Toshiba 40L1333DG no power, blinking green/red power light fixed by flashing firmware
  • piernov
    • Jan 2016
    • 4437
    • France
    Fixed a Toshiba 40L1333DG TV with a 17MB95S-1 motherboard.
    It was not turning on (no picture/backlight/sound), even though the microcontroller would get hot. Sometimes the power LED was flashing green/red.
    The measurement on the PSU were good, except the DIM signal was 0V.
    By flashing the firmware, the TV came back to life again.
    At first I picked up a firmware which worked except that it was for the wrong panel, and such the colors were messed up.
    Attached is the good firmware for this TV, found at http://www.elektroda.pl/rtvforum/topic3202664.html .
    (splitted it in 2 parts because it's just above the size limit)
    Procedure for flashing:
    Grab a USB key, create one FAT32 partition, put all the files (mb90_en.bin, mboot.bin, usb_auto_update_A1.txt) at its root, plug it in the TV (I used the top USB port), hold the OK button on the remote and turn the TV on. Wait for the LED to start flashing (faster than the regular error blinking), you can release the OK button. When it's finished, the TV will restart by itself and show the configuration wizard.
    I also attached some schematics for the PSU, not sure which one is the right one, but at least you get the pinout for the CN4 connector to the motherboard.
  • habanerocat
    • Nov 2014
    • 96
    • Ireland
    Re: Toshiba 40L1333DG no power, blinking green/red power light fixed by flashing firm
    I'm digging up this thread as there is lots of info relevant to my questions.
    I have a Toshiba 40L1333DB TV with symptoms as above.
    I tried to load in the above files but it didn't seem to work.
    Then I found a a bin file, Toshiba 40L1333DG.bin in the "Eeprom dump thread!", but that didn't work either.
    I hold the "OK" button on the remote for 10-20 seconds, blink rate changes, but nothing seems to happen after that, no matter how long I wait.
    Couple of questions.
    Am I using the right files?
    Is it critical to use a FAT32 or just FAT formatted USB stick? (read elsewhere)
    Does it matter which USB port I use? (read elsewhere)
    After the first 10-20 seconds, how long then should I have to wait?
    Should something appear on the screen at any stage during the load?
    Many thanks for any guidance here.
    • nomoresonys
      • 12268
      • U.S.
      Very nice fix, was there instructions how to do it or did you already know?
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        have you seen this try try whats in post one and whats in post 10 post 15
        https://www.badcaps.net/forum/showth...shiba+firmware
        • habanerocat
          • Nov 2014
          • 96
          • Ireland
          Thanks for the help above.
          I think these Tvs break down a lot leading to "Too Much Information" and hard to find an exact solution.
          The link in the above post lead me to other links in other posts and the whole thing became confusing.
          I finally found this link. Post #8 contained the correct procedure and firmware for my TV. So thanks to @asek94.
          https://www.badcaps.net/forum/showth...hiba+40L1333DB
          Also of help was:
          Finally as a last resort, or perhaps I might have to do it yet, is this:
          https://www.badcaps.net/forum/showth...el+ceramic+cap
          Again, thanks to all.
          • habanerocat
            • Nov 2014
            • 96
            • Ireland
            Ok an update.
            TV still wasn't 100% right, especially on a cold start. Also the terrestrial tuner wasn't available in the tuner menu. So I download the latest firmware and load procedure from the Toshiba website. Tuner was now available and worked fine, but TV still wouldn't turn on consistently. Just a flashing green light.
            So I took the drastic step indicated in the third link in my post directly above. @steviewonder is a genius. Many thanks to him.
            • kas49
              • Nov 2019
              • 10
              • France
              Hi Piernov
              That was my fastest TV repair ever for a non obvious failure
              Thanks for this very informative post
              Greetings from Grenoble Repair Café
              • H34TO
                ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                by H34TO
                Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                06-17-2025, 07:17 AM
              • DarrenHD
                Firmware for older Toshiba TV 22CV100U
                by DarrenHD
                HI all, Does anyone know if there exists an archive for older firmwares for Toshiba TV's? I've searched all over Toshiba's various websites and also on Dynabook's site (they say they deleted all old firmwares due to "server space". ) Toshiba has not replied to my request.
                I'm looking for Firmware 1.07 for the 19/22/26/32 C100U series as described in this link:
                https://support.dynabook.com/support...tentId=2865076
                Thanks!
                06-16-2025, 11:56 AM
                09-06-2024, 05:27 AM
                09-06-2024, 05:59 AM
