Samsung LE32S71B no power/no backlight fixed
  • piernov
    • Jan 2016
    • 4439
    • France
    Multiple issues finally solved on this LE32S71B.
    First one was now power at all.
    Obviously bulged caps on the secondary of the SMPS. I replaced the caps for the 24V line which looked ok too.
    Still no power: a CBB was dead (slighty opened on the side), I think it was a 563J 650V.
    After replacing it, with a 562J though, the TV turned on, but showed the infamous 2 seconds to black issue: backlight problem.
    24V line for inverted was fine, caps on the inverter were fine. The issue was found to be the top-most transformer, with open-line secondary. (the others are around 1.1kohms). I couldn't find the transformer alone, so I bought the whole inverter on Aliexpress. Well… lucky as I am, it arrived dead: all fuses blown. No big deal, I desoldered one of the transformers (all tested OK on this "new" inverter board) and replaced it on the original inverter board.
    So far so good, power ok and backlight ok. I'm only worried about a small buzzing noise coming from the inverter (not from the replaced transformer apparently), so we'll see for how long it will hold out.
    Re: Samsung LE32S71B no power/no backlight fixed
    So the replacement is smaller capacitance of 0.0056uF instead of 0.056uF? That is not going to work, it also has to be Polypropylene type for high-pulse withstanding type.
    • piernov
      • Jan 2016
      • 4439
      • France
      Yep, it has 10 times less capacitance. I honestly thought it would not work but it does so all good for now… This was the only cap I had with a sufficient voltage rating as it is on the PFC-boosted line. The replacement is rated for 2kV, otherwise I had only 250V ones, maybe one 400V but probably not with the same capacitance either.
      I'm going to replace it as soon as I receive the proper part, but it's probably going to take a few more weeks.
        Can I see the board and the location of that cap?
        Board P/N is BN44-??????
        • piernov
          • Jan 2016
          • 4439
          • France
          I think it was BN96-03775A because I downloaded its schematics (attached) to troubleshoot the PSU.
          The capacitor is CM802, between the F9222L IC pin 23 and the transformer.
          I'm going to attach a picture of the board and the cap later if I don't forget.
            CM802 is the DC Blocker/Coupling cap for the output of the half-bridge that drives the primary side of that 24V power supply section. It has to be the correct capacitance, the smaller capacitance will have higher Xc so the primary winding will not be getting the correct drive Voltage, I am surprised that 24V power supply will be able to run at full load, I will not run the TV with the cap 10 times less than the original.
            BN96-03775A
            Pictures provided by Shopjimmy
            • piernov
              • Jan 2016
              • 4439
              • France
              Ok, still not sure what this cap do (if you have some pointers on this topology…), but can it induce high-frequency ripple on the 24V line? That could explain the buzzing noise. Maybe it would still be filtered by the transformer and the filter caps on the secondary though.
                The 24V power supply will not be bale to deliver the full power due to lower capacitance, it is part of the output circuit that drive the primary winding of the transformer, it is like putting a resistor 10 time higher resistance than the original in place. Just put in the right one and fix it correctly. They put in 0.056uF for reason. I already explain what the function of that cap is and what type and value it should be replaced with.
                See PDF page 10.
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  Cap replaced with a 563J 2K5V: the inverter is much quieter.
                  Here are some pictures.
                    Did you high pulse withstanding Metalized Polypropylene (MPP) type? Polyester film will not last in that circuit.
                    • howardc64
                      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                      by howardc64
                      TV was fixed just after removing Samsung's rear snap cover.
                      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                      Maybe PSU->backlight connector didn't have a good contact?...
                      07-23-2025, 12:34 AM
                      09-07-2024, 05:50 AM
                    • C152Heavy
                      Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                      by C152Heavy
                      Summary for TL-DR readers:
                      • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                      • Have obtained Samsung schematic & service documents - Can upload if helpful.
                      • Have read ALL applicable threads
                      • C1818 and CP820 replaced as low hanging fruit
                      • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                      • VCC pin (18) of PFC...
                      01-11-2023, 02:53 PM
                    • sansanpartida
                      Samsung QE82Q70RAT no backlight
                      by sansanpartida
                      Hi everyone!
                      Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                      My issue: No backlight.
                      Model: QE82Q70RAT
                      Type No: QE82Q70RAT
                      The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                      So hopefully, I can fix this cheaper.
                      05-22-2024, 06:56 AM
                    • howardc64
                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                      by howardc64
                      • Prior owner tried a replacement main board. No difference.
                      • Samsung 2x red blinking standby LED = panel fault
                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                      07-19-2025, 10:54 PM
