Because of bios password,need dump hp probook 430 g3 motherboard dax61cmb6c0 rev c.many thanks in advance.
Hp 430 G3 bios unlock help please
Tags: None
can someone help me to unlock this bios ?
Thanks in advance :***Attached FilesComment
Re: Hp 430 G3 bios unlock help please
Welcome back to badcaps...I`ve rebuild this for you ...try and post results...
Attached FilesLast edited by Djosla; 03-01-2017, 04:50 PM.Comment
Ok try this dump and post results...
can you try thisAttached FilesIm Back... sort of...Comment
with g2 and i think with g3 the only way is to reprogramm ec and main bios with a dump from the same machine if not appear a "machine is not in committed state".
for the password, if tmp is not enabled, it is sufficient to reprogram both ec and bios.
But if all the protections are enabled, it is very difficult to overcome the problem.Comment
i can't read the ec.....in my stupidity when i bought the programmer i didnt buyed the peb-1 expansion slot to read the ec..
did u try this with original bios rom?
https://www.youtube.com/watch?v=Qv-ahswViWcComment
hp probook 430 g3
pls i need dump for hp probook 430 g3 board codeA0X61MB6G0 REV G Model;x61
it is working but with passwordAttached FilesComment
by zeniusHello, I have an old Dell G3 3579 (ST: 2WQ7LP2-8FC8) with a newer 8FC8 BIOS password. I have successfully attached to the flash chip (W25Q128JVSQ) on the motherboard with a CH341A programmer and made several modifications using Intel FIT (e.g., allow software SPI write) without bricking. I was also able to boot to a modified GRUB shell where I attempted to edit many BIOS security related options like BIOS Guard/Lock, Flash Signature Override, ME FW Image Re-Flash, etc.
Unfortunately, some of these modifications like to Intel BIOS Guard failed because it is fused into the PCH. Also,...-
Channel: BIOS Requests ONLY!
by studdy05Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
Ive got...07-08-2025, 09:24 PM -
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
- Loading...
- No more items.
