Standby regulator Switch on a VCR P.S project?
  • ivtec
    • Dec 2008
    • 1967
    Hi guys;Maybe this Idea for my old Sony VCR stand by switch maybe a crazy idea and maybe not executable,but i like crazy ideas, who knows if some one of you are experts and can tell that it can be done or not; here goes my idea; i have an old Sony VCR for the tuner from my coaxial RF distribution cable and i'm using it with my small 8'' lcd Phillips monitor in the bathroom and have the VCR hidden inside the vanity and all connected to a power outlet with a switch,when i turn the switch on it turns on monitor and VCR but the VCR goes right back to Standby so every time i have to access the Vanity inside where the VCR is and push the power button.
    My question?, is it possible to make an adoption in the VCR power supply and replace the standby switch regulator for one that switches on VCR without going through the Stand by regulator mode switch ?i can mess with this one because i have a few more of these SLV700 models.thanks
  • ivtec
    • Dec 2008
    • 1967
    Re: Standby regulator Switch on a VCR P.S project?
    Could this power switch be adapted to my vcr sony power supply?
    https://cdn.badcaps-static.com/pdfs/...80cc3bac4c.pdf
    • R_J
      • Jun 2012
      • 9633
      I don't think simply turning on the power supply will work, the microprocessor still needs to see the momentary power on command.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8716
        I had to do something similar for an ATX motherboard that did not support turning on after power outage. I hacked up a 555 circuit that generated pulses "pressing" the power button that kept going until power was turned on. However this sort of depends on characteristics of the ATX system and can't be directly applied to a VCR.
        After solving a VCR power on problem, a slightly different circuit is needed to power it on upon power restore. I think it will require a small relay so it will work regardless of what VCR you have...
        • ivtec
          • Dec 2008
          • 1967
          Thanks eccerr0r; can you elaborate on small relay so it will work regardless of what VCR you have...thanks
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8716
            Well, if you have the relay in parallel with the actual power switch, that's all that's needed. Just need to design in the "button pusher". I'd imagine a 555 that has a 10% duty cycle, 2 second repeat rate, and shuts off when power is on... then that should do it.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8716
              I think the toughest part is finding a signal on the VCR that indicates it's on... (and a power source that you can tap off of). Past these to things, it shouldn't be too hard...
              • Longbow
                • Jun 2011
                • 623
                You will need the Sony schematic. It is possible that you can identify the wakeup line from the system control micro to the supply. If that line is hard wired to be active, the supply should stay on after the power up cycle. Another easy way to approach it would be to maintain VCR power and set a daily timer recording schedule that wakes up the VCR a few minutes before you need it. Stick an old tape in the machine and program it to use EP speed; rewind the tape once a week. Why over-tech it?
                Is it plugged in?
                • ivtec
                  • Dec 2008
                  • 1967
                  Thanks longbow; your scheme seems to be appealing but i don't have enough skill to try it and the recording timer also seems to a hassle,but i found an easier way, i went again through my scrap parts and found an extra IR Pyramid transmitter i put in front of the VCR IR eye inside the Vanity and i have an IR pyramid receiver in every room including in the bath room to be able to change channels from OTA receiver everywhere in the house for my old coaxial RF tvs, i have also a vcr sony remote,so this is the easier way ,thanks anyway for your expertise skills .
                    Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                    This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-06-2024, 05:30 AM
                  • nubie
                    Gigabyte B460M DS3H blown standby regulator, hot 5v(?) Regulator
                    by nubie
                    Please help me ID the blown chip and point me where the short might be.
                    I have a L1085DG that is getting really hot and a blown up standby regulator (I assume, one leg is ground, one leg is 5v standby, the other has 180 Ohms to ground.
                    The L1085DG is in the front corner of the board. With no standby power I am using a jumper to get the PSU powered on.
                    Anything I should check first for a short?
                    Edit: I can look again but I don't think the USB are shorted, on back or the headers. The USB2.0 are powering up my portable monitor, so I don't think...
                    01-05-2023, 06:06 PM
                  • BOSCHNJAK
                    by BOSCHNJAK
                    ABOUT ME INTRODUCTION FILE
                    2
                    024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                    2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                    2022 BEV, PROJECT ?
                    2021 BEV, PROJECT ?
                    2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                    2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                    12-28-2023, 02:09 PM
                  • hemant_2222
                    Yamaha RX-V373 no voltage on the standby switch
                    by hemant_2222
                    Could someone please advise on this. I have this Yamaha taken from a friend for repair, especially since it had a USB for my interest. But it is not working at all.
                    Here is what has been done so far. Checking the standby switch did not show 3.3 volts on one of its pins, the other was ground. it is showing as 0.60 volts. I have changed the switch as it had some resistance even when normally open. After changing the switch, I next saw that PIN 91 is not showing 3.3 volts.
                    The processor clock pin show 2.8 on pin 18 (XOUT) and 0.80 on pin...
                    11-29-2022, 11:33 PM
                  • Natob82
                    Micro Momentary Push Switch?
                    by Natob82
                    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                    12-21-2022, 05:22 AM
