Vizio M60-C3: dead PSU
  • HAHOMETP
    • Nov 2012
    • 155
    Folks,
    I have this Vizio M60-C3 with the PSU not showing any secondary voltages whatsoever. The main bridge rectifier shows 160v DC between M10 and M11 pins. No voltages on any pin of CN201, CN301 and CN202.
    I tested ~90% of semiconductors on the board (everything that was easily testable with a multimeter w/o desoldering the component).
    1. MOSFET Q1 (K8A65D) was shorted between all 3 pins. Replaced it with a TK8A65D(STA4QM)-ND from Digi-Key.
    2. Zener ZD5 was blown (yes, physically blown). It was a Vishay MMSZ5250, 20v, in SOT123, J5 4. Replaced it with a through hole 20v Zener from my stash.
    Nothing else seems out of order, yet the board is still completely dead. Both the Q1 and the ZD5 replacements survived the power-on, so the problem must lie downstream from them and was most likely cased by the shorted Q1.
    Does anyone have any idea where to look? Pix attached.
    P.S. Is there a Boolean search on the forum? No matter what I do the search reveals the results in the form Vizio OR M60-C3 which is rather useless.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8340
    Re: Vizio M60-C3: dead PSU
    If all legs on Q1 were shorted, then I would check all the components of the gate drive circuit of the FET and the PWM that switches it. Also make sure the PWM gets Vcc. Other than that it will play dead too.
    • caspian
      What Zener Diodes on a Linear Power Supply
      by caspian
      Dear members,
      I have a linear variable power supply with unknown brand name that I used for voltage injection.
      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
      In addition, I discovered that its zener diodes are defective.
      I can replace the burned transistors.
      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
      Therefore, I cannot replace the zener diodes.
      I do not want to test the zener diodes in a test circuit to discover their model or value.
      no schematics are available...
      05-26-2025, 12:38 PM
    • Dvsr
      On M-Audio AV40 active studio speaker's two zener diodes get really hot.
      by Dvsr
      Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
      I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
      After replacing the caps I started testing out the speaker. It seemed...
      09-10-2025, 10:20 AM
    • Iain P
      Vizio E65-F0 really dead
      by Iain P
      Hi everybody!
      I've got a Vizio E65-F0 smart tv that is good and dead. It shows no signs of life when I press the power button on the back. The power LED in the lower right corner doesn't light, there is no backlight and no picture.
      So I took the back off and started poking around figuring one or more of the caps had dried out. My esr meter says all the caps on the power supply board and the mainboard are less than 1 ohm.
      I decided to check the voltages coming off the power supply they are as follows:
      connector CN201
      pin 1 (18vsb1)...
      02-23-2023, 11:32 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • catnapped
      Dead Vizio D40u-D1
      by catnapped
      Recently had my bedroom Vizio D40u-D1 apparently die while it wasn't being used. Noticed the power LED flashing, figuring maybe a software upgrade, but attempting to turn it on proved that wasn't the case. When powered on, the power LED will flash a bunch of times after about 2 minutes then turn off again. Definitely is no picture even with a flashlight on the screen. Had the opportunity to open it up over the weekend. Doesn't apper to be anything out of the ordinary visibly inside, nor any odd smells of escaped magic smoke. Readings from the connector in the corner of the power supply board...
      04-02-2024, 08:55 AM
