Strange noise when powering up AVR
  • madan1
    • Nov 2016
    • 726
    • Bulgaria
    Hello everyone.
    I had this topic posted in the Audio section, but nobody replied there.
    Since this is not that much audio-specific, in this section there could be people who might help.
    Here is the original post:
    ...Yamaha RX-A1010 receiver. It was working just fine for some time, but then suddenly developed a new "feature". When powered-up from long stand-by it makes a "camera-flash-charging" noise.
    Find attached wav file with the noise and the service manual.
    From the schematics of the power supply ( pg 133 ) , it looks like the noise is happening when the main power relay RY201 closes and powers up the transformer. From there ( pg 132 ) there is another relay ( ry109 ), a rectifier bridge ( d1050 ) and the big 12000uF filter capacitors ( c1105 c1106 ).
    So I guess the noise is associated to the charging of the caps? Is it the transformer or the caps?
    For now I do not see/hear any issues with the functionality of the receiver, but is it possible to get worse?
    p.s. the manual is too big so had to upload it here -
    this is the wav attachment
    https://www.badcaps.net/forum/attach...4&d=1492791503
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Strange noise when powering up AVR
    High frequency sound developed in the transformer??...If the system is working even with this new sound then we may not be able to 'fix' it as all voltages etc would be correct for start-up and play. When it stops working as it should then and only then might we be able to help......My advice...Don't worry about it until it stops working.
    • madan1
      • Nov 2016
      • 726
      • Bulgaria
      So you are saying it is the transformer?
      What is the cause behind that new "feature"?
      The voltages seem to be fine.. at least according to the inbuilt system/service menu.
      • R_J
        • Jun 2012
        • 9607
        The "sub transformer" is the switching supply for the +5.5 volts, it supplies the voltage for the relay coil, I suspect when the unit is turned on the relay coil current is enough to make the power supply make a noise, I would suspect c2021,24,26,27,35 or maybe the ones in the primary like c2010 or c2017
        • petehall347
          • Jan 2015
          • 4440
          • United Kingdom
          does it have a slow start resistor ?
          • madan1
            • Nov 2016
            • 726
            • Bulgaria
            Originally posted by Andrew F. Ali
            ..When it stops working as it should then and only then might we be able to help......My advice...Don't worry about it until it stops working.
            and here we are again
            It got worse - it started to make more noise after that initial "start-up" sound. For now that "after noise" disappears after some time ( <1min ), but it looks like it affects some of the functionality.
            In the service menu all V are within the specs, but I noticed some errors in the communication between the modules on the hdmi board ( cpu <-> dsp1 ). During the time when the noise occurs the unit refuses to play network and tuner streams ( still multi-channel input which does not go through the hdmi board plays fine, which means that at least the power amp section is not affected ).
            So anyone willing to reveal what causes that psu(?) noise... choke? transformer? caps? ....???
            What could be the cause to develop that problem?
            I suspect that I have a bad pc psu ( pc working fine but the psu is making high-pitch sound ) and the pc is my main audio/video analog/hdmi source ).. could be it?
            I also have placed the yamaha on my subwoofer ( it had to be temporary, but... )... so could be the vibrations? .... or is it just bad luck?
            All the equipment uses the same wall socket ( common ground ).
            • madan1
              • Nov 2016
              • 726
              • Bulgaria
              Aaaaand it died... all "smart" functionality ( usb, network, radio, etc. ) got broken. Basically I was left with not that good* sounding power amplifier ( multi channel in ).
              So, long story short - after resoldering the main power pcb ( the one with the standby/low V transformer ) now everything seems to be working fine.
              I guess the vibrations from the subwoofer were the root cause... then cracked solder joints, ripples and so on.
              Now I'm sorry that I forgot to hook that board to the scope to see whats going on there... I only tested the other power board ( powered by the main transformer and outputting +/-7 and +/-12V ).
              *personal opinion
              • tony359
                by tony359
                11-28-2023, 05:18 AM
              • ohren
                Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                by ohren
                Hello!
                I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                Measured voltages with no load:
                After rectifier diodes
                12V: 6.17 V
                5V: 5.67 V
                Secondary transformer pins AC measurement (really don't know if this says anything)
                12V: 2-2.5 V
                5V: 1.04 V
                I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                03-18-2023, 10:33 AM
              • mikey5791
                Is it possible for transformer substitution?
                by mikey5791
                Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                My questions are
                1. How do i test to see if the transformer is in good working condition?
                2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                Hope you guys understand what i was asking. My intention is...
                11-03-2022, 02:11 AM
              • courtcircuit
                Philips HTS8000 home cinema noise problem
                by courtcircuit
                Hello
                I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                Removed each of tyhe boards
                02-08-2025, 08:22 AM
              • dennis_elx33
                3PHASE STEP-DOWN Transformer in Check
                by dennis_elx33
                Hello All,
                i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                Problem statement: Power tripped Off
                Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                Action Done:
                1) Replaced the faulty parts with good spare.
                2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                12-02-2024, 06:52 AM
