:
                  I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                  I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                  10-19-2025, 04:41 AM
                • Habble7
                  I need a BIOS dump for the Samsung S49CG934SU monitor
                  by Habble7
                  The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                  Suspected Cause:
                  I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • haitham sharabati
                  [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                  by haitham sharabati
                  Hello engineers 😀,
                  I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                  🔧 Device Info:
                  - Model: HP 15-da2007ne
                  - Product Number: 8XF55EA#ABV
                  - Serial Number: CND0338P0D
                  - CPU: Intel Celeron N4000
                  - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                  💀 Problem:😅
                  - Device shows “Administrator Password”...
                  08-07-2025, 04:54 AM
                • Citymin
                  NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                  by Citymin
                  My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                  The charging red LED lights up, but the charging screen doesn't show any indication.
                  When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                  (I've tried removing the battery and resetting the device, but the issue persists.)
                  NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                  PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
